Probably not. Sounds like a bad ground. The ground connecting point for the door is behind the drivers side kick panel, lower left. And the ground for the fuel sending unit is on the drivers side fender well. First I would unplug the connection at the tank (you can usually access this plug without drooping the tank) and check for corrosion. Clean it if any and take a paper clip and bend the tabs a little in the plug to make a better connection.
