Question about Bogen Communication BOGEN DDU250 DYNAMIC DESKTOP GOOSENECK MICROPHONE Microphone
Bogan DDU250 Decktop mic
We have a Bogan DDU250 Decktop mic and would like to put an XLR connector on it so it can be portable panel discussion microphone and used with a mackie mixer. Is this possible and if so can you show us a diagram of how the wiring would be soldered.
    Sergeant:
  • 243 Answers
The tip is is soldered to 1 and the sleeve/ring is soldered to 2 on a xlr. thanks nate. i have pictures i can email you if you need more.
Posted on Aug 22, 2008
  • Anonymous Aug 29, 2008
    so you got it and didnt need any thing else i asked if you did sorry you didnt feel the need to reply so i could better assist you.
  • Rommel Jimenez
    Rommel Jimenez Oct 18, 2018
    Hello Nathan, I have a client with one of this BOGEN DDU250 Mic and need to be able to connected to the computer for dictation. Could you please send me the pictures or we can work something out, me sending you the unit for you to work on it and you charge me, here is my email: rommeljjimenez @ gmail . com, i really hope that you can help me either way. thanks in advance.
SOURCE:
My external mic wont work! Please help.
If the mic is working on other camera's, what about the adaptor ? If there is a possiblity of checking the mic and the adaptor together on other equipment ? Use another mic with the same plug as the camera, ie. PC microphone (you can even test by using an earphone, the earphone can be used as mic) If it works then the XLR mic with adaptor is the problem. If ther other mic (used for testing) also did not work then the microphone jack (socket) in the camera is defective or the gain setting of the camera is set to minimum.
Jun 05, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
No sound from mxl 990 condenser mic
From the Micropower PS400 product description it states:
"routes the microphone signal to a mixer or a microphone preamplifier."
• these is just a phantom power supply.
One reason your former setup is OK , is that
tascam m-50 is a mixer preamplifier.
• phantom power supply is just a part of the mic preamp of the mixer
to power up your mxl 990 condenser mic
• What you may need is something like these:
X2u XLR to USB Signal Adapter
Sep 29, 2012 | MXL 990 Professional Microphone
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
I’m happy to assist further over the phone at https://www.6ya.com/expert/stanley_d05f392d8fafa669
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
I bought a ddu250 and an xlr connector for it. I looked at the picture of the wiring diagram and it has the White wire going to pin 2, the black wire going to pin e and the shielded wire going to pin 1. ...
does this mic have a switch? Is this mic dual impedance? If it is dual impedance depending on the impedance of the input will determin if you use 2 or3 wires. If it is only low impedance then white to pin2 black to pin 3 and the shield to pin1. If it is low imlpedance and has a switch the red and blue wire may be connected at the switch and may also have to be conneceted to pin2 and3. any more questions call me a the store.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
[email protected]
[email protected]
www.prolinemusic.com
Jul 14, 2011 | Bogen Communication BOGEN DDU250 DYNAMIC...
Hello My name si Christopher and I have a Sennheiser E815S microphone and was wanting to know how can I get it to work on my PC?
Christopher, your microphone is a dynamic type with XLR connector. This means that you can connect this microphone at your pc (at the mic in connector, the red one) using a cable with XLR female connector at one end and 3.5mm jack male connector at the other end (like this). Keep in mind that the 3.5mm male connector has to be a mono type, a stereo one will not work. In case you have the connectors and a suitable cable you can connect as follows:
YOU MUST CONNECT BOTH 1 & 3 pins from XLR side at the ground point of the jack.
The whole setup won;t give the best sound quality, but it's the simplest and cheapest way to use your mic and the pc. In case you need better quality, clarify me what you are trying to do order to give you some suggestions.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jan 31, 2011 | Sennheiser E815S Professional Microphone
I have a mic Behringer C1u and would use it with an M-Audio fast track usb interface. How can I do it?
You will need to turn on the phantom power which will be a switch labled eithe PHANTOM or +48V to use the condenser mic. YOu MUST use an XLR to XLR cable.
Sep 10, 2010 | Behringer C1U Microphone
Microphone
For microphones with a 3.5 mm miniplug you can use a plug-in at the front of the camera. There is a little plastic cover over the hole under the word "MIC". I would call this an emergency solution because for most recording purposes you would want a microphone with XLR connectors.
This camcorder comes with an external shotgun condenser mic and XLR adaptor. If you have the operating instructions that come with the camera, you can turn to page 29 where there is a description of how to install the supplied external microphone.
When you slip the hot shoe plug of the XLR adaptor into the intelligent accessory shoe, the internal microphone is by-passed. In case you do not have the operating instructions you can download them from the Sony manual site.
http://esupport.sony.com/perl/select-system.pl
Put briefly, Attach the XLR adaptor to the accessory shoe on the top front of the camcorder and tighten the screw of the adaptor. Connect the hot shoe plug of the SLR adaptor to the intelligent accessory shoe of the camcorder, located behind the adaptor screw. When you push the hot shoe plug into place you should hear a click. Sometimes you have to use a little strength to get it correctly seated.
I hope this helps.
Dec 12, 2007 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Bogen Communication BOGEN DDU250 DYNAMIC DESKTOP GOOSENECK MICROPHONE Microphone Logo
538 people viewed this question
Top Bogen Communication Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Bogen Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
