Question about Speed Queen AWS52NW Top Load Washer
Speed Queen AWM 373 w3062w
Intermittently, when the machine is switched (any function) nothing happens. It sounds to me like a switch/selector problem.
Assuming it is, is this a job for a ok DIYer.
MNM
    Novelist:
  • 172 Answers
I would start by checking the lid switch, you should hear a click when you open and close the lid. If this is ok we will move on to the timer.
The main power comes thru the timer when you pull out the timer knob the main power is fed to the machine. if you try and start the wash cycle multiple times will it occasionally work and then not. It so replace the timer. the p/n is on the back, it will be an RSPC number, typically 5 or 6 digits.
Then go to Partselect.com or repairclinic.com or a local parts house since you have an Export model for the Asian area I believe you may need to find someone local. The price on one I would think about 85 USD.
Let me know if you have questions. I can tell you how old it is if you send the serial number. Your choice.
T
Posted on Aug 22, 2008
My heat stopped blowing in my 1998 escort zx2 it just quit where do I start I checked all the fuses they are good is there a blower motor relay ??
"I checked all the fuses.." There is only one fuse, the 20A WIPER one in the instrument panel fuse panel which energizes the blower motor relay. The panel also contains the BLOWER circuit breaker which supplies power to the relay. If these parts check OK, there will be 12 volts on terminal 87 of the relay with the engine running and 12 volts on the BLU wire connected to the blower motor. If you set the function selector switch to any position other than OFF, the blower motor should operate at a speed you select by rotating the blower switch. If this doesn't happen, rotate the blower switch to HIGH. If still nothing, the thermal limiter in the blower motor resistor may be open. If still nothing, the function selector switch, the blower switch, the resistor or even the blower motor itself could be defective
Oct 13, 2012 | Cars & Trucks
Machine stop working after wash cycle
Typically this is a sign that the timer switch is sticking and needs to be replaced. I have also found that sometimes a faulty speed selector switch can cause a similar problem, but more than likely it is the timer switch.
Jun 11, 2012 | Speed Queen AWS52NW Top Load Washer
Speed queen washer mod.AWM 593W How do youu lift the top of the cabinet to remove inner basket?
use a 5/16" nutdriver/socket and remove the two screws and the bottom of front panel and tilt panel out and then look and find 2 screws(one on each side) facing up on the corners of top/cabinet, remove those and raise top
Jul 22, 2011 | Speed Queen Washing Machines
I have a Speed Queen top loader(older model). It let's water in but does not wash or let water out. I have checked the control pannel and motor. All seems to be ok. The reset used to work but now it does...
Make sure that the lid switch is working as it can make the program from advancing forward. So check the continuity of the switch that goes to trigger the main board.
If Ok then the program controller is not functioning, if you can try to change manually then the control board is faulty.
Jan 13, 2011 | Speed Queen AWS17NW Top Load Washer
I have a Speed Queen Heavy Duty Large capacity wash machine model:AWM 351-3062 I need to find out ifit has a steel drum
Yes, all Speed Queens have a stainless steel tub, some are coated, but underneath is stainless steel
Jun 12, 2010 | Washing Machines
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
AWM 352 washer motor connection
Look at laundry.manualsonline.com , search for awm351. A manual is posted that may help you.
Mar 30, 2008 | Washing Machines
Speed Queen AWS52NW Top Load Washer Logo
378 people viewed this question
Top Speed Queen Washing Machines Experts
Dan Webster
Dan Webster
Chris Hall
Chris Hall
Paul Bade
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
