Question about Acer Aspire L100 PC Desktop
Testing the motherboard
How did you go about testing the caps? In my case I've got power into the case but no voltage at the frontpanel switch. Haven't poked around further. I needed to get my wife going quickly so I bought a barebones kit and popped the disk from the Acer into it.
  • 68 Answers
The failed caps have obviously vented at some point as it was swollen and an obious doming was present on the top of the cap.
I have inspected the other failed machine which Acer refused to repair alongside some other kit ive had fail recently and they all have the same rated cap failed.
Ive since found this article which could be the root of the problem with the acers.
As I said earlier what I found with mine upon applying power I heard a faint click from the piezo buzzer and the LAN LED flashes once.
Hope this is of help, if you need any more dont hesitate to ask.
Nick Sharp
Posted on Aug 21, 2008
How can I be certainty that my motherboard is bad
Jun 27, 2013 | Computers & Internet
PC not POST - Phase LEDs blink once then nothing
Try testing with a voltmeter. They are common, cheap, and you may even have one. Or, at least be able to borrow one.
Nov 08, 2012 | Computers & Internet
Rca p52738wk projection tv has power but wont turn on button will flash and keep clicking so its got power but tv wont turn on
Possible there is a short within the outputs and so the power is tripping off when switched as a protection since the chances of damage is more.
It will require a voltage check on the motherboard to confirm if the +B voltage comes up and fails. If you trace the +B it will lead to the fault condition. In most cases if the switch on is repeated you can notice the heating of a driver or component which can confirm the fault. Once the short or the drain circuit is removed the +B will be stable.
Make sure that precaution is taken when testing high voltage circuit.
Oct 04, 2011 | RCA Televison & Video
My Geyser element is not heating - test done show full voltage supplied from thermostat to element. when element removed from casing and wired directly to power supply heats up no problem. direct power...
Sounds like a bad thermostat. If testing continuity be sure you are testing with at least one wire off. Continuity will feed backwards through the element rather than actually testing the switch.
Jul 29, 2017 | Heating & Cooling
TV quit working
I just fixed a friend's set that had the same symptoms.
Multimeter check: all the expensive parts are still good!
Physical check: Hmmm this pair of 10V 1000uF caps are bulging on their tops. ( they are located by the output connectors ).
I swapped out the two bad caps. and Bingo!
Mar 12, 2010 | Samsung LN40A500 LCD TV
I have medion akoya s5610 laptop. Power light bottom left comes on when conected but nothing else happens, just black screen, no attempt to boot.No light on power button either
  1. Believe it or not, the number one reason why a computer won't turn on is because it wasn't turned on!
    Before starting a sometimes time consuming troubleshooting process, make sure you've turned on every power switch and power button on your computer:
    • Power button/switch on the front of the computer
    • Power switch on the back of the computer
    • Power switch on the power strip, surge protector, or UPS (if you have one)
  2. Verify that the power supply voltage switch is set correctly. If the input voltage for the power supply does not match the correct setting for your country, your computer may not power on at all.
  3. Check for disconnected computer power cable connections. A loose or unplugged power cable is one of the top reasons why a computer doesn't turn on.
  4. Perform a "lamp test" to verify power is being provided from the wall. Your computer isn't going to turn on if it's not getting power so you need to make sure that the power source is working properly.
    Note: If you have a multimeter or another electrical testing device you are welcome to use that to test your wall outlet (and power strip, surge protector, etc.). The lamp test is useful if you don't have an electrical testing device.
  5. Test your power supply. At this point in your troubleshooting, it's very likely that the power supply unit in your computer is no longer working and should be replaced. You should however test it just to be sure. There's no reason to replace a working piece of hardware when testing it is fairly easy.
    Replace your power supply if it fails your testing.
    Important: In the huge majority of cases when a computer isn't receiving power, a nonworking power supply is to blame. I bring this up again to help stress that this troubleshooting step should not be skipped. The next few causes to consider aren't very common.
  6. Test the power button on the front of your computer's case. It's not a very common point of failure but your computer might not be receiving power because the power button on the front of your PC is damaged and is not actually turning your computer on.
    Replace the power button if it fails your testing.
  7. Replace your motherboard. If you're confident that your wall power, power supply, and power button are working, it's likely that there is a problem with your PC's motherboard and it should be replaced.
Nov 27, 2009 | Medion md40298 Notebook
My Aspire M1600 (desktop) might have encountered an overvoltage surge and wont start at all. The lower blue LED on the frontpanel is flashing slowly (1 sec). Where to look /what to do? Looking forward. BR...
Test the power supply first- to do this you should use a "tester". OR un plug the power cable from motherboard 20/24 pin adapter and might as well unplug the rest of it for the testing purposes. With the 20 pin cable unpluged look for a GREEN wire on it then taking a paper clip TOUCH green wire to any SOLID BLACK wire. If the power supply powers up - fan comes on- its likely a Motherboard failure.
Note: you can (test power) on the power supply with everything plugged in by "shorting" the green wire to black wire for 5sec. if the pc AUTO turns back off after 5sec it is bad motherboard or "maby" CPU/actual processor.
If you can throw some other RAM into the motherboard and try to power on normally.
You might want to RESET the bios - look for a jumper on the motherboard with 3 pins and - while unplugged from wall power - move the jumper to the other 2 pins (should share the center pin from 1st position) leave there for 5sec then move back to origional pins it was on. Then re-connect power and turn on normally.
Aug 06, 2009 | Acer Aspire (AST180-US340B) PC Desktop
Power supply fail DVE DSO-142L
The output + 5.1v/2.4 Amps and -5v/0.5Amps DC
Input is AC 100/240 VAC 50/60 Hz
Jun 05, 2009 | HP 336044-B21 8-port KVM Switch
Power on/boot-up problem
Have I got a story for you? Dell inadvertently used some defective capacitors in their Optiplex motherboards and some power supplies. From what I?ve experienced and read this affects the Optiplex 270 and early 280 lines. In my case my systems had video display problems and eventually ended up not booting. The giveaway is looking at the large 150 uf capacitors; they are the larger ones usually with an ?X? inscribed on the top. If the tops of the capacitors are flat you?re out of luck but if any of them are bulging (even slightly) at the top, leaking electrolyte or split Dell will replace the motherboard for free. This program is in effect till 2008. I wouldn?t recommend pulling the power supply apart but the flashing yellow power light for me has been a failed power supply. I would check out the motherboard for bad capacitors then call Dell. It?s likely they will replace the power supply if it?s in warranty, perhaps even if its out in light of the capacitor issue. If you?ve got some rounded caps on the motherboard I would also ask them to replace that as well. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 30, 2007 | Dell OptiPlex GX270 PC Desktop
Acer Aspire L100 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
