No audio in my goodmans LD1928w television
Hi
Thanks for helping me with this. All of a sudden audio of my TV is gone. It was okay at on emoment and there is no sound at all. Definitely not muted. Tried to connect to dvd, head phone and no luck. Looks like the audio is completely gone. Video is good. Any suggestions
regards
vinoth
    Genius:
  • 1,139 Answers
I would first try to determine if the problem is in the audio circuit or in the IF circuit. First you will need an RF signal generator with audio and video modulation this will allow you to inject audio into the set and allow you to track the signal with an oscilloscope. I would make the suggestion by your post that the audio circuit might be defective. However troubleshooting is the best bet. I would suggest that you have a qualified TV technician check the set out.
I hope this helps
Thank you,
Posted on Aug 21, 2008
SOURCE:
My audio has suddenly disappeared. the volume button on the TV and the remote are working, but I am not getting sound. Any idea why?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Dec 09, 2014 | BenQ DV3750 Television
My aiwa surround sound subwoofer is not working. I can here bass when I touch my finger to its cord however. Just isn't working when I play music.
Hi,You did not give make and model of your Receiver !!!
Was it working before or you have just connected it to the receiver..? All surround receivers have a surround Sound Setup procedure that either Activate or Deactivate the Subwoofer..So,pls check your Sound set up and speaker Connectiions on the back of Ampl?f?er.
If problem continues pls let me know with more detailed description.
Hope this helps! Take care and please Remember to rate/vote us
to continue for Helping out the Community :)
Thanks
Aug 21, 2011 | Audio Players & Recorders
I have a 1993 Toshiba 32 inch tv. suddenly there is no sound. The mute is NOT turned on. What might be the problem?
Hi kohn,
Plug your headset to the earphone jack (if installed) of the TV.
If you can hear the sound there, the fault may due to open(defective) internal speakers or the earphone jack itself. Faulty internal speaker may replaced with new sets to back your sound to normal again. If the earphone jack was faulty, you may spray it first with electrical contact cleanerwhile inserting and pulling the headset plug into it for one minute to clean the contact. If nothing happens, this jack need to replaced with new one.
If you can't hear the sound after inserting your headset, this is an indication that the audio circuitry was gone bad. The most common caused of this trouble was the faulty sound IC(mounted in heatsink). This is the one converts the audio signal to sound and feed to your speaker's. I would advice you to look for a qualified technician to check this parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 13, 2011 | Toshiba Televison & Video
Suddenly I have no sound on myVizio tv
Assuming that your remote is working and you see the on-screen volume overlay, I would check the audio settings from the setup menu. make sure it has the sound on and output to the internal speakers of the TV. If that is okay, try plugging some kind of audio device like external speakers into the output jacks on the rear of the TV. Audio rarely fails on a TV, however this could require service if you can't get any audio out of the thing.
Feb 03, 2011 | Vizio Televison & Video
No sound on channel 3
Maybe the cable signal is defective not your tv.the other channel is ok.if you tv has a defect all channel has affected.
Jul 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Distorted audio
Audio amps on original set are fubar.
Jun 20, 2017 | RCA F36695BC 36" TV
Need audio driver!
hi, m using compaq presario F700 - amd processor
i want audio driver for windows xp service pack 3... please provide me link to download the driver
thanks in advance
Jul 14, 2008 | Computers & Internet
Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Feb 17, 2008 | Televison & Video
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
Ekse
