Question about Fuji FinePix A210 Zoom Digital Camera
Focus error comes up as soon as the camera is turned on
  • Anonymous Dec 12, 2008
    Focus error comes on when I turn the camera on (as soon as i slide the lens cover to its full open position),,,the lens extends in and out and comes to a stationary position (a small unfamiliar electro mechanical malfunction sound does occur just prior to the focus error display..turning camera on and off does not work as a solution even when batteries are at peak [email protected] ..loved this camera but it is getting old!!!
Aw, that just happend to me..
It's an old camera, dude..
I turned it off and it sayed FOCUS ERROR and I reset everything and it is still unfocussed.
But it was FINE before that!!
SORRY I CAN'T HELP YOU!
but if you find someone who can, TELL ME SO I CAN GET MY CAMERA FIXED TOO!!
<3
Posted on Oct 19, 2008
SOURCE:
My camera was dropped on the floor, now everytime I turn it on it says lens error on the screen and the lens itself will not detract when turned off.
Focusing mechanism might be either broken and jumped out of its place
1) Take a screwdriver and open it yourself (it's not that complicated, as soon as you don't lose any parts; just try to remember where every part lies in).
2) When after opening the case you still don't understand how the focusing mechanism functions try to place battery inside, switch it on and then you'll see what exactly is blocking the focuser from moving back and forth.
3) Either place the focusing mechanism back correctly or if something is broken that you can fix with a SuperGlue - do it.
P.S. I once had the same problem after dropping my photo camera (Canon PowerShot G7), but the focusing mechanism was broken so had to go the mechanic to replace it. Mechanic normally wouldn't object that you have already disassembled the camera - less work for him.
Mar 05, 2011 | HP Photosmart M425 Digital Camera
MACRO FOCUS
Please download the manual here:-
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=1c6c4980e80fcb495c014b5150b0bc22&q=Sony+MVC-CD350 To turn off the Macro function, look at page 26.
To attempt to clear the error E61:00, press the reset button on the underside of the camera with a fine tipped object. This is also described in the manual.
If you have trouble downloading the manual or you are not happy with this solution please comment soon and I will try to help more.
Oct 23, 2007 | Sony Mavica MVC-CD350 Digital Camera
My camera will NOT focus.I have reset all the settings. As soon as the camera is turned on the image is blurry. Also, when uploaded to image is blurry.
There are tiny magnets connected to a ribbon cable, that control the focusing lens. It is possible that it has come slightly ajar, or loose. You can reseat these, but you have to disassemble the camera to do it. The other possibility is that there is a problem with the focusing mechanism (infrared mostly). If the sensor is bad, you have a major repair. Sometimes the ring that the magnets "sit" in can become stuck. In this case, you can try to give the camera a slight tap with the palm of the hand, hoping to free it up. Some people recommend laying the camera on it's back on a towel, and gently hitting the usb compartment, or other surface without switches, to try to free the focusing ring. Here is a web blog about stuck lenses, but some suggestions will possibly help you. This fellow has a lot more expertise than myself:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oh, if you do elect to have it repaired in case everything else fails, make sure you get an estimate first. These repairs can run more than new cameras on sale. Good luck, hope this helps!
May 05, 2010 | Nikon Coolpix S210 Digital Camera
Focus error on s5600 fuli help
The clip on the focus drive has detached itself from the motor thread ( or possibly broken )
There are no drive gears on this model, only a motor with a screw thread about half an inch long which the focus lens travels up and down on. This is attached to the drive thread by a small clip and a tension spring.
You will have to access you lens unit to acertain the problem.
My email is listed in "THE ONLY WAY I KNOW HOW.." in my tips and tricks section on my profile if you require any advice or help should you wish to effect a repair your self.
Aug 15, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Focus error
Can't take photos, camera show focus error.
May 04, 2009 | Fuji FinePix S9500 Zoom Digital Camera
Focus error show up and can't take any pictures
Had "FOCUS ERROR" appear on my Finepix S9500. The lens seemed to be stuck at the extremity of focus range. I resorted to hitting the camera on a table while turning it off (because this is when it sounded as though the focus motor was trying to move the lens back). Guess what? It worked!!!!!
Aug 11, 2008 | Cameras
Lense problem
Dear jmgrev,
Whenever you turn your camera on and your lens doesn't go in and out properly you are likely experiencing a lens error of some sort. Look for an error 18 or a "lens error restart camera" message. If either of these appears you definitely have a lens motor mechanism problem and will need to send the unit in for service.
If the lens still functions, but only intermittently - or if there seems to be a functional problem in focusing correctly or in taking an excessive time to focus, then you are in the early stages of what will soon become a fullblown lens issue.
These problems can be caused by a variety of things such as having obstructed the lens when turning the camera at one point, or getting grit in the lens mechanism or during/after a fall or some sort of impact. It can even happen spontaneously due to the tracking mechanism coming out of gear. Hopes this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
FOCUS ERROR
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
Mar 11, 2008 | Fuji FinePix F410 Digital Camera
Fuji FinePix A210 Zoom Digital Camera Logo
129 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
