Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Refridgerator light in refridgerator willn't come on change bulb, also clean switch. please help!
  • 61 Answers
Try remoing the rubber bulb mount using a flat screw driver and have the power off as well / the lamp assembly is plugged in behind /may have come unplugged. also check the switch for condinuity using a multi meter good luck
Posted on Oct 06, 2008
I have a 99 ford f250 5.4 super duty and dash lights and running lights come on when I press the brakes. I have changed multi function switch. Light Switch and brake switch. Checked all the bulbs and...
It could be if you tail light bulb and brake light bulb are the same bulb. You might have put the bulb in the wrong way round so the two silver bits on the bottom of the bulb joins the 2 wires together so when you brake the side lights come on and dashboard lights up or the other thing it might be is a broken wire hope this helps
Nov 15, 2013 | Cars & Trucks
If light stays on will refridg over heat?
The answer to your question is no,your refridgerator will not over heat. If you don't want to replace door switch you should be able to remove bulbs to shut off lights. I would try working door switch several times to see if it's just not closing all the way. Hope this helps. Thanks
Nov 15, 2010 | Maytag Refrigerator Light Switch -...
My refridgerator light will not light. New bulb,
you may have a bad door/light switch, stuck in a "closed" position
Feb 09, 2010 | Refrigerators
Light bulbs have been replaced but don't light
Hello Binfull,
Since you replaced both bulbs with new ones and they still won't illuminate, there is a high probability that the open door switch is not working or if you have a newer style refridgerator then in some models if the electronic brain for that model sensed the door has been open for too long, it will shut off the lamps.. Try this.. unplug the firge for a minute or two then plug it back in. Check to see if that 'power up clear' cycle got the lights to illuminate. Also, if your model has a freezer that has lights in it check to see if they go on. Hope that helps you.. Good luck...
Nov 29, 2009 | Maytag Refrigerators
LEFT TURN LIGHTS WILL NOT WORK ON 1993 TROOPER
believe it or not, a 4 way flasher can cause this even if it itself is working properly, otherwise flasher, bulbs, or switch is bad .
Oct 06, 2009 | 1993 Isuzu Trooper
Broken Light Bulb
Unplug the refrigerator first.
Then, try removing carefully the base of the socket with a pair of long-nose plier.
Dec 10, 2007 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
56 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
