Question about Polaroid FLM-3232 Television
FLM3232 HAVING PROBLEM WITH THE CONTROL BOX ASSEMBLY...DIFFERENT CABLE
You need a control box 909-kso-gf321xa about 400.00
Posted on Sep 24, 2008
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
Shows a 5E error code. Can you help?
SE means you have a shorted membrane keypad.
Actually the best overall solution to this problem is usually to order a new controller assembly (control box) and install it yourself. It's pretty simple.
We have a similar service manual and have uploaded it to our site here to help you.
Your part numbers may be different, so you can find helpful exploded views by entering your actual full model number at the Sears parts direct Web site here.
At Web site , they have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Apr 23, 2011 | Samsung SMH9187 Microwave Oven
I've been told I need to replace the control head to fix my AC problems. What's involved? Can I do it myself or do I need to get a mechanic?
Hi, in most cars it's much easier than in yours. I have pasted the procedure below from Autozone.com. Please let me know if you have questions. Also, I would be happy to confirm for you that you need a new panel if you can tell me the symptoms you are having.
Removal & Installation
  1. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
  2. Remove or disconnect the following:
    NOTE When the control panel assembly is out, it will have to be disconnected from the wire harness and control cables.
    Center panel assembly Front driver's side under cover Front passenger's side under cover Radio/tape/CD player Floor console Instrument panel center reinforcement Foot duct (LH) Control panel assembly
    Light bulb harness Defroster switch Air mix damper control cable Air outlet changeover control cable
To install:
  1. Attach control cables to control panel
    1. Set the air outlet changeover control knob on the heater control assembly to the defroster position.
    2. Set the air outlet changeover damper link of the heater/cooler unit to the defroster position as shown in the illustration, and then connect the cable to the link pin.
    3. Push the outer cable in the direction so that there is no looseness, and then secure it with the clip.
  2. Install or connect the following:
    Defroster switch Light bulb harness Control panel assembly Foot duct (LH) Instrument panel center reinforcement Floor console Radio/tape/CD player Front passenger's side under cover Front driver's side under cover Center panel assembly
Mar 24, 2011 | 2002 Chrysler Sebring
How to install a blower moter and fan
Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support.
BLOWER ASSEMBLY
Removal and Installation
1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly
2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure.
INSTRUMENT PANEL
Removal
1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl.
2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector.
3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel.
Installation
1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
Feb 28, 2011 | 1995 Isuzu Rodeo
I cant find the blower motor
If you mean the climate control blower motor, it's usually under the dash on the passenger side on Hondas.
1990-93 Accord
  1. Disconnect the negative battery cable. If so equipped, disable the Supplemental Restraint System (SRS).
  2. Remove the glove box.
  3. Remove the glove box frame (lower support) Fig. 2: Remove the glove box and frame 86806004.gif
  4. If not equipped with air conditioning:
    1. Remove the three screws and remove the heater duct.
    2. Remove the blower mounting nuts. Unplug the wiring from the blower motor, resistor and recirculation control motor, then remove the blower assembly.
  5. If equipped with air conditioning:
    1. Lift the carpet in the passenger compartment. Remove the side cover (kick panel).
    2. Remove the control unit bracket nuts; unplug the five connectors and remove the control unit bracket.
    3. Remove the retaining band, then remove the blower lower covers. Do not break the tabs on the lower covers.
    4. Remove the retaining nuts and remove the blower assembly. Fig. 3: Air conditioned models require the removal of the control unit. Handle it carefully 86806005.gif
      Fig. 4: Remove the lower covers from the blower unit 86806006.gif
      To install:
  6. Install the blower unit and tighten the retaining nuts.
  7. On air conditioned vehicles:
    1. Install the lower covers and the retaining band.
    2. Install the control unit bracket and carefully engage the wiring connectors to their proper location.
    3. Install the kick panel and reposition the carpet.
  8. Connect the wiring to the blower assembly. For non-air conditioned vehicles, install the air duct and tighten the screws.
  9. Install the glove box frame and install the glove box. Note that some of trim on the frame is held with 2-sided tape; replace the tape when reassembling as necessary.
  10. If applicable, enable the SRS.
  11. Connect the negative battery cable.
1988-91 Prelude
  2. Remove the glove box and frame (lower support).
  3. Remove the 4 screws and remove the heater duct. Fig. 5: The glove box and frame are secured by several small screws 86806007.gif
  4. Remove the 3 mounting bolts.
  5. Unplug the wiring connectors from the blower motor, resistor and recirculation controller. Remove the blower motor assembly.
  6. Reinstall in reverse order. Make certain the blower mating surfaces are tightly sealed.
Jan 08, 2011 | 1992 Honda Accord
I need a Service/Repair manual so I can replace the "control box"
http://www.audiolabga.com/pdf/FLM3232.pdf or you can buy one on EBAY....hahaha
Apr 21, 2009 | Televison & Video
FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Craig
Mar 16, 2009 | Polaroid FLM-3232 Television
My FLM3232 does not turn on at all. Does FLM3732 have same board
I had same problem, I fixed changing main board I found from FLM-3237 that used same part #, It worked perfect.
Feb 10, 2009 | Polaroid FLM-3232 Television
Flm 3232 polaroid
The power supply is only supplied with the control box. The control box is listed below.
Polaroid FLM3232 Control box with Power Supply
Jun 15, 2008 | Polaroid FLM-323B Television
Polaroid FLM-3232 Television Logo
113 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
