Question about Dryers
I have four wires, three screws. black, white, green and red. What goes where!! Thank you
  • 5,911 Answers
The following link explains how to properly install an appliance power cord:
If you still have questions, please let me know. I hope this helps you.
Posted on Aug 21, 2008
Had to put dfferent plug what is the order the wires go on dryerto plug
White goes to middle post. Red goes to post with red wire and black to black. Green goes to green ground screw around opening for terminal block.
Nov 12, 2017 | Dryers
Trying to wire a four wire power cord to a washer dryer stackable that only has three bolts to wire to
Green Wire hooks Screws into the case of the machine (Ground wire)
Red and black are powers wires and they go on the left and right screws. And the white wire is neutral which goes on the middle screw. Hope this helps.
Green to case, Red, White, Black
Apr 09, 2012 | Dryers
I have a maytag neptune dryer #MDE5500AYW and I am trying to convert from a three prong to a four prong connection. the four prong has a red, white, black and green connection. the old three prong, had a...
yes,hook up the black with the black the white with the white and the red where the blue was,now the green is just a ground wire,all you have to do is connect it anywhere to the metal frame of the machine just to ground it,look around there should be a screw somewhere near the other wire connections if not remove any screw and connect it and it will be fine.
Sep 04, 2011 | Dryers
Went from a three wire to a four wire dryer connection... what post does the red wire go on to? White, Black, or Green?
On the dryer , you have 3 terminals on the block . The red goes on one side , either side , the white goes in the center , and the black goes on the other side . Makes no difference on which SIDE the red and black go on . The white MUST go on the center terminal , and the green MUST be grounded by any screw screwed into the cabinet .
Nov 17, 2009 | Maytag PYE2300AY Electric Dryer
We have moved and the three prong cord now needs to be four prong
Ok here is how to hook up looking at dryer. Left brass screw is hot put red or black wire on. Center screw silver is neutral put white wire on. Right brass is also hot put the red or black wire on which one you have left. The green you ground to the dryer body or you can put with the white wire.
The reason why you have to hot wires is that it is a 240 volt dryer. Each hot wire caries 120 volts. The hot wires are the red and black. The white is a neutral witch is also a ground
I hope this helps. If you have any questions please ask before you rate.
Good Luck And Thank You for the post
Oct 20, 2009 | Dryers
I am changing out the wiring from a 3 wire to a four wire. The terminal block has (top to bottom) black, whiteandblue wires. The new 4 prong wiring has a white black green and red wire... what goes where...
The black,red & blue wires are your hot (120 volt) wires. Two of them get conn. to the two brass colored screws. The white is the neutral wire which conn. to the siver screw. The green wire is the ground wire conn. to the green screw which is the grounding screw.
Oct 06, 2009 | Dryers
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
How to hook up the outlet plug on the hot point dryers
white always goes in the middle!!!!!!!!!!!!!!,green on top on green screw,black on one side and red on a four wire outlet,on a three white in the middle!!!!! black on one side and red on the other-mike
Sep 21, 2008 | Hotpoint Dryers
White to center, red on Right, Black on left, Green goes to case or external ground screw.
Mar 26, 2008 | Dryers
Dryers Logo
Top Dryers Experts
