I have a Samsung HL-P4663W TV. Last evening we heard a pop and then the screen started to shrink in size and a loud buzzing noise could be heard. The indicator lights on the front panel indicate that the lamp needed to be replaced. I replaced the lamp with a Samsung replacement and still have no picture and aloud buzzing noise. Is it possible that the new lamp was defective, or could it be the DLP engine itself?
After much research, it became apparent that the most logical culprit after the lamp was the color wheel. It has been replaced and the set is working again.
Posted on Aug 22, 2008
Samsung model HLP4663WX/XAA with loud buzzing noise, need to know which part to replace.
See attached photo: you have a bad color wheel----it turns at about 12,000 rpm and bearings in the tiny motor go bad.
High pitched or fan like sound is classic symptom.
The wheel is available on the internet and You Tube has video instructions by model number for replacing it---Google the model number for the part number for your set to locate the part and instructions.
This for most people is a do it yourself job---takes like 45 minutes start to finish.
If color wheel slows too much set will shut down as its speed is monitored and the wheel can even shatter causing shutdown of the set.
Steve
Feb 28, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-P4663W/HL is making a buzzing noise
Color wheel needs replacement is the most likeliest cause.
Jan 02, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Our Samsung HL-P4663w television bulb, BP96-00608A(P), cracked and we just replaced it with a new bulb. When we turned on the TV all we got was a loud buzzing sound and no light on the screen. It is now...
You probably don't have the new bulb seated properly. Does the buzz last for about 5 seconds, quit for a little bit, and then repeat? If so, then it is the ballast trying to start the lamp but for some reason or another, the lamp is having a problem.
Aug 01, 2009 | Samsung Televison & Video
Poor picture quality and loud buzzing noise
Sounds like your color wheel is failing they make a loud sqeauling noise when they begin to fail.Run you somewhere around $300-400 to have a tech repair it.
http://the-tv-dude.blogspot.com
May 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLPTV bad picture and buzzing sound
You color wheel blew a bearing. You need to replace the color wheel.
Mar 28, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
168 people viewed this question
Top Televison & Video Experts
