Question about Akai LCT2721AD 27 in. LCD Television
Remote Wont fire up. Fresh batteries. Wont work universal either. Any suggestions??
  • ceabbott2 Sep 09, 2008
    Remote stopped working and no universal will work either. What is the ignition panel?
  • 1,800 Answers
Ignition panel burned try to change it
rate!!
Posted on Aug 21, 2008
Brought a CHUNGHOP H-6998E Universal remote and it was working and now it wont, tried to reset it but don't have the code, any suggestions.
Do the remote control work properly. Check it first. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV.If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/If the remote control is found OK; check and replace the infra-red sensor inside the TV.Contact any service technician.
Feb 27, 2015 | Universal Televison & Video
Correct code for universal remote will not turn off tv. On the 50" digital led model ELEFT502. Original remote always had a weak signal worked only when pointed a foot away from infared reciever. Then quit...
No universal remote control will work with any TVs as well as the original ones. If the original remote control do not get range, there are two reasons for it; and can be repaired to.
1. Battery weak [Replace with new batteries]
2. The infra-red light emitting diode at the front of the remote control is weak.[Can be replaced with a new one. It can be bought from most of the electronic spare part selling shops]
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Feb 06, 2015 | GE Televison & Video
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
Kross speaker remote no longer works. is there a way to fix it? if not will a universal remote be good for replacing it?
The remote may need fresh batteries. A universal remote may not be able to generate the codes required to control the speakers.
Jan 01, 2014 | Audio Players & Recorders
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
Romote will not turn t v on or off
if remote is universal remote, you will need to find the code to correspond with the maker of the television, most universal remotes come with programing instructions, check owners manual of tv for codes which now adays they include. Without the model number, i cannot help further, other than suggesting you try fresh batteries and make sure the sensors are clean on tv and remote.. best of luck
Oct 17, 2010 | Televison & Video
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
Wont power up via remote
Hello aadams64,
The photo diode might be defective in this TV. I would suggest that you get a schematic and voltmeter to measure the bias voltages and the signals involved in the use of the IR control. This will let you know if the control is working. I would suggest that you get a qualified TV technician to look at your set and troubleshoot it because of the possibility of damage that may occur if you should make a mistake while trying to troubleshoot the problem.
I hope this helps,
Thank you,
Shuttle83
Aug 21, 2008 | Akai LCT2721AD 27 in. LCD Television
Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Feb 07, 2008 | Proscan 26LA30Q 26 in. LCD Television
Akai LCT2721AD 27 in. LCD Television Logo
18 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
