Playing a downloaded film with HDMI cable to my TV set Sony Bravia, after 10 minutes the colour on tv set disappear or change. Do I need a certain drive on my computer for HDMI
  • William Miller
    William Miller Jun 21, 2011
    What computer are you using? What operating system? And is the HDMI built into the motherboard or a part of a video card that is installed onto the motherboard?
  • franco318 Jun 21, 2011
    I have HP laptop with window 7
    Scholar:
  • 83 Answers
If it was playing the video fine initially, there should be no reason for that to change. Most likely the video card on the laptop is overheating or dying, which results in the change in colors. I fix laptops at my computer repair shop, and most are HP Pavilion DV6000 and DV9000, and they are notorious for having bad video chips on the motherboards. If it is still under warranty I would back up your data from the hard drive then send it in to HP to have fixed or replaced. If it isn't under warranty I would try to connect your tv using just a VGA cable, and see if the same thing happens. If it does, you have a bad video card. If it doesn't happen then you may still have a bad video card, it's just that the VGA signal isn't as high powered/high resolution so your card doesn't get pushed hard enough to malfunction. Try the VGA cable and let me know how it works.
Posted on Jun 21, 2011
SOURCE:
I have purchased the apple component tv cable for my ipod 5th generation but when playing back videos I have only sound - no picture. I have set the Ipod to tv out, PAL (Aust) & connected all the...
Hi, this seems to be a physical failure with your connections and not your TV input configuration (as you're able to listen to your audio). First, try to see if there's an obstruction on your iPod dock (maybe some dirt or dust) and on your AV cable. As the video travels through different pins than the USB or power, you may've not noticed the failure until now. Sony Bravia TVs are all built in the same factory, so they can easily change from NTSC and PAL, try going to your settings and change the TV out to NTSC. If everything else fails, take it to your Apple Store, they'll be more than happy to test it for you and if it's broken, replace it for a working one.
--Dennis
Feb 27, 2011 | Apple COMPONENT AV CABLE (MB128LL/A)
I hooked up my tv,a sony bravia bx3 to my laptop using an hdmi cable which i disconnected from myps3 while it was still on,it worked perfect.suddenly the ps3 switched off.I re-connected my ps3 to the tv...
ok you have to reset the ps3 by turning of backswitch wait 10 seconds turn on the backswitch then press and hold down the front power button for 10 seconds you should hear 2-3 beeps that does it just wait and the video settings have automatically detected your tv settings and are going to ask you to save hit x to save display settings on ps3 remote problem solved. If you still get problem message me cause its technically bad.
Dec 15, 2010 | Video Game Consoles & Games
I have a Sony bravia 32" (KLV-32T400A) and have just bought an xbox.. On trying to connect it using the HDMI input an error comes up saying that it's not a supported signal. I also tried plugging my laptop...
All hd-ready tv's only support max 1080i and not 1080p. The default setting on the Xbox is 1080p, that's why you get that message. There is a way to fix this, just follow the steps below:
Connect TV and X box via HDMI cable with units switched off.
Switch both units on.
  1. Press the right arrow 7 times (Left top jog knob on game controller)
  2. Press "A" button 4 times (Green button)
  3. Press "up" arrow once to set to 1080i
  4. Press "up" arrow once again to set to 720p.
  5. Press "A" to store setting
Sep 12, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Jan 07, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Oct 11, 2008 | Televison & Video
SONY BRAVIA HIGH DEF KDL-26M3000
This TV is almost 8-10 yeas old, in that time the HDMI specification is not firmly set, the problem in most of the case is compatible problem. You may log in SONY website, try to up date the firmware; in other possibility that the main board may be bad.
Oct 27, 2017 | Sony KDL-26M3000 26 in. LCD Television
Shadowing on screen
You should get a good surge protector. Sometimes some areas have a spike in the power. That will cause interference in the TV signal coming from your PS 3. Try out different surge protectors that should solve your problem.
bimmerhp
Jan 23, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
104 people viewed this question
Ekse
Alun Cox
