Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Radio removal procedure
I need to know how to remove the deck to get at the wiring in the back, the vehicle came with the deck and no manual.
  • Anonymous Feb 01, 2009
    i have dim lights on my pioneer deh 1000 supertuner3 .how can i fix this and how does the deck come out ,it had no manual with it
    Problem Solver:
  • 51 Answers
We can help you.Welcome to contact www.playpower.biz
Posted on Aug 22, 2008
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
Pioneer DEH-2000MP Radio In 2001 Chrysler T & C
Make sure that the speaker wiring is correctly connected. Please see the instruction manual that would have come with the Pioneer deck for correct wiring instructions first. Check that first and let me know..
Jun 14, 2008 | Car Audio & Video
I need to know how to take the old stereo out of my 1999 buick regal to put in my new cd player? i cant figure out how to get the dash out
Hi, here is the procedure from autozone.com. Please let me know if you have any questions, and thanks for using FixYa.
Removal & Installation
  1. Obtain the THEFTLOCK® codes and radio station presets before attempting to remove the radio, if applicable.
  2. Disconnect the negative battery cable.
  3. Remove the trim plate bezel from around the radio using the following procedure.
    1. Adjust the steering wheel for access.
    2. Remove the ignition switch cylinder bezel.
    3. Remove the left side instrument panel fuse block access opening cover.
    4. Remove the instrument panel cluster trim plate screws.
    5. Starting at the right side of the instrument panel cluster trim plate, grasp the trim plate and carefully pull rearward. Continue working around the trim plate until all of the retainers are released from the trim pad.
    6. Detach the electrical connectors from the hazard switch and remove the trim plate from the vehicle.
  4. Remove the screws from the radio and pull the radio gently from the instrument panel.
  5. Detach the instrument panel wiring harness connector and the antenna cable connector from the radio.
Fig. You must remove the instrument panel cluster trim panel in order to remove the radio assembly
To install:
  1. Installation is the reverse of the removal process, noting the following:
    1. After the electrical connection is secure and the antenna cable is connected, find the radio locator tab.
    2. If the locator tab is difficult to align to the instrument panel locator opening, pull the radio towards you and reposition the antenna cable.
    3. Gently install the radio to the instrument panel, aligning the radio locator tab to the instrument panel locator opening while carefully pressing the radio into the instrument panel until fully seated.
  2. Install the trim plate bezel.
  3. Connect the negative battery cable.
  4. Unlock the THEFTLOCK® radio (if applicable).
  5. Program the radio stations back into the radio as recorded at the beginning of this procedure (if applicable).
Jan 28, 2011 | Car Audio & Video
How do you get access to the rear turn signal lights in a 95 dodge intrepid
From autozone.com. Please let me know if you have any questions.
  1. Release the trunk latch and open the trunk lid.
  2. Remove the fasteners holding the trunk lining to the lower rear deck panel.
  3. Separate the trunk lining from the deck panel.
  4. Detach the lamp wiring from the wiring harness.
  5. Remove the nuts that retain the tail lamp to the lower deck and quarter panel.
  6. Remove the tail lamp from the vehicle.
  7. Remove the socket and pull the bulb out if replacement is needed.
To install:
  1. Push a new bulb into place if required, then insert the socket into the lamp.
  2. Insert the wire harness through the hole in the lower deck panel.
  3. Install the wiring harness grommet into the lower deck panel.
  4. Place the tail lamp into position on the vehicle.
  5. Install the nuts to hold the lamp to the lower deck and quarter panel.
  6. Attach the wire from the lamp to the body harness.
  7. Place the trunk lining into position on the lower deck panel.
  8. Install the fasteners that hold the trunk lining to the lower rear deck panel.
  9. Check the operation of the lamp.
Nov 05, 2010 | 1995 Dodge Intrepid
Got panasonic cd-radio put in vehicle,it's playing but no sound
Did it ever play? Original mercedes vehicle had external amps and faders that were controled by the deck it self. If deck was removed most likely you need to install new speaker wire to the speakers.
Jun 11, 2010 | 1996 Mercedes-Benz C-Class
REMOVAL OF THE RADIO
Here ya go!
Exploded view of the radio, tape player or CD player removal, 1990-94 vehicles
  1. Disconnect the negative battery cable. Wait at least 60 seconds before beginning the remainder of the procedure, in order to disarm the Supplemental Restraint System (SRS).
  2. Using a plastic trim tool, remove the radio panel. Pry the lower part of the radio panel away first, then separate and remove the panel.
Using a plastic trim tool, carefully pry the radio trim panel away
Remove the center trim panel for access to the radio retainers
WARNING When removing and installing the floor console, do NOT allow it to bump against the SRS-ECU!
  1. For 1995-98 vehicles, remove the floor console assembly, as outlined in Section 10 of this manual.
  1. Remove the mounting bolts and pull the radio receiver, tape player or CD player out slightly. Detach all harness connectors and remove the unit from the vehicle.
After removing the console, unfasten the radio mounting screws
Pull the radio out enough to access the connectors
Unplug the electrical connector from the rear of the radio ...
... then disconnect the antenna lead and remove the radio from the vehicle
Installation is the reverse of the removal procedure.
Oct 29, 2009 | 1992 Eagle Talon
How to....remove radio sepakers (rear) from a toyota echo??
It's really easy to remove the rear speakers. First, get in the trunk and find the 3 white anchors for the rear deck-they're near the rods for the trunk mechanism. Push them through the metal frame to free the deck. Next, you have to get in the back seat and remove the stop light from the deck. To do this, push in the pins on the locking mechanisms on either side of the light to free the back casing. Pull the pins out and the casing off. Next, undo the two bolts holding the stop light in place and pull it off-don't forget to undo the wiring harness. Next, find the three anchoring points for the back seat. Gently lift the two side ones free of their anchors. This gives you access underneath the deck. Free the deck and gently lift it over the seat. You'll have to jimmy it a little to get the locking clamps free--they're all along the back of the deck. Pull it free and you have access to the speakers. I believe the factory speakers are 5 1/4 inches
Try to use Toyota speaker adapter plugs so you don't need to cut wires and mess the electric system up. You can get them from Ebay or Amazon.
cheers
Oct 14, 2009 | 2000 Toyota ECHO
Removed aftermarket radio from 1999 Wrangler, no gauges work now
first, you have to tape any open wires with electrical tape, so they DON"T short anything out again. second, check your gauge fuse.
Dec 04, 2008 | 1999 Jeep Wrangler
Removing front and back speakers in 1991 Grand Am....
There is a lot involved in replacing these speakers. You should also know that the original factory speakers are 10 ohm speakers. This means that if you replace them with new speakers (most of which are 4 ohm) you run the risk of damaging the stereo, the speakers, or both. This can also cause a potential fire hazard in your car. If you want new speakers, you really should look at installing a new stereo as well.
To get to the back speakers, you will need to remove 2 bolts located under the front edge of the rear seat (bottom). After you remove the bottom, you will need to remove the rear seat (back). This involves removing the bolts that hold down the rear seat belts, which is a large sized torx bit (T-45, T-47, or T-50... Don't remember which). After removing these, lift straight up on the seat back to remove. Now remove the deck brake light housing, and the bracket that holds it. Now the deck cover can be removed. Be careful not to bend it too much getting it out from under the side trim on both sides.
For the front speakers, you must disassemble a good portion of the dash. Remove the screw holding the light switch and the wiper switch housings. This screw is underneath each housing. Once removed, there are dash mounting screws behind them. These screws (and many of the other dash screws) are a smaller torx-bit (T-10 or T-15, don't remember which). Sometimes they use a 7mm bolt. There is a cover panel just above the glove box. This panel is held on with 2 screws located in the glove box. After removing this panel, you will find 2 or 3 bolts holding on the dash. Last but not least, you will find 2 bolts inside each of the defroster vent grilles. These grilles just snap out for easier access to the bolts.
1991 Pontiac Grand Am Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4" Round
Car Audio Front Speakers Location: In Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6" x 9" Oval
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Nov 30, 2008 | 1991 Pontiac Grand Am
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
96 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
