Question about Canon Office Equipment & Supplies
Please advise what might be wrong with my printer S400. All of a sudden it decided not to print. I have cleaned it several times and it still will not print. Is it "dead" or can yoy help me? Thanks. [email protected]
  • wobrown2007 Aug 21, 2008
    Sorry, but I'm not satisfied with your answer. Canon should do better than that. What would it cost me to get it into working order?
  • Canon Master
  • 6,487 Answers
Check first if the printer is working properly, then after that turn the power off of the printer to about a munite, then try to print if still not working, update the printer software..
Hope that helps..........
Posted on Aug 21, 2008
    Master:
  • 521 Answers
As its the problem of no power replace the power supply wire you are using and see if it works.if still not getting it worked.then its inter circuit board problem.repairing that would cost you more than new printer.so dont repair it and waste your money.its a scrap.buy another hp printer.as this problem in the hp printers can be solved quiet cheaply.as the spare partys are easily available.thanks.please rate the solution.
  • Canon Master
  • 19,396 Answers
Try firs unplugging printer from usb and from power for five minutes.
  • Ginko
    Ginko Aug 21, 2008
    then do the following:
    • Unplug printer USB from computer.
    • Uninstall printer from 'installed printers' in Windows Control Panel.
    • Insert printer disk or install drivers after download from Dell website here :
      Drivers and Downloads
    • Run printer drivers setup wizard and follow instructions.
    • Connect printer when asked by setup wizard.
    This should fix the problem, unless printer is faulty
  • Ginko
    Ginko Aug 21, 2008
    Check also that the cartridge is not empty, or faulty, try an alternative set of cartridges.
SOURCE:
Installed new black cartridge - had ink
A firmware update for your model addresses the print quality problem that you're currently experiencing. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Should the error continue to display even after successfully updating your printer, please contact Lexmark Technical Support Center for additional assistance. Your printhead itself might be the cause of the problem.
Feb 17, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Will not receive faxes/sends faxes but no print on the page
A firmware update for your models addresses the issue where the printer is having trouble printing out any colors. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
After successfully updating your printer, run the Deep Clean Printhead function on your printer. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead.
Then try printing a document again to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Feb 15, 2012 | Lexmark Office Equipment & Supplies
Printer-printhead replaced but paper is coming out blank
Make sure that your printer's firmware is up-to-date. The firmware update for the Lexmark Interpret S405 printer addresses print quality issues. Please visit the Lexmark website to download and install Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
After updating your printer, please run the Deep Clean Printhead one time. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead. Your printer will then print a page forcing ink through the cartridge nozzles and clean them.
Then try to print your document again to verify that the problem is fixed.
Nov 30, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Hi dear friend i have brother mfc-240c that cyan color work good since last day. but suddenly don't work today. i cleaned several time but no result. please help me thanks a lot.
Inkjet printers needto be used frequently to prevent ink drying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to
May 19, 2011 | Office Equipment & Supplies
Soon after initiating printing, Canon s400 printer stops with a loud clunk. This produces Error 5100. Turning off and on again does not help.
Hi You can Try
Error Code 5100 This happens lots in caon
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 13, 2009 | Canon S400 InkJet Printer
Won't print red color
push and hold the power button for 35 seconds this will reset the color fill it should work
Dec 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Canon s400 printer w/new cartridge
Dear aunder,
Did you mean print blank in black nozzle?. Please compare with another cartridge if you have. Is the problem still persist?. If it so, the problem can be caused by purge unit of the printer not function properly (purge unit cannot **** the ink from the cartridge). Hope this will be useful for you.
Regards,
Dec 02, 2008 | Canon S400 InkJet Printer
CANON S400 PRINTING PROBLEM
What printer do you have? Clean heads, clean heads, clean heads, etc. Then do the test print to see if the heads are open. I had similar problem with an Epson, had to clean the heads often, finally got to where the heads wouldn't clean so threw it away and bought another one (HP this time, the heads are included in the ink carts, haven't had to clean the heads at all.)
Nov 02, 2008 | Canon S400 InkJet Printer
Open Questions:
Clive
Clive
old marine
old marine
Ekse
