Question about Acer Aspire 3100-1405 Notebook
My acer screen monitor will not turn on
What does it mean if my acer laptop screen doesn't want to show but the power is on and when it starts it beeps.how do i fix it.
  • wolverine10 Jan 17, 2009
    my acer 17" lcd screen is workin but you can not see any images. the power button just kept on blinking.
  • Acer Master
  • 1,800 Answers
Display card burned change it
rate me fix ya
Posted on Aug 21, 2008
2 Suggested Answers
SOURCE:
Norisil
  • 139 Answers
SOURCE: My acer aspire one notebook
Perhaps you've built a computer and are turning it on for the first time, or you've owned this computer for awhile. Either way, you may encounter an issue where the monitor shows a black screen and the computer is beeping. There are several causes and solutions for this problem.
1.Refer to your motherboard manual, since the motherboard is the beeping device. These beeps are like Morse code, and each "beep code" is explained in the manual. Common beep codes include not having a monitor or keyboard properly connected; not having a CPU fan connected, or not attaching internal power cables to the video card. This black-screen-and-beeping issue is most common with newly-assembled computers.
2.Check external cables to make sure they're properly connected. The most important external connections to check are the monitor's signal cable and the keyboard. If your monitor cable looks damaged or kinked, try replacing it with a spare. If your keyboard's cable looks frayed, try a spare keyboard.
Also, a PS/2 keyboard plug (round, with holes in it, about the diameter of a finger) is often color-coded purple. If you have plugged it into the green port in the back of the computer (for PS/2 mice) switch it to the other one. If there is no color coding, the proper port should have a small, embossed icon of a keyboard on the back of the computer. If it does not, refer to your motherboard manual for the correct port. If all else fails, try a spare keyboard, preferably USB (Universal Serial Bus), which can be plugged into any USB port on the back of the computer.
3.Check for additional motherboard power connections. Yours may require multiple cables attached from the power supply. There is the standard wide plug, which you know is connected properly because your motherboard is beeping. However, there may also be an additional, four-pin cable that connects elsewhere on the motherboard. Check the board's manual to make sure it has all the power connections it needs.
4.Check your internal cables. Make sure that the CPU fan is plugged into the motherboard header nearby. Without that, the CPU fan will not spin, and the motherboard may detect this lack of connection and produce a beep code. Your video card also may have one or two internal power plugs that need to be attached to the power supply's cables. These cables have unique ends on them, similar in shape to a USB plug. Refer to the case or video card documentation if need be. If those cables are not attached, your motherboard may refuse to boot the system.
Your video card may be faulty. If this is a new card, it may have arrived to you broken, in which case you will probably need to request an RMA (Return to Manufacturer Authorization) to receive a replacement. If this card was previously working for you in this system, you can contact its manufacturer yourself to receive a replacement, if the device is still under warranty.
I hope you find it very helpful.
Posted on Aug 25, 2011
My Acer LED monitor is black unresponsive and has an unchanging purple power button. What is causing this and how can I fix it?
no PC stated,
and what does this mean.
"showed nothing."
2nd monitor ,did it work on not? please be clear.
I guess you mean the 2nd monitor works on this unstated PC.
but not the 246 ,as it is dead. or shows odd things? no photos off odd presented,
246, is 6 years old today.
ok , PC dead, but is it silent, it must blow 2 fans desktop.
ok, does the GN246HL fail on other PCs.
if not it is good.
if yes,it is bad, simple no?
all test monitor directly to a PC, DVI jack.
this monitor is only 6 years, old and is LED backlighted
what does this mean?
Dual Link DV-I.??????????
this monitor has only one DVI port (and vga , and HDMI)
now test 1.
NO pC connected
power on the monitor,
it shows LOGO sign , ACER logo message seen for 6 long years but today is dead.
Now turn it on again and push menu button, on monitor.
you get OSD screen windows, from the monitor brain and it works
and looks good , but only for 10 seconds at power on.
the 10 second rule on OSD, means you must do that fast.
the controls are in the manual
page 22
https://www.manualslib.com/manual/380485/Acer-G246hl.html?page=19#manual
May 13, 2018 | Acer Computers & Internet
Why does my acer aspire one not boot with a hard drive besides the screen going white when connecting the charger?
If you can plug an external monitor into the laptop, and if it works ok, the video on the laptop is going bad (chip or cable). If an external monitor works, I recommend you back up your data asap, if possible to an external hard drive. No way of telling how long before other things go wrong, and the price of fixing it might cost more than getting a new laptop.
Jul 19, 2014 | Acer Aspire Computers & Internet
Black screen
first check your display in monitor with the help of vga cable attach your laptop in the monitor,if display comes in the monitor it means your screen faulty .or if display cant seen on monitor it means there is an fault on MOTHERBOARDS BGA CHIP.
Jan 29, 2014 | Lifetime Acer Aspire 4736Z Replacement...
Laptop wont start.
Remove the battery and unplug the power cord for 5 minutes, put in the either the battery or the powercord and power on.
if it doesn't power on, make sure the charging light is lit on the front of the laptop when the power adapter is inserted and plugged in properly.
light blinking when you power on means battery low / no power.
If the problem doesn't go away you need to contact acer for warranty service if you are outside warranty contact a local repairer.
Jul 20, 2012 | Acer Extensa 5420-5687 Notebook
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
My acer aspire one laptop screen is completely white how can i fix it
Power down the laptop (press and hold the power button).
Try turning it back on, and hitting the F8 key to get boot options. Start in "Safe Mode" or some other configuration that worked and see if that fixes the issue.
If the screen does not show anything at all, try connecting the laptop to an external monitor while starting up.
Apr 15, 2012 | Acer Aspire One PC Notebook
Laptop screen is not showing anything after power is on
if the power is on and the screen does not show up , try to hook an external monitor using the VGA cable. If the screen does show up, it means that the problem is in the laptop LCD monitor itself. Otherwise if the external monitor does not show up, that means your laptop does not boot anymore to the operating system. Try to turn off the power and remove the power cable and battery on the laptop. Then press and hold the power button for 8 secs. Then reinsert the battery and power cables on the laptop then turn on the laptop. If there is still no screen displayed then call Lenovo for repair of your laptop.
Oct 22, 2010 | Lenovo 3000 C200 Notebook
When I turn on the aspire one note book it goes to a white screen and will flash once and go to white screen and stays there, owver all other lights on the panel flash normal, but will not boot up. this is...
If you're still under warranty, you can diagnose one possible problem easily enough. Blank white screen with the LED indicator lights running normally otherwise will almost always mean that the LCD panel is bad. If you don't have an external monitor available, find a friend with one and hook up the laptop to that monitor. Be sure to have the laptop power off when you attach the monitor cable. Press the power up button and then the Fn+F? (whatever F key has a little icon on iyt showing a monitor) combo to switch to an external monitor. If your laptop's Operating System shows up on the monitor, you know for certain it's jus your LCD panel that's bad and you can ask the manufacturer to replace it.
Dec 05, 2009 | Acer Aspire One PC Notebook
Monitor on Acer staying gray
have you tried to the "function+8" (or the number to transfer the signal to a monitor) when you are on the laptop with grey screen?
Did you said that grey, means that there is light on the laptop, but no colors, or that tha screen is not turned on?
Jan 09, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3100-1405 Notebook Logo
157 people viewed this question
Ekse
Alun Cox
