Question about Maytag Portable Air Conditioner M6P09S2A
Leaking in the maytag m6p09s2a*b
I have the maytag m6p09s2a*b and I believe the top tray is not draining... My carpet is soaked but I don't see where the a/c is leaking from. When I try to drain the bottom tube, a little bit of water comes out. I've opened up my unit and can see that the top tray is filling up with water. Is there a way to drain this? Is there maybe a blockage because I can't find where the top tray is supposed to drain to?
    Novelist:
  • 166 Answers
Do you have the Manual to read the trouble shooting page?
How old is the unit?
If not here is a web site to acquire the manual
http://homeappliance.manualsonline.com/ex/thread/view/idThread/326907
Bless you ngafm Waiting for you answer!
Posted on Sep 07, 2008
SOURCE:
Old Maytag portable AC leaking. an hwar water when I move , don't know how or where to drain
Make sure the drain line is not stopped up and that the drain pan is empty. The pan relay on the heat from code see to evaporate water and with a full pan that isn't going to happen. Drain line or pan full.
Jun 05, 2016 | Maytag Heating & Cooling
Getting wet
The divider is generally not sealed at all, just a lump of metal reinforcement, the coolant may have pooled at the rear. The water will evaporate from the coolant mixture but the coolant will stay a long time so it'll have to be vacuumed out, add water and vacuum some more to pull it from the carpet and padding as much as possible. You can verify whether it's coolant or just rainwater by smelling the carpet. You may be nose blind to it by now from driving the car so have someone else sniff the carpet if you don't detect any coolant smell yourself. It'll also feel more slick than straight water if it's coolant so that's another way to ID the liquid. Option three is a cat or dog, they'll likely try to lick it if it's coolant but don't let it clean the carpet for you unless you dislike the animal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Mar 07, 2014 | 2006 Ford Focus ZX3
Buick passenger side front and rear carpets soaking wet
The two most common causes are rain water leaking in or the ac drain being clogged up. I would vote for rain water if the entire carpet area is wet.
Could be coming in around the windshield, or one of the door gaskets.
Feb 22, 2014 | 1996 Buick Park Avenue
Air conditioner drain box
Hate to say it,but usually this requires removal and replacement of the entire a/c heater box for new gasket (and any extra sealer needed.) It is quite a job. Also, have had extended cab pickups with leaky door seals at top keep the carpet underlay soaking wet.
Aug 26, 2012 | 2006 Chevrolet Silverado 1500 2WD
WATER CARPET SOAKING WET
Coolant? your heater core may be leaking. Or A/C drain blocked. Unblock the drain first & check radiator is at correct level when cold.
Jul 09, 2012 | 2005 Mercedes-Benz C-Class
Needing the hose attachment to the window kit
I believe you'll find what you need at the following link. http://www.appliancefactoryparts.com/airconditioners/maytag/m6p09s2a.html If you can't find it there, try Sears Parts Direct.
I hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Maytag Portable Air Conditioner M6P09S2A
Maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
Oct 10, 2009 | Maytag Portable Air Conditioner M6P09S2B
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Model M6P09S2A Maytag Portable Air Conditioner/Manual?
I have the M6P09S2A Portable unit that is leaking water everywhere. I have to place it in a large bin to keep it from draining on the floor. Any solutions?
Jun 29, 2009 | Maytag NMPEB08F2A Air Conditioner
Heating & Cooling Logo
1,623 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
