Question about Apple iPod touch
Can u help me
My ipod touch is diabled and locked but i cant get to a screen on the ipod to unock it and i do not even know teh passcode
  • Apple Master
  • 13,433 Answers
Read this page for instructions on how to force the itouch into RECOVERY MODE
http://support.apple.com/kb/HT1808
then you can perform a restore to remove the codes and restore it to the original status
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Aug 22, 2008
My i pod is diabled how do you able it i need help can you help me
If your iPod is disabled from a passcode that is entered too many times you'll want to follow:
http://support.apple.com/en-us/HT1212
It will instruct your to put your iPod into recovery mode to do a restore to factory setting (this will erase the iPod).
If you have a backup available, that doesn't have the passcode in it then use:
http://support.apple.com/en-us/HT203977
Be warned that if the passcode is on the backup and you do not know the code, then you will be back to square one and have to restore it to factory settings again. Good luck!
Oct 02, 2014 | Apple iPod touch
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
How to unlock it
How to Unlock an Apple iTouch
Although locking your iPod Touch prevents accidental touch commands, the feature also prevents you from accessing your media and applications while the device is locked, according to the Apple site. The lock code is the 4-digit code that was created when the passcode lock was first enabled, and displays a passcode menu prompt on the iPod Touch's screen when the "Home" or "Power" button is pressed and the unlock bar is slid across the screen.
Instructions
1 Push the "Home" button on the iPod Touch's screen, or push the "Power" button on top of the device to show the home screen.
2 Slide your finger on the iPod Touch's unlock bar.
3 Enter the 4-digit passcode using the on-screen keypad to unlock the device. If you cannot remember the passcode, plug the dock-connector cable into the iPod Touch and plug the other end into your computer's USB port. According to Apple, the iPod Touch will automatically unlock after it is connected to your computer.
Jan 07, 2012 | Apple iPod touch
My ipod touch is diabled and itunes wont let me see it til i unlock ut
if you put in the 4 digit passcode wrong six times, it locks up, and wont let you do anything on it for 1 minute. if you get it wrong again, it will lock up for 5 minutes. each time after that, it locks up for longer and longer, until it reaches an hour. after that, everytime you get the passcode wrong, it locks up for an hour
Dec 01, 2009 | Apple iPod touch
My 8GB ipod touch is disabled
You need to put in DFU MODE, and restore your ipod touch.
Easy:
Press The Home Button + power button for 10 seconds. after 10 seconds, press only the Homme button.
And now, connect your ipod touch on itunes and press RESTORE.
Jun 28, 2009 | Apple iPod touch
My ipod touch is locked and disable i dont know how to unlock it
  1. Connect the iPod to your PC using a USB cord.
  2. Open iTunes.
  3. Click the Options button in the lower right corner of the iTunes window.
  4. Click Enable USB disk use. (sometimes optional)
  5. Go to "My Computer" and select your iPod.
  6. Select tools and the folder option.
  7. Select the "view" tab.
  8. Select "Show hidden files and folders".
  9. Search for the file (file name differs in earlier versions) but on all models it will be located in the "Ipod_Control" folder aka Settings
  10. Look in a folder that is sometimes called "Device" find a file named "_locked".
  11. Change the file name "_locked" to "_unlocked".
  12. and listen to the good old tunes"
From
wikiHow
Check also
Unlock iPod Screen "
Sep 17, 2008 | Apple iPod touch
Apple iPod touch Logo
91 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
