Question about Olympia Mastertype 3 Typewriter
My typewriter is not typing correct letters on keys pressed. The Print Wheel locks in correctly.
  • Anonymous Mar 23, 2014
    the typewriter does everything but type, the key makes a beep noise but does not print the letter onto the paper. Have read the manual but cannot find the answer
  • Anonymous Mar 25, 2014
    The typewriter types different characters than the keys hit in all pitches. The daisy wheel says pica 10. How can I get the typewriter to type the correct keys for that pitch?
Excellent !! This fixed my issue !
Posted on Oct 29, 2008
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Posted on Sep 02, 2008
How can i use the eraser?
I'm not sure exactly what your problem is but if you type a wrong letter press the correction key on the R. side. The key has a "X" inside an arrow pointing left.
Go to NADIST.com click on current models one of the Nakajimas will be the same as yours.
DickyO
Sep 19, 2011 | Olympia Mastertype 3 Typewriter
My olympia mastertype 3 typewriter,does not print the key I am typing. Please give me an idea of what to check
On the L. side of the keyboard is the pitch slide switch be sure that it isn't in PS, if it isn't S'slide it up and down a few times they do get dirty.
DickyO
Jul 25, 2011 | Olympia Mastertype 3 Typewriter
Typewriter types different letters and symbols when pressing ALL the keys to type. How do I reset it to the original setting?
The pitch selector switch on the L. side of the keyboard should be in 10 or 12 not PS. Also press down on it and slide it a few times they do get dirty.
DickyO
Jul 05, 2011 | Olympia Mastertype 3 Typewriter
Changed print wheel (same type as previous) now typing letters incorrectly
Check the "Pitch" selector slide switch on the lhs of the keyboard... it should be on 10, 12 etc position to match the printwheel... NOT in the PS position.
Sep 23, 2010 | Olympia Mastertype 3 Typewriter
Ribbon does not advance but wheel does turn when
You are in the overstrike ribbon mode. Code and Period, comma, or slash will get you out of that mode.
DickyO
Jul 26, 2010 | Olympia Mastertype 3 Typewriter
Correction key problem
To correct press the correction key just above the ret. key. If you are passed the error backspace to it and press the corr. key.
DickyO
Aug 04, 2009 | Olympia Mastertype 3 Typewriter
Where is the correction key on the olympia mastertype 2?
The correction key should be right above the return key.
DickyO
Aug 03, 2009 | Olympia Mastertype 3 Typewriter
How to install Nukote 86TL Correct type in olympia master 3 typew
If you need the operators manual go to www.nadist.com for a Nakajima manual...they are the same as the Olympia models.
Apr 28, 2009 | Olympia Mastertype 3 Typewriter
Printing incorrect letters
Check the pitck selector slide switch it may be in PS this will give you that problem.
DickyO
Apr 06, 2009 | Olympia Mastertype 3 Typewriter
Erase key
When you press the correcton key it should backspace and lift off the print, if it makes the movement and dosen;t correct check to be sure you have a correctable ribbon (orange or yellow knob), be sure the correction is installed properly dull side facing the paper.
DickyO
Jan 22, 2009 | Olympia Mastertype 3 Typewriter
Olympia Mastertype 3 Typewriter Logo
471 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
