Question about APC Back UPS 650 (APWBK650MC) UPS System
APC Back UPS Pro 650
When we opened the unit, we saw considerable rust on the door to the battery compartment and in the compartment itself. Is it possible that the RBC4 battery leaked even though it's advertised as leakproof?
Also, ince it doesn't look like the rust has damaged the unit itself, can we just clean it up the best we can and input a new battery? The terminals are not rusted.
Since the unit is not rusted ,its clear that it is OK!when battery leaks,it loses power,so is not harmfull to unit.replce the battery and keep rollin!
Posted on Dec 28, 2008
My apc back ups es 650 has a continous chirp what doe that mean?
the chirp means a power event has occurred and the unit needs reset to continue operation , power events can be a few things ( to large a current was applied as a load to it , the power stayed off till battery failed and it had to charge it back up when power comes back on )
Apr 29, 2014 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
Apc 650 back-ups does not boot
try turning on the power connection
Mar 22, 2013 | APC Back-UPS Pro 650 UPS System
Need information
The Back-UPS is fairly straight-forward. The 9-pin connector (at the top of the back) is a serial port (RS-232) for the UPS data (when connected to a computer it will shut down the computer safely during a power outage). The next plugs are RJ-11 telephone jacks; the cord from the jack (wall) goes in on the left (some models have RJ-45 for network protection). The battery protected outlets are the three surrounded by black paint. The other three provide surge-protection only. Do not plug items like printers and scanners into the outlets that provide battery protection.
I hope this helps.
(for software, manuals and other information:
http://www.apc.com/products/resource/include/techspec_index.cfm?base_sku=BP650S&tab=models )
Apr 17, 2010 | APC Back-UPS Pro 650 UPS System
APC BACK-UPS PRO 1100VA 120V does not cold start.
When was the last time you replaced the batteries? These units will not start with old / failed batteries connected, or without batteries connected.
If you have a voltmeter, check the batteries. Your unit should have two batteries harnessed together. if you check the individual battery, you should see just over 13 volts, together should be around 26 volts. if you see less than 12.5 volts, that would be why the unit will not start.
You will have to replace the batteries if that is the case. Your BP1100 takes an RBC 7: moz-screenshot-1.pnghttp://www.refurbups.com/APC-RBC7-Compatiblemoz-screenshot.png
Apr 14, 2010 | APC Back-UPS Pro 650 UPS System
My ups is back-ups cs 650. How to auto turn on this ups?
yes connect the serial cable came with the ups from serial port to ups there is again one serial port to ups the insert the cd came with ups and install it then it will auto turn offf before battery bown
Mar 02, 2010 | APC Back-UPS Pro 650 UPS System
Problem with APC Pro 420
If the unit works ok on mains power, then it is the usually the batteries causing this, New battery i think you need.
Sep 17, 2009 | APC Back-UPS Pro 650 UPS System
Back ups battery rpo1100 APC disconnects the Dell PC power button
try plugging the pc directly into the wall...if it works the UPS is defective.  You can order new batteries for the UPS online.
Battery Planet.com
Mar 13, 2009 | APC Back-UPS Pro 650 UPS System
Apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
Feb 24, 2009 | APC Back-UPS Pro 650 UPS System
APC Back UPS 650 (APWBK650MC) UPS System Logo
164 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
