Cars & Trucks Logo
Posted on Jun 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wat can I do to get better gas milage in my 1989 chevrolet Corvette without droping horsepower or torque?
  • cheap repair Jun 21, 2011
    better air filter & cold air intake, free flow exhaust. higher tire pressure. tuned engine.
robert wales
Level 3:
  • Chevrolet Master 4,977 Answers
  • Posted on Jun 21, 2011
robert wales
Chevrolet Master
Level 3:
Answers
4977
Questions
0
Helped
1330252
Points
59541
You don`t say what if anything you did to increase horsepower.if you have done a mod to the motor then there probably is nothing you can do as more horsepower requires more fuel to be burnt to run properly.if not then you can try changing the thermostat as if its not working properly it can have an effect on gas mileage also a bad coolant temp sensor can have the same effect.you may have to change your driving habits,no jackrabbit starts from a stop and not braking till the last second.constant revving of the engine anything you do that causes you to push on the gas pedal will result in more fuel being used.even driving above 60mph(100kil) will cause more fuel to be used.what about tune-up has it been awhile.
Terry Reimink
Level 3:
  • Chevrolet Master 458 Answers
Terry Reimink
Chevrolet Master
Level 3:
Answers
458
Questions
0
Helped
116778
Points
1367
Make sure the engine is properly tuned. Check tire inflation. Accelerate slowly. Anticipate stops. Probably not what you wanted to hear when your driving a Corvette but there are no magic solutions.
1989 Chevy Corvette. Changed 4 fuses now car won't start but lights come on?
Question edited for clarity.
Question moved to Corvette sub category.
Removing one of the fuses disconnected the anti theft module.
https://www.google.com/search?q=1989+Chevy+Corvette+reset+security
1helpful
What is the engine power of the truck Chevrolet C 50 of the year 1969 ?
Gasoline Engines
The 1969 C50 pickup truck was available with three different gasoline engines, including a 292 in-line six-cylinder engine that produced 170 horsepower at 4,000 rpm and 275 foot-pounds of torque at 2,400 rpm. Other engine options included the 350 V-8, which output 200 horsepower at 4,000 rpm and 325 foot-pounds of torque at 2,000 rpm, and the 366 V-8, which generated 235 horsepower at 4,000 rpm and 345 foot-pounds of torque at 2,600 rpm.
Diesel Engines
Customers that were interested in a diesel-fueled 1969 C50 had a choice between the Detroit Diesel (4-53N) engine, which offered 130 horsepower at 2,800 rpm and 278 foot-pounds of torque at 2,000 rpm, or the more powerful Toro-Flow Diesel (DH478) engine, which output 165 horsepower at 2,800 rpm and 337 foot-pounds of torque at 2,000 rpm.
1helpful
What is the power of the engine in hp of the chevrolet corvette 1959 ?
Type ohv V-8 ohv V-8 ohv V-8 ohv V-8 ohv V-8 Displacement, liters/cu inch 4.6/283
4.6/283 4.6/283 4.6/283 4.6/283 Bore x stroke, inches 3.875 x 3.00 3.875 x 3.00 3.875 x 3.00 3.875 x 3.00 3.875 x 3.00 Fuel Management 1 x 4-bbl. 2 x 4-bbl. fuel injection 2 x 4-bbl. fuel injection Horsepower @ rpm 230 @ 4800 245 @ 5000 250 @ 5000 270 @ 6000 290 @ 6200 Torque @ rpm, pound-foot 300 @ 3000 300 @ 3800 305 @ 3800 285 @ 4200 290 @ 4400
My 1989 Corvette has trouble starting the first couple times I turn it over
Sounds like your losing fuel pressure i would check your gas cap first.
Im looking for a spark plug wirng diagram for a 1966 corette 427
1966 - 1969 with 4 Barrel Carb (L36)
(Low Compression Model)
Max Brake Horsepower - 390 @ 5200 rpm
Max Torque - 470 @ 3600 rpm
Stroke - 3.76
Bore - 4.251
Compression - 10.25
Firing Order - 18436572
1966 with 4 Barrel Carb (L72)
(High Compression Model)
Max Brake Horsepower - 425 @ 5600 rpm
Max Torque - 460 @ 4000 rpm
Stroke - 3.76
Bore - 4.251
Compression - 11.0
283, 327, 396, 409 and 427 CID Engine 1965-1966
Firing Order 1-8-4-3-6-5-7-2
350 CID Engine 1969-1974 Corvette, 427 CID Engine 1969 Corvette
Hope this helps (remember to rate this answer)
Just wondering how much horsepower and torque a 383 stroker engine with a 4.030 bore, 3.75 stroke with a 278 crane cam with 222 degree at .050 inlift .470 lift, port and polished gm heads with 2.02 intake/...
I would guess you would be very close to the 1 horsepower per cubic inch ball park with very comparative torque figures, but...so much depends on how well the fuel mixture and ignition timing is set up. The port and polish work is also very important, bigger isn't always better, it's the shape that matters. Smooth ports actually flow worse than ports with an even cast surface. It's the protrusions and transitions that matter the most, not the surface.
On the dyno, at the rear wheels, I say about 290 hp and 300 torque with good gas and the timing optimized. This may sound weak, but it is an impressive real world repeatable attainable goal in my opinion. Peak numbers at the crank would be far higher, but driveline loss is huge, and so subjective because of tires, trannys and gears.
2answers
The car is running poorly and missing when hitting the gas pedal
Give it a good tune up. Change the cap and rotor, plugs. Make sure that the plug wires are in good shape and not broken from heat.
My engine wont rev on kickdown 1989 corvette
your torque convrtoer is shot. it is the at the front of the tranny to transfer motion from fly wheel ( engine side) to the trans. its a fairly cheap and easy fix.
Did the 1981 corvette offer a 230 HP engine or just the 190 HP
Engine Specifications
Type ohv V-8
Displacement, liters/cubic inch
5.7/350 Bore X stroke, inches 4.00 X 3.48 Fuel management
1 X 4-bbl. Horsepower @ rpm
180 @ 4,200
280 @ 1,600
Published Performance Numbers
Acceleration 190 hp, 4-speed manual
0-60 mph, second
8.1
0-100 mph, second
NA
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
