Question about Dual Sew 3400 Mechanical Sewing Machine
Singer Quantum XL 3400
I have a singer Quantum XL 3400. Every so often when I first start to sew, after 2-3 stitches there will be a loud clang and the needle will jump to the right and there will be a clob of thread underneath the material. Right now I am sewing small squares together to make a quilt square. This will occur every 6-8 starts. It only occurs during a start and never occurs if I am sewing a long seam. The tension seems correct as the top and bottom stitching lay flat and snug to the material. I have checked the threading of the machine and the bobbin and they are correct. I took the plate off and the bobbin holder out and cleaned the area. What could be causing this? What else can I do?
  • 323 Answers
SOURCE: i have an 1130 bernina
The 1130 does not have a consumer adjustable presser foot. Check to be sure you are using the correct presser foot .Some feet are slightly different in height which is how the pressure is regulated. If this is not your problem it will need to be seen by a technician.
sewman7
Posted on Jul 14, 2008
  • 323 Answers
SOURCE: unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Posted on Jul 18, 2008
  • 201 Answers
SOURCE: Skipped stitches & looping on the bottom of Quilt
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
Posted on May 03, 2009
  • 240 Answers
SOURCE: stitch problems
You can adjust the pressure foot(not footpedal)which puts the prsure on the foot by the needle. Also try altering the stitch length. If the stitches are skipping on silky fabric or knitted fabrics try using tissue and sewing onto that directly then tearing it off afterwards.
Posted on Jun 11, 2009
  • 152 Answers
SOURCE: Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Posted on Oct 08, 2009
Can't find the stretch stitch on my singer xl100. Where is it?
Here's the manual:
Singer Quantum XL 100 Instruction Manual
I did not find a stretch stitch in the manual. FWIW, a zig-zag stitch works in place of the stretch stitch. It is also much faster and uses less thread.
Oct 13, 2017 | Singer Sewing Machines
My singer quantum xl 1000 is stitching in one place
Remove plate over feed dog, femove bobbin and bobbin casing. My guess is that you have debris, lint or a piece of fabric stuck in the works
Dec 17, 2016 | Singer Quantum XL-1000 Computerized Sewing...
Cxl manual
User's Manuals, including yours, are available as a free download the Singer Sewing Machine website. Actually, when you enter CXL you get the XL-50 user's manual, which is essentially the same machine, although a few of the patterns may be different. The CXL, XL-50, XL-10 and XL-1 are basically the same machine; I own a CXL and XL-50, and love them. They can sew SIDEWAYS--straight AND zigzag stitch!
Jun 12, 2014 | Singer Sewing Machines
HOW CAN I FIX SENSOR PROBLEMS ON SINGER XL 100 IT WILL NOT MAKE STITCHES
I had this problem with my XL-1000. The motherboard had shorted out and I had to take it in to the repair shop and they ordered a new one and installed it for me. Best of luck!
Jun 08, 2014 | Singer Quantum XL-1000 Computerized Sewing...
How do you drop the feed dog for quilting
do you have a manual for the machine?
if you don't, singer has a free one on their website
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 3400 ) & click search
Mar 11, 2012 | Dual Sew Sewing Machines
My sewing machine is not sewing stitches
That is irritating! Singer has your manual; check out: http://www.singerco.com/accessories/manuals.html
I believe it costs $15.00.
Happy sewing!
Robbie
Jan 29, 2010 | Singer Quantum XL-6000 Computerized Sewing...
Singer xl1000 will only sew backwards
Electronic problems require professional to diagnose, sorry.
May 13, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Frozen machine
Hi this is techcrazy
the motors in ur sewing machine is not runnin because there is no proper rotational motion inside the motor of sewing machine.so one way of rectifyin is replacing the old pair of magnets with new ones..which may prove costly.so if possible my sincere advise is to go in for a new one
please do rate me on this solution
Feb 02, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Dual Sew 3400 Mechanical Sewing Machine Logo
190 people viewed this question
Top Dual Sew Sewing Machines Experts
ray gallant
R.A. Ellis
R.A. Ellis
Are you a Dual Sew Sewing Machine Expert? Answer questions, earn points and help others
