Question about Sony KP-51WS500 51" Rear Projection Television
Sony KP51ws520 Flashes 9 times Pause Flashes 9 times keeps going No Sound No picture or HV
  • skyttlez69 Sep 16, 2008
    The LCD indicator flashes 9 times and the tv will not turn on only flashes standby
    Genius:
  • 2,920 Answers
Weak power supply
Posted on Aug 29, 2008
What's six red blinks at sony tv?
Hi, [Error code 6. LED flashes 6 times]. Malfunction of inverter or overcurrent protection....regards Sean
Jan 15, 2016 | Sony BRAVIA KDL-32BX330 32" 720p HDTV with...
Sony model no KP51WS520 red light flashes 9 times but wont turn on
Check if the TV is in an AV mode.
Normally if I leave my TV in an AV mode with nothing plugged in, it starts flashing the red led..
If no luck return it
Mar 17, 2012 | Sony Televison & Video
Sony HDTV get sound when turned on but no picture small red standby lite in front flashes for a few seconds then turns it self off
Count the number of flashes in between a slight pause and see if its a 9 blink error or not. Then let me know how many blinks the red light is doing and I will assist you with the issue
Aug 10, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony KP51WS520- stand by light flashes 9 times and won't turn on.
Greetings, This is direct from the Sony Service manual
9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound or picture. Fails to start
Because of the intracies and risks of electrocution and radiation in this repair I suggest you arrange for a tech, rather than to attempt it yourself. Often changing the faulty component or the actual boards, fails to resolve the problem totally as it may have become damaged deeper into the circuit.
Thanks for using FIXYA
May 04, 2010 | Televison & Video
Sony KV-34xbr800 standby light flahes all the
Flashing standby light is an error code that is specific, there would be pause of 3 seconds in flashing, so count pause to pause and let me know that how many times red standby light is blinking to diagnose problem.
Thanks.
Jan 11, 2010 | Sony Televison & Video
Sound comes on, but know picture then unit shuts off. Standbye light blinking 10 times pause then cont. 10- kp51ws520
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.good luck
shaun
Aug 26, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony KP51ws520
9 times blink shows Audio Error in your TV.
Let me know if you want to fix it by yourself.
Feb 21, 2009 | Sony KP-51WS500 51" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Projection tv wont turn on
a sony should only blink up to 8 times. If its continuous without any pause that usually means No reply from the jungle (data bus is busy, shorted to ground or held
high), IK video path is defective.
Count your blinks again. let me know.
Jan 21, 2008 | Televison & Video
Sony KP-51WS500 51" Rear Projection Television Logo
169 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
