Question about Clarion DB245 CD Player
Wiring from a kenwood kdc mp332 to a clarion rdb245d
I am trying to get my sons stock radio clarion rdb245d/w original wire harness with connector, the person who owned before had a kenwood kdc mp 332,
the previous owner told him the radio would be plug and pay!!! NOT!!!!.
Ihave the wiring diagram for the kenwood I lost my wiring digram for the clarion, I was thinking to splice the wires from the kenwood to the clarion.
Please help!!! my son is driving me nuts!!!!!
Thank You, Patricia
  • Mitch
    Mitch May 11, 2010
    I'm unsure what you're asking.... Are you trying to put the Clarion INTO the car? does it have the wiring harness attached or are you looking for one? Are the connectors still on the wires coming out of the dash or have they been cut? What kind of car is it going in?
  • 239 Answers
And the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
orange/white illumination
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
Posted on Sep 25, 2010
I have a kdc-mp142wm what other recievers would plug right into the existing harness?
There are wiring kits you can buy that have the proper connectors on both ends of the wire harness so it will match up with the radio and the car's wiring harness. No cutting or splicing involved. Just push the connector into the radio and the car's original radio plug connector.
Jan 01, 2016 | Kenwood Car Audio & Video
Hi, this is Angel, My radio is a kenwood KDC-MP 238. The display said Bluetooth unit ready, how do I pair the radio with my phone? Thank you.
Hi Angel, you will need to use your phone to connect, search from phone for connection relating to radio......like Kenwood or KDC-MP 238 and then accept!
Jan 30, 2015 | Kenwood Car Audio & Video
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Hi, I would like to install my kenwood kdc-w7534u into my mini one, how can I do it, can you help please?
To install your kenwood, you will need to first remove your stock radio. To do this, I believe there is a screw you can get at from the glove box. As well, there should be trim around the radio itself. Pry into that, and pull as hard as you can. It should pull off the trim-- from there, you should be able to remove the original radio.
While putting in your new head unit, make sure you have the right wiring harness. With this, you can plug existing wires into the new receiver. From there, all you need to do is make sure all of the previously installed wires are installed in the new unit correctly, then secure the unit and replace the trim.
Voila, you're done!
Feb 28, 2011 | Kenwood Car Audio & Video
Wiring diagram
My fault meant this as a solution post....
What do you need the diagram for? If your installing the radio, you do not need a diagram you need to go purchase the wiring harness for your make and model and year car. Match the colored wires together to the ones on the back of the head unit then connect them, then that harness plugs into your stock car harness that your stock radio unplugged from. You also probly need an antenna adapter cable that just connects to your stock antenna cable to add length and then plugs into your aftermarket radio. If you need a wiring diagram because you are trying to open you radio and fix it because it is broke or something...good luck to ya. Hope I helped... :)
Dec 15, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
What wiring harness do I need that works 1996 Toyota Tacoma
Hello shonk_patric,
You'll have to go to Kenwood or to the audio dealer where you purchased the receiver if you do not have the harness that plugs into the back of the radio.
One vehicle specific aftermarket harness for a '96 Tacoma is the Metra 70-1761 available here at Crutchfield.
Hope this helps.
May 20, 2009 | Kenwood KDC-MP228 CD Player
Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
Nov 21, 2008 | Kenwood KDC-MP235 CD Player
Installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
Oct 11, 2008 | Kenwood KDC-MP228 CD Player
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
In my 1995 Chevy Lumina
check if you're getting power to the red and the yellow, it may be that you are only getting a permanent live but no switched live and if so you will need join the red and yellow on the radio side together using the connectors on the loom so you will have one permanent live leading into two (red and yellow) wires into the radio. clear as mud, good luck
Dec 06, 2007 | Kenwood KDC-135 CD Player
Clarion DB245 CD Player Logo
642 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
