Question about Samsung Televison & Video
I have a Samsung SH853M DVD recorder. It's a bit complicated to use but I have generally got to grips with it. My problem is that HDD recordings are often "jerky" on playback. They skip and sometimes just stop. This has been especially bad whilst recording the Olympics. I have tried to improve things by setting timer recordings to XP but when I set up a timer recording it is automatically set to FR and I cannot access the mode sector to change it. Similarly pressing the Rec mode button (in normal stop mode) does not have any effect. Any idea what I am doing wrong please?
Are you connecting via an HDMI cable? I had this problem, and went back to using a scart cable new recordings did not have this problem.
Posted on Aug 14, 2009
Wiring diagram for a samsung dvd-sh853m
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 14, 2014 | Televison & Video
Hd recording
If the digital tuner can pick up the HD channels, then I don't see why it can't record them. However some TV channels have blocking on them to prevent recording. If it can't record a channel it will say so with a message, generally.
Jan 22, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
My Samsung DVD-HR753 will not recognise any of the blank discs I am using including DVD-RW. I've tried Panasonic, Logitec, HP Lightscribe and Datawrite but no joy. I'm trying to record from the HDD to DVD....
It looks to me to be an old machine as I see listings for that model in 2006, now there could be a few reasons firstly it may need a firmware update which will enable it to "recognise discs" made later than it (service engineer).
The laser may be poor, playing is less stressful than recording or it may need a general service, their mechanisms and/or optic slides get dusty sticking to old lubricant slowing response times so the machine goes into "timeout" or just gives up, some have rubber belts which stretch.
It comes down to cost of repair versus new one? you could try a lens cleaner disc (a disc with a bit of fuzz stuck on it) but I have found these have varied sucess and a service clean is better with a suitable liquid.
Hope this helps.........
Aug 28, 2017 | Samsung DVD-HR735 DVD Recorder/HDD...
Samsung HDD SH853M doesn't work
What type of cable are u using to connect the TV and player.
Check those first, and reconnect if in doubt and post back
Rifaa
Nov 17, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
Libary view for Samsung DVD SH853M
No, I'm afraid not - this player simply does not offer that feature. Amazon reviews are very negative about the product.
Nov 07, 2008 | Samsung Televison & Video
Samsung dvd sh853m after recording on hard drive in play back it stops and starts every 10seconds instaled new firmware but is still the same
I had the same problem. I phoned Samsung and they told me I needed to format the hard drive. I did this and everything seems fine now. Hope this helps
Aug 04, 2008 | Televison & Video
Samsung DVD SH853M Freeview/HDD/DVR. Recorded list - cannot access
The Manual fro this machine is typically vague on the minutae of setting up and performing various functions.
Apparantly the 'standby button' on the handset should be in the 'off' position not the 'on'.
The logic of the layman can seee it as the opposite. This does work..... and thank you for your patience.
Mar 18, 2008 | Samsung Televison & Video
Samsung DVD-SH853M HDD/DVD Recorder/Digital Receiver
Make sure you are not using DVD+R dics - the player won't play these. It is OK with DVD-R.
Jan 21, 2008 | Samsung DVD-HD950 DVD Player
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
177 people viewed this question
Henry  Thomas
Henry Thomas
