Legacy Jandy  Lrz400ep Swimming Pool  Spa Heater Logo
Posted on Jun 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jandy legacy pool heater brand new igitor doesnt
Jandy legacy pool heater brand new igitor doesnt come on. message chk ign control. water pressure is 15. propane was just reconnected from old heater. Flow was good.
  • papollack Jun 24, 2011
    I have a jandy Legacy LRZ400EP which has electric ignitor. Although the unit appeared to be powered on and had a display indicating "Fault-check ign control", I was told ALL Zodiac pool heaters come wired for 240VAC. I have a 120 circuit and thought I ordered 120 Volt wiring. As shown on the Installation and operation manual two wires which are shorted together for 240 operation needed to be connected to the 120 VAC input.I wish jandy would add a small note into the packing reminding the comsumer.
    If I had not understood electronics ,that could have been difficult to figure out.
    very odd symptoms.Good idea for a battery, but I dont think jandy uses one.
    Joel
David Spradling
Level 3:
Top Expert:
  • Legacy Master 13,524 Answers
  • Posted on Jan 20, 2018
David Spradling
Legacy Master
Level 3:
Top Expert:
Answers
13524
Questions
0
Helped
929468
Points
28396
Check inside by power supply if wiring 120 volt need to separate wires with nut on them see inside of front panel for instructions
  • David Spradling
    David Spradling Jun 02, 2018
    check inside the fenwal for burned area by plug for ignitor sometimes the ignitor will short out and ruin fenwal
Morne Olivier
Level 2:
Guru:
  • Expert 265 Answers
  • Posted on Jun 21, 2011
Morne Olivier
Expert
Level 2:
Guru:
Answers
265
Questions
Helped
80003
Points
518
Good day. Some of the gas heaters have a battery powered ignitor. Please check if batteries are installed, and if so, is there sufficient power from the batteries (have the run down). Hope this helps
The pool water does not heat even though the heater says that it is set to 86 Jandy Legacy model LRZ325EN
there may be a problem with one or more of the safety devices causing the heater to not start. the biggest culprit is the pressure sensor followed closely by the fireman switch. get a pool heater technician to test and repair this problem
Why is the flame on but water not heating
check gas pressure if correct check heat rise you might need to slow water flow down
I have a brand new jandy legacy natural gas pool heater. Keeps saying check ignition control. 250,000 BYU w/elec ignition.
The heater should still be under warrantee. Call Jandy to send out a factory approved tech. Anyone else messing with it may void the warrantee.
May 28, 2013 • Pool & Spa
Top Legacy Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Legacy Pool and Spa Expert? Answer questions, earn points and help others
