Question about Cell Phones
What is the blue tooth connection code fo a Jabra BT 250v
Code is 0000
Posted on Apr 20, 2009
Nokia 6276
Posted on Aug 21, 2008
Nokia 6276
SOURCE:
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
Cant get it to woork blue light just blinks
you have to put ur bt device into pairing mode in order to pair it to a cell phone usually when u turn your bt device on you continue to hold the power button for 6 to 10 seconds and when you have a solid light you are in pairing mode then your cell will pair to your device,it will ask for a pin or pairing code,most blue tooth manufactures use a 4 digit code.the codes to most blue tooth devices are as follows 0000,1234,9999,or 1111.i hope this helps
Feb 20, 2011 | Jabra BT125 Headset
CANNOT GET TO PAIR says it is but is not connected
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps.
Thanks for using fixya.....
Nov 29, 2010 | Jabra Bluetooth Headset with Adjustable...
I need pass key for Jabra BT530 to pair with cell phone.
Take care.
Aug 06, 2010 | Cell Phones
Upgraded my phone software cannot connect my jabra bt 250v ? code 0000 but did not work
Check that both devices are in pairing mode and the phone lets the headset connect without asking for authorization.
There might also be a security / firewall issue. You might want to check your phone settings...
Dec 06, 2009 | Jabra BT250 Consumer Headset
Not charging up nor starting
Typical non use problem answer is on this site use this link
http://www.fixya.com/support/t190081-jabra_bt250v_indicator_light_doesnt
Oct 15, 2008 | Jabra BT250 Consumer Headset
Jabra 250v blue tooth headset
please mail me service center in india particular in thane mubai with phone no. my emain chalke_pravin @sify.com
Jan 22, 2008 | Jabra BT250 Consumer Headset
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Sep 02, 2007 | Jabra BT250 Consumer Headset
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
