Question about Dishwashers
ON MAYTAG MODEL MDB4800 AWB . WHAT IS THE COLOR CODE OF THE WIRE GOING TO THE SOAP DISPENSER SOLENOID?
icansurf
  • 72 Answers
SOURCE: Maytage dishwasher soap dispenser not operating properly
assuming the dispenser is in the door... maybe take off the front door panel to access the inner workings of the dispeser to see if the spring is worn out or missing. otherwise, try a little WD-40 sprayed onto the hinges or moving parts.
Posted on Mar 06, 2007
Illeagle
  • 525 Answers
SOURCE: soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Jun 04, 2008
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
  • 10865 Answers
SOURCE: soap dispenser doesn't open
My recommendation is to switch over to a tablet and merely put the tablet on the floor of the dishwasher bypassing the soap holder all together. It should work just fine that way. good luck.
Posted on Jan 27, 2009
  • 9 Answers
SOURCE: soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Posted on Apr 20, 2009
Why will the soap dispenser not open up ?
Does it open by itself during a cycle when there is no tablet inside? Have you changed to a different tablet recently? Some tabs are larger than intended for some machines and so put pressure on the lid and stopping the catch from sliding away and releassing the tab. Or it possible that the solenoid valve that operates the dispensor is faulty, Does the rinse aid still dispense?
Sep 20, 2014 | Maytag Dishwashers
Ive got a maytag neptune model# MAH8700AWW front load washer that water keeps dripping into the soap dispenser and filling up the tub over night about 1 to 2 gal of water and ive been looking for a repair...
Would be the Inlet solenoid (this is effectively the valve that allows water to come in - that the inlet hose screws on to, and has a couple of wires going to it on the inside).
Replace carefully, with the power shut off, or simply turn the tap off when not in use :-)
Oct 01, 2017 | Maytag MAH8700A Front Load Washer
Dishwasher won't access soap tray
Check if the dish rack is reversed. If it is, it'll block the dispenser from opening.
If that is not the case - you may have problems with soap dispencer solenoid or with control board. Unplug the d/w. Disassemble the door, and find the solenoid contacts on the dispenser. Check for continuity. No continuity - replace dispenser.If dispenser is ok, check wiring for continuity. Otherwise it's the board.
Jun 01, 2010 | Dishwashers
Soap dispenser does not open on main wash
Water may have run into the dispenser door solenoid core causing it to be sticky. Remove the inner door panel (after shutting power off to the machine by either pulling the plug or turning the circuit breaker off in the house panel) and remove the core mechanism from the solenoid. If the core has a white appearance, water has entered the solenoid. Either replace the solenoid or try cleaning the core piece and the inner coil hole. Don't use any lubricant here as it will make it stick. There should be a bellows-like seal between the two parts that must be in good condition. Hope this helps!
May 24, 2010 | Maytag MDB9600A Jetclean II Built-in...
Wet dishwashing soap
make sure that the you let the hot water run for 2-3 min to make sure it is hot going into machine or it will not break down the soap.if the dispenser is opening then it is a tempproblem. let me know if my assistance was any help with a 4 thumbs up post
Feb 27, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
Soap dispenser door doesn't open for the second cycle.
Hi, the soap dispenser has a motor / solenoid which controls the latch that opens the door. This has gone bad and needs to be replaced. It is located inside the dishwasher door panel. Remove the screws around the inside of the door to gain access to the solenoid. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 18, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwasher
detergent dispenser solenoid
May 10, 2007 | Maytag 24 in. MDB8600AWS Jetclean II...
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
