Question about Matsonic MS9127C Motherboard
The cd-roms @ new dvd rom with the red cable makes the cpu freez no icons
When i plug in a drive the cpu boots then my icons are missing and the pc just stays that way no change but if i only have the hdd conected then it works fine no problem what can i do to solve this minor little problem?
The DVD drive has a red narrow cable the new tipe that all the fancy computers use. I have reseted the bios to see if that would help but there was absolutly no change what so ever. Please help? Adriaan 078 156 8095
The computer was also checked by a technicion but not even they could a answer out of it.
  • 31 Answers
The DVD drive you are trying to use uses a SATA (serial ATA) connection (the red cable). If the drive came with any software on a disk, you should install the drivers for it. Otherwise check the manufacturer's website for information and/or drivers for the installation of the drive.
Posted on Aug 22, 2008
Computer continuously reboots. I can get into the BIOS and it will stay running just fine, but it will not boot to any device. It just beeps once and restarts.
sounds like the MBR is infected with something virusy, try backing up the data you need and then repartition the main Hard drive you boot from, then format and then reload your OS and you should be fine after that.
Jul 16, 2012 | Foxconn Computers & Internet
Boot device missing error
Sounds like you haven't got the cable installed correctly it will only go in one way check to make sure there are no bent pins but you should never touch or do any thing with the pc running always switch off the pc and leave it switched on at the plug socket to give you an earth this will help to eliminate static discharge and killing components in your pc, Just to clarify your CPU is the chip or brain of the computer. the lid you removed is from the pc itself. there are utilties and programs but if you need to be quite experienced to use them effectively. if you still need one just do a search on www.googalit.com and search for hdd testing software. or try this software http://www.freedownloadscenter.com/Utilities/File_Maintenance_and_Repair_Utilities/Disk_Repair_Software.html
Hope this all makes sense
Jul 03, 2010 | Western Digital (WD3200JS) 320 GB Hard...
I have just purchased a 1tb Iomega Select external HD
please change the boot setting in BIOS to hdd first then other and save it .... now try to connect the external hdd to pc and switch on .......................... ( make sure your internal HDD should be first boot able device .......)
Dec 31, 2009 | Computers & Internet
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Ntldr missing
Please check the hard drive . Seems the hdd is having bad sectors.
Jul 07, 2009 | Dell Inspiron 1420 Notebook
I've got BIOHD-3 NO BOOTABLE DRIVE (HP Diagnostic test)
if it cant detect ur HDD ... then check for jumper settings. ...
Jul 04, 2009 | Computers & Internet
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
Pc boots and stays on the black screen at the start
Try getting into the BIOS and making sure that it is detecting the RAM and HDD and Processor. Typically this happens when theres no memory or a memory problem. If its the Hard drive it will say NTLDR missing or Hard Drive failure. When its blank.
Does the Hard drive fire up when its sitting there? Does it seem like it booting the Hard drive or does it just sit there.
Also, if you have an onboard Video and a video card, try using just the onboard video for now, sometimes the Video card can cause an issue if it doesnt have drivers and comes up blank.
Make sure the bios has the video set to PCI or AGP depending which you have intstall. Or Auto if it has it.
I have had two Gigabyte board and im using one now and have had similar issues that where caused by a ATI video card.
Good luck and let me know if you still need help.
Dec 02, 2008 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Can not get any boot at all
Hi, First of all, your hard drive is what this computer needs to boot up. Try to see if you can POST, that is, only plug in power supply to motherboard with cpu and memory in there. Don't put any hard drive or other device into motherboard as yet. see if it reaches past post. If it does, then plug in hard drive and see if the problem occurs again. If it does, then the problem is the hard drive. But for now try reaching past post with only the bare necessary components for startup. Then let me know what happens.
May 02, 2007 | ASUS P4S800-MX Motherboard
Matsonic MS9127C Motherboard Logo
85 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
