Question about Tasco Galaxsee 45-060675 Telescope
How do i install my moon filter - Tasco Galaxsee 45-060675 Telescope
    Genius:
  • 1,027 Answers
The moon filter screws on the barrel of the eyepiece.
Posted on Aug 24, 2008
Nasa moon facts for kids
The first and foremost reason is the lack of oxygen. Then there is no other filtering of harmful sun rays that reach the surface. IT gets very hot in the sunlight and very cold at night.
May 14, 2014 | Computers & Internet
Miele Silver Moon Losing Suction Power
That is possible, also check for a.m. exhaust filter off the motor. Usually a very fine filter to stop dust that gets past the bag. May just need to open it up and clean out the accumulated debris.
May 02, 2013 | Miele s558 Silver Moon Vacuum
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
Cant see anything through the view finder
1. During the day, use the 17mm eyepiece on a object outside (telephone pole, water tower, etc) then align the finder to what you see in the scope.
2. Put in the 7.5mm eyepiece and fine align the red dot finder.
3. At night, point the finder at the moon (less than half moon or the image is too bright without a moon filter) Use the 17mm eyepiece.
4. Once you see the moon, switch to the 7.5mm lens and enjoy.
5. Download Stellarium or any free astronomy software and see what is in your sky tonight. Your scope should be able to see Jupiter and its moons easily.(Saturn, Mars and Venus when the time is right) Open clusters like Pleiades will be nice is this fast scope.
5. If stars are not sharp, you may need to collimate the scope. Look online for general instructions.
Nov 14, 2011 | Optics
Replacing camshaft position sensor, Sable 2003,Ohv
usually if the magnet in the sensor comes out it destroys the cam position shaft,(it should have a half moon shape when u remove the sensor from the cam pos/oil pump drive. if the half moon is damaged or missing u must replace the cam pos/oil pump drive, and yes it is timed with the engine. wot i have done is try to locate where the half moon was on the drive it usually leave a trace of where it was. now index where the half moon is at remove hold down bolt and remove the driver assy. install the new drive, clock the half moon shaft to match the one u just removed once u get the half moon shaft where u want it and the oil pump rod alines and the whole housing is down install the hold down clamp. now to get rid if that check engine lite youll have to plug a scanner in and look at the live data adjust the cam position till u have plus or minus 2 degrees
Mar 18, 2010 | 2003 Mercury Sable
My Miele Silver Moon "Reset" light is blinking. What do I do?
Greetings from GoVacuum,
Ahh yes, the Silver Moon. One of Miele's best made vacuums ever! So good that out of all the different vacuums that I could of chose for my home, the Miele S558 Silver Moon was the one I chose.
When you're Reset button is flashing, this simply means that it's time to replace the HEPA filter on your vacuum cleaner. Miele included this feature on their upper end models to alert the user when their filter needed to be changed.
The Miele Silver Moon uses Genuine Miele S-Class HEPA Filter for S300i/S600i, and Miele S7 Uprights. Miele Part # 04854915 (replaces 04854911) Which can be purchased from GoVacuum for $52.95 with free shipping.
Once you have installed the new HEPA filter, simply press down on the flashing Reset button to restart the 50 hour internal timer inside. Miele recommends to replace this filter after every 50 hours of vacuuming.
If this answer was helpful, please click on the helpful Thumbs Up icons in the top right hand corner of this Solution.
If you have a repair that you would like explained, please check out our Q & A website, askgovacuum.com.
Thank you very much,
Chris Jones
GoVacuum.com
Feb 19, 2010 | Miele s558 Silver Moon Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
Bissel carpet shampooer
Make sure the filter on the tank lid is clean. If yours has the half moon window at the bottom, make sure that the half moon window and the clear noozle haven't come apart from each other.
Aug 02, 2008 | Bissell 1699 ProHeat Clear View Upright...
Tasco Galaxsee 45-060675 Telescope Logo
106 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
