Question about Gestetner Office Equipment & Supplies
Gestetner 3245 copy machine
Could you tell me what SC 543-00 means in the function window?
What would it take to resolve the issue?
  • 3 Answers
You have a problem in the heater, sensors detected temps over 220c for more than 6 seconds. It will be an expensive repair. Most likely around $400 parts plus labor. Not something for the average Joe to troubleshoot.
Posted on Aug 22, 2008
Gestetner 3235 copier speed only 35cpm it true that
replace the board and the main motor and the polygon mirror motor( not recomended)
3245 45cpm
3235 35 cpm
Oct 30, 2009 | Gestetner Office Equipment & Supplies
I have a Gestetner 3245 With Code SC 322-00 call for service message on. What is it, can it be fixed or reset. I bought it used to use in my classroom. Thanks
Hello sir; The error code you display on screen, it means laser unit have problem, it can not be reset but it can be fixed, you have to call your local technician to help you.
Oct 13, 2009 | Gestetner Office Equipment & Supplies
Gestetner 3245 dev.bias setting....
Hi how you doing the main problem with changing the dev bias is that the gap between the drum charge and dev bias has been brought closer and so more toner is being put onto the drum for image density.. I take it you have cleaned the optics on the scanner mirrrors and that the laser **** glass has been cleaned as these effect the copy quality too.. if the dev hasnt been changed at the pm intervals it slowly looses its charge holding capabilities.. you should change at least at the 160k marks to keep quality good.. you could also adjust the laser power up so you have a stronger image formation..hope this helps..if you know the machine I would take the laser unit out too and take the cover off to see if there a dust coating in the image mirrors as this can cause faint copies over a long period.. Good Luck A
Jul 01, 2009 | Gestetner Office Equipment & Supplies
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Product Gestetner 3245 It has sc 543-00 problem
Fusing overheat error.  It may require a thermistor or a new lamp.  Prices vary by dealer.  You would have to contact a dealer in your area to find out.
Aug 21, 2008 | Gestetner DSm645 Digital Imaging System
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Mar 03, 2008 | Gestetner DSm515pfd Digital Copier -...
73 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
