Question about HP PSC 2355 All-In-One InkJet Printer
My printer is not working
My printer keeps telling me scanner failure turn power off then on. i keep doing that but then it says the same ting again. plz help.
  • 4 Answers
Try http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=uk&lang=en&dlc=en&product=422000 (4 XP Only) to remove all software and then install again and upgrade drivers, Creon
Posted on Aug 25, 2008
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Ink system failure & keeps shutting down & coming on its own.
Do the following, let me know if it clears or not:
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Displays " Scanner Failure"
I've seen a similar issue on other HP All-In-Ones. I had to contact support, but all they do is make sure you try connecting the printer to the wall outlet instead of a surge supressor, then a different wall outlet, then reset to factory defaults. After that didn't work, they submitted an replacement order.
Hope this helps
May 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I keep getting this error scanner failure.
On the top of the scanner mechanism, there is a black tab that gets caught on the underside of the scanner surface, just beyond the glass, towards you. You will hear a gear grinding sound, that"s the tab getting caught. either bend the tab down, or remove it. Its on the black cover that"s on top of the scanner mechanism. Also remove any tape that is on the bottom of the trailing cable under the scanner mechanism that prevents it from moving all the way to the left.This worked for me, It drove me nuts till I found out.
May 04, 2009 | HP OfficeJet D135 All-In-One InkJet...
My hp psc 750 will print from my computer, but I cannot make a copy. It keeps saying, "Scanner Failure. Turn off and on again." I have done this several times and it still will not make a copy.
My hp psc 750 will print from my computer, but I cannot make a copy. It keeps saying, "Scanne Failure. Turn off and on again." I have done this several times and it still will not make a copy.
Apr 20, 2009 | HP PSC 750 All-In-One InkJet Printer
My Office Jet 7310xi scanner failure
Does it scan from either the doc feeder or from the flatbed itself?
Can you COPY a page?
Are you using the buttons on the printer, or do you work from HP director?
Mar 29, 2009 | HP Officejet 7310 All-In-One Printer
When I turn the printer on, a rhythmic banging sound starts
Is the scanner transport lock engaged?
This is either a screw, pin, Clip, Slideswitch or button that keeps the delicate scanner head from moving during shipment.
Look for it in the back and on bottom. If that isn't it, then the driver circuit for the stepping/space positioner motor is bad and you need a techie like me to fix... or just get a new AIO for $39.95 from Wal Mart.
Mar 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
R40 Scanner Failure
Hello I have a little problem my printer print well for scanning it is not tell me what I have to do and the copy too doesn't work properly.
thank you for your help. May God bless you in everything that you udertake in life. keep on
Apr 16, 2008 | HP OfficeJet r40 InkJet Printer
Scanner Failure Message keeps popping up
Here it is all over, with all the steps.
1.Unplug power cable from printer.
2.Hold Cancel and Enter. OR you could Hold Cancel and Black Copy Button. Whichever is easier
3.Then plug back in the power cable, while still holding those 2 buttons.
4.It should turn on, lights blink, then it should say FULL RESET on the little screen thingy .
5.Let go of the buttons, and hopefully, it fixed your problem.
Nov 29, 2007 | HP PSC 750 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
87 people viewed this question
Ben Johnson
