Question about Acer AL1717 17" LCD Monitor
MOnitor Base We have received instructions to send in the monitor for repair or replacement and in the instructions it says to remove base prior to shipping. I can not figure out how to do this. Can you help me?
  • 31 Answers
Unfortunately I have heard that the bases on this model of Acer aren't meant to come off once they are put on properly. There are clips that hold the base in place that if manipulated properly should let you wiggle the base off gradually. Using a screwdriver or other thin, flat object to wedge the clips out of the way is usually a good bet.
Posted on Aug 22, 2008
How to remove base from gateway hx2000 monitor
You need to find the original instructions for putting the monitor together, or you could accidentally break the base from the monitor if you attempt to remove it the wrong way. Try Google.
Jul 11, 2014 | Gateway HX2000 20" Monitor
How do I remove the base neck from the monitor? I
theres a scre that is making the base stick to the monitor, take it out and slide out the base, or check the user manual for that
Feb 15, 2010 | LG W1934S-BN 19" Monitor
hope u r a u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
Attaching Samsung 2033 monitor to base
The solution is that you simply have to really force the monitor onto the base post. Thanks anyhow.
Jun 23, 2009 | Samsung 204T 20" LCD Monitor
VG930M-3 Taking base of this monitor...
After a chat with a Viewsonic tech and pulling out a lot of screws, this is what I discovered you have to do;
Find a secure place to turn your VG930M upside down, like on an armchair.
Undo the central screw on the base and remove the rotating black plastic plate.  Make sure you know which way it goes back on again.
Remove all the screws on the metal plate, something like eight around the circumference and another two which attach to the LCD support column. (You were never just going to pull that base off!).
Now for the tricky bit! The support column has two extensions that extend down into the base and click into position.  You have to get a flat blade screwdriver and push one of them towards the centre while trying to lift the base just a little away from the support column, so that it is unclipped.
Then you have to do the same with the other extension, while lifting the base a little. The base should now pop off.
Not as straight forward as some screens but achievable!
Good Luck!
Aug 25, 2008 | ViewSonic VP920b 19" LCD Monitor
Acer p221w monitor removing base
Since you have surely looked, it isn't held on with exposed screws.
Check to make sure that the rounded area that allows tilting is not part of the case but appears to be separable.
Most that are removable are held by a tongue and a fairly obvious release tab.
if you can't remove the base, just place the monitor in the carton on good padding and upside down.
Fill and cushion the sides well, mark the carton with 'This side up' and an arrow and hope there are no malicious handlers on the trip.
I've shipped numerous monitors of different sizes and types and have lost none of them to shipping damage.
Aug 06, 2008 | Gateway FPD2275W LCD Monitor
How do I remove the base of a Viewsonic VX900 monitor?
actually you will be having a projection which locks into the slots of the monitor..
you need to apply some pressure to remove them out of the slots
Jun 18, 2008 | ViewSonic VX900 19" LCD Monitor
X2gen MG19E monitor
The only way to adjust the tilt on these monitors is to loosen the screws that attach the stand to the monitor. We had to completely remove the stand from the monitor to get to these stand screws.
Feb 12, 2008 | X2Gen MG19MY 19" LCD Monitor
Missing important base screw - is replacement possible?
I have a replacement from a dead monitor. Contact me and I will send it to you free of charge. Ken Hunter (
Nov 18, 2007 | Mag Innovision LT982s 19" Flat Panel LCD...
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
