Question about Canon ES50 8mm Camcorder
I have i guess connetion problems
My camera has a fully charged battery but the camera doesn't reckonize it so i have to use the power cord at all times. i have even bought two new batteries replaced the time date battery and i still cannot get it to understand the battery is there
    Scholar:
  • 62 Answers
There are a few possibilities. One of the contact pins on the camera may be dirty or bent. The wiring coming from the pins to the circuit board inside the camera may be broken. A fuse inside of the camera may be blown (if there is a separate fuse for battery power). The battery even though it was charging for many hours may still be drained because it's old or defective - check the battery voltage with a digital volt meter to verify, and for absolute verification you should check the battery voltage under load when it's plugged into the camera and the camera is switched ON - is the voltage more or less constant or did the battery get loaded down and voltage level is now way below spec? Those in my mind would be the first few things to check.
Good luck.
Posted on Aug 21, 2008
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
Camera works fine with power supply cord connected. It will also charge the battery if connected to camera and power supply connected to ac outlet. Checked battery and it has 8.32 Volts stored in it after...
Your charger is probibly the problem i had a friend of mine that had the same problem but different camera i told him to get a new charger he did and it worked so yoyu do the same goodluck:) please rate this solution...
Jun 06, 2010 | Cameras
Battery cannot be recharged.
OK, Batteries have cycles and these get depleated by recharging thus once there all gone well the battery will not charge. The facts here 9 timeso ut of 10 it would be the battery but I will not holdthat over your head. Take it to a camera shop and discover it for yourself as what you going to end up doing anyhow. If it where the charger I would reckon it would not even try the first time.
Thanks and please be considerate when leaving a postive rating and feedback
May 27, 2010 | Samsung NV10 Digital Camera
Whenever I turn camera on it immediately turns off.Battery new and fully charged.
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 18, 2010 | Kodak EasyShare M873 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Its charged. i turn it on and it chuts right back
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 14, 2009 | Kodak EASYSHARE M1063 Digital Camera
Hi My Dell M1530 doesn't start up The battery is fully charged, the power cord is working good(the light is on) but the laptop doesn' give a sign that is connected to power
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 18, 2009 | Dell XPS M1530 Laptop
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Canon ES50 8mm Camcorder Logo
69 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
