Question about SimpleTech Pininfarina 80GB External USB 2.0 SP-UE25/80 (SPUE2580) Hard Drive
Want for format with FAT32
Is it possible to format the drive with a FAT32 setup. Our security at my work makes all files created at home into a read only at work.
    Master:
  • 505 Answers
Yes that's the way i format my drives
Posted on Aug 23, 2008
I have a panasonic blu ray home cinema system, it says my usb isnt compatible cannot read it, trying to play music via a portable hard drive
It may be in the wrong format, there are 2 main format for usb hard drives, FAT32 and NTFS. You may have to reformat to a different format to what you currently have. To do this, you will need to plug it into a computer, go to Computer and right click on your drive and select format. Select either FAT32 or NTFS, make sure there is a tick in Quick Format and then click start. Please note, this will erase all data off your USB stick so make sure to copy all your data to your computer before you do this. If it doesn't work, then try the other format i.e if FAT32 does not work try NTFS. And just as a side note, the main difference between the 2 formats is FAT32 will not allow you to copy files over 4GB while NTFS will.
Dec 05, 2014 | Panasonic Audio Players & Recorders
My PS3 recognizes my old external hard drive but not my new one (same brand). Why?
Connect the hard drive to your computer using a USB cord.heck what the File System type is by going to Start, Control Panel, Administrative Tools, Computer Management, Disk Manager. Select the external drive and read the "File System" type. The file system type must be FAT32 in order for the Playstation to recognize it.3 FAT32 has a limit of 3.9 Gigabytes per file, which means some high quality HD movies might have to be split into smaller files, and that makes it less than ideal for some HD content.4 Please read this entire step before attempting - going into the command prompt is for advanced users only. It is recommended that you instead use HP's freeware tool "HP USB Disk Storage Format Tool" instead of following this step which shows you how to manually format your drive.Note that on all of these systems the ormating process will take considerable time (possibly hours) depending on the size of the Hard Drive. This is normal, just be patient.Windows Users Using the following method you can only format a drive to FAT32 up to 32GB in size.[This requires confirmation as I thought that was only true during windows setup? 8TB format is technically possible with FAT32] Freeware such as EASEUS Partition Manager allow you to format the entire drive as FAT32, whereas windows and other programs like SwissKnife v3 will limit it to 32GB and 393GB respectively. If the file system type is "NTFS", right click and select "Delete Partition" or "Delete Volume" for Vista.Recreate the partition but do NOT format it. Make sure you assign a drive letter (for this Tutorial, we'll use H:)Format the drive by going to the command prompt (Vista, right click on Command Prompt in Start>All Programs>Accessories and click "Run as Administrator") and type in "format h: /FS:FAT32" (without the quotes). You may need to substitute your drive letter. (note this might not work on XP for a large hard drive - you may have to use a third-party formatting utility like like the HP Utility noted above. If you receive an error message stating that the drive does not exist or cannot be found, it is likely that Vista has formatted the drive to "NTFS". Use the Disk Management screen to delete this partition again choosing the option to not format the partition then use the command line format command again. Mac OS X Users Open /Applications/Utilities/Disk Utility.app, pick the drive, and click on the 'Erase' tab. Pick 'MS-DOS (FAT)' for the file system type, and click on the 'Erase' button.Mac OS X Leopard Users Open /Application/Utilities/Disk Utility.app, pick the drive and click on the 'Partition' tab. Pick '1 Partition,' for the Volume Scheme, and 'MS-DOS (FAT),' for the Format. Click the 'Options...' button (near the bottom) and select 'Master Boot Record.' Press 'Okay' and then 'Apply 5 Open "My Computer" and double-click on your empty external hard drive.6 Create a folder system identical to that on the Playstation 3. All folder names must be in capital letters. In the root directory of your drive, create folders named "PICTURE", "MUSIC", and "VIDEO". If you do not create these folders, your media files will not display when selecting the USB drive on your PS3, although you can access them if you press the triangle button and select "display all". If you will also be storing backups, save game data or themes, create a folder called "PS3" with folders called "EXPORT", "SAVEDATA", and "THEME" inside 7 Load all the music you want into your music folder, all the video you want into your video folder, and all the photos you want into your picture folder. Your game folder should still be empty.8 Disconnect the hard drive by clicking the green checkmark in the icon list and the bottom right hand corner of the screen and select "Safely remove Disconnect the hard drive by clicking the green checkmark in the icon list and the bottom right hand corner of the screen and select "Safely remove. Once your computer tells you "*** drive can now be safely removed", unplug the hard drive from your computer.10 connect the hard drive to your Playstation 3 and use the extra space to save information and access all your extra content saved on your external hard drive.11 In order to make your new HDD recognized by PS3, you must make sure that: First, the file system is FAT32 or NTFs. If it is NTFs, you should convert it to FAT32 with an NTF converter.Second, make sure your PS3 firmware is the latest version. If it's not, download the latest firmware from the Playstation website and put it on a memory stick to transfer to your PS3 via a USB port. This will be recognized by the PS3 and will be used in the process of setting up your new hard drive. You should also put your FAT32 partition as the first partition on your HDD, as only this can be recognized by PS3.
Oct 16, 2011 | Sony Playstation 3 (PS3) Console
I brought a 250gb hdd for the xbox 360. The xbox 360 says that it is a unformatted storage device, the only thing i can do is formatted the hdd. but nothing happend I have formatted the thing 5 times....
Trying to format a large external USB or Firewire hard drive to the FAT32 file system? Can't do it? Only see an option for formatting the drive using the NTFS file format? Well if you answered yes any of those questions, then you're at the right place.
I was recently trying to format my 1 TB MyBook external hard drive in Windows XP to FAT32 instead of the overly forced-upon NTFS format. Why? Well because I needed to connect it to a NAS device and the NTFS permissions were causing the NAS not to be able to access the drive. Simple solution is to use FAT32, no security, no problems. Though it's sometimes useful to format a USB drive in NTFS format.
Also, formatting a drive in FAT or FAT32 will allow it to be read by other operating systems, such as Mac, Linux, and older versions of Windows such as Windows 98.
Unfortunately, Windows XP and Windows Server 2003 will only format a removable drive in FAT32 if it's less than 32GB! Hmmm...that pretty much cuts out ALL modern external hard drives!
However, Windows can format a drive that is larger than 32GB in FAT32, but you have to use the DOS command prompt. However, if you have a drive that is 1TB or larger, you may still get an error saying "The volume is too big for FAT32".
In that case, you can use a free program called SwissKnife that will allow you to format an external hard drive that is up to 2TB in size. Let's go through both methods. In case you are having problems getting your external hard drive to show up in Windows, read my article on how to change the drive letter for an external drive in Windows.
Format external drive in FAT32 using DOSOpen a command window by going to Start, then Run and typing in CMD.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
Mar 02, 2011 | Microsoft 20GB Hard Drive for Xbox 360
Computer crashed now formatted with vista home and trying to reinstall flight sim X but it keeps coming with this message microsoft flight simulator x scenery world texture 024C2 Sul.BMP
FAT32. The File System used by Win98SE that has no security like NTFS file/user permissions. The lack of FAT32 security may be your answer to a lot of problems with FSX. Mine was a license issue + couldn't install ACCELERATOR pack. Windows 7 offers all the tools to create a FAT32 from available space from your C drive. ControlPanel>>AdminTools>>ComputerManagement>>Storage>>DiskManagement. Right Click on Drive C and click "shrink volume". Set shrink size to just under 32 GIGABYTES. Then format it as FAT32, Reinstall FSX into the FAT32 partition and ENJOY!!!. The install may take almost 2 hours so just let it sit. This (installing into) FAT32 thing will solve so many issues. In NTFS, if security on one file it tries to access - fails or a service FSX needs to run fails THE APP WILL FAIL!!!!
Oct 10, 2010 | Microsoft Flight Simulator X
How do I get it to work on my Ps3
Hi Damian, if you can't read any file from it it's because it's probably format as NTFS. You have to format it as FAT32 otherwise PS3 won't read anything from it.
Also, you have to create two partitions on it because PS3 won't read anything bigger than 512 GB. When you got it to fat32 go to MOVIE, PHOTO or MUSIC and hit the triangle button in order to display your files.
Regards, Peter
Aug 09, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Will not play from usb flash drive get "Loading" when I put it in usb slot then it goes to "FO TO" on the display and nothing happens. I tried pressing channel + and channel - to move to the next file, as...
Is your USB flash drive formatted with NTFS? Most consumer devices that is USB enabled aren't able to read NTFS-formatted drives. Try with a FAT32-formatted drive if you have one, or you could backup the drive and then format it in Windows as FAT32. (Right click the drive and choose format, then choose FAT32 as filesystem)
Apr 20, 2010 | RCA RT2870 Theater System
I am having an issue with my WD5000h1u-00 500 GB external drive
Read this instructions my friend
It is possible to use a Western Digital external hard drive on botha PC and a Mac. However, there are some things to keep in mind if youwant to do this. Moreover, Western Digital does not recommend doing it.
  • For both PC and Mac to be able to read the drive, it must beformatted in the FAT32 file format. In order to format to FAT32 on aMac you may need to contact Apple for support. We do have a FAT32Formatting utility for Windows that reformats WD external hard drivesto their full size, but in only one partition. The FAT32 formattingutility can be downloaded from our Downloads Library. You will find it on your WD drive's Downloads page.
  • Critical: Do not attempt toconnect any external drive to multiple computers, simultaneously; letalone to both a Mac and PC. This could quickly damage the drive'spartition and corrupt the data on the drive.
  • Sometimes, PC's won't read Mac FAT32 formatted drives, andMac's won't read PC FAT32 formatted drives. You may have to re-formatthe drive trying both the PC and Mac until you get a format that works.
  • Most WD external hard drives come pre-formatted with one large FAT32 partition, which is accessible by Windows 2000, XP, and Vista, and Mac OS 10.4 and 10.5.
  • Windows 2000, XP and Vista can only create FAT32 partitions that are 32 GB's or smaller.
  • Mac 10.4 and 10.5 can create FAT32 partitions the full size of the drive.
  • There is a 4 GB file size limit on the FAT32 file format. Thisis a file system limitation that affects both Mac's and PC's, and thereis no way around it.
  • Finally, you need to understand that if you are using the samedrive back and forth between a Mac and PC, there is always the chanceof files being corrupted. Mac's and PC's are different platforms, andtheir file systems function differently. Please keep backups of allyour files before you start sharing between Mac and PC computers.
Note: Once the data iscorrupted, that drive may no longer be recognized by one or both of thecomputers. Or, the drive may be recognized, and the data may bevisible, but you won't be able to open any files. At that point, youwill need to re-partition and reformat the drive in order for it to berestored and usable by both computers again. In the process, you willlose all the data on the drive. For that reason, you need to keep abackup of the files you are transferring between computers.At the bottom of the page, you will find links for partitioning and formatting in Windows XP and Vista, and Mac 10.4 and 10.5.
Jan 12, 2010 | Western Digital My Book Premium ES...
Hts3440 home theater 5.1
Check the file system format on the flash drive (possibly FAT32) and have the hard disk drive formatted with the same file system.
Note that Windows can not format with FAT32 any hard drives that are bigger than 32 gb, you will need to do it in MAC OS or in other operating systems that support formatting large hard disk drives with FAT32.
regards
Sep 17, 2009 | Philips HTS3440/37 System
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
USB Hard Drive
You cannot run a External Hard Disks (...that's what the User Manual say) It only reads Flash Drives, I have tried 8GB.
Oct 01, 2008 | JVC KW-AVX800 CD Player
Computers & Internet Logo
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
