Question about Konica Minolta DiMAGE 5 Digital Camera
Power up failure
I plugged a 6-volt AC power supply into my Minolta DiMage 5 camera while I charged its batteries. The camera did not power on, and now will not power on with the AA batteries. I have tried different sets of batteries, without any luck.
  • Crockie Aug 25, 2008
    I plugged a 6-volt AC power supply into my Minolta DiMage 5 camera while I charged its batteries. The camera did not power on, and now will not power on with the AA batteries. I have tried different sets of batteries, without any luck. Nothing comes up on the display, and there are no sounds. It is as though there is no power to any part of the camera.
    Thank you for the idea, but how can I check to see if there is a problem with the battery connection?
  • 10,594 Answers
You have supplied almost double voltage to camera and in my opinion, it damaged the on-board few power supply parts like regulator IC etc. You should contact to nearest Sony Service Center as they service Minolta too. Here is Minolta customer notification for details.
Posted on Aug 25, 2008
  • Shahid Electronics
    Shahid Electronics Aug 26, 2008
    Hi Crockie,
    Hope you got my suggestion about your camera problem.
    Master:
  • 623 Answers
There are fuses or wires on main board that might have been burnt
take it to a professional.
    Genius:
  • 1,447 Answers
Hi-
Check the leds on the camera's battery compartment/slot and if you can clean it with a sandpaper( little tricky though) then try cleaning it, and if its still within warranty call manufacturer instead for a possible replacement.
Hope this helps
    Master:
  • 521 Answers
If the memory card is full then also this problem occurs like no power in the camera.
i will provide you with some tips to solve this problem manualy try that if it helps it your luck or take it to the repair center for proper repairs
Things You Can Fix Yourself:
The common problem that can be detected and fixed without much hassle is the digital camera lens. Most of the time it is due to careless handling or improper setting that the lens ceases to function leaving you baffled over the matter. Most of the time, it is due to the improper alignment of the lens. You will encounter system error messages on the LCD. In such circumstances the camera is not able to focus and the result is worse pictures. You can simply realign the lens or reset the zoom barrel guide pins and you will find your digital camera working as usual.
There are some other minor and common problems such as broken battery cover, broken hinges on memory card doors, cracked LCDs, etc. But if you are not sure about the problem, it is wise not to handle it. Rather you can take your digital camera to an authorized repairing center.
However, before visiting any repairing center or technician you must take check certain common things. There may be some minor problems that you can identify yourself such as:
1 - Sometimes, it is very likely that you might have hit the wrong button or have changed the menu for which the device does not work properly.
2 - If the battery of your digital camera is running out of power, it is most likely that the digital cameras will not work. Ensure if thing improves when a fully charged cell is inserted into the digital camera.
3 - Sometimes, it is necessary to reset the camera through the menu or by removing the battery for 24 hours.
4 - The camera may not turn on if the memory card is full.
These common problems can not be really considered as a serious problem for the digital camera. But a novice user of the gadget may find it difficult them troubleshoot.
Selecting Repairing Service Station:
If the small efforts are not enough to fix your camera, visit an authorized service station in stead of asking any ordinary technician. The technician in the service station should have experience of fixing several brands and models of digital camera.
Moreover, both the user and the technician should have the ability to distinguish between marginal repair and quality repair. A little bit of confusion in this regard may cause damage to your precious digital camera.
Each model of digital cameras requires special tools to fix the errors and reliable service centers have these specialized tools and skilled technicians to properly service and safeguard the digital camera. Efficient diagnosis and repairing of digital camera depends largely upon specialized tests, appropriate equipments and expert technician.
The high-end and sophisticated device like digital camera requires a lot of concern and careful handling which is of paramount importance for longevity of the digital camera. However, the repair process of digital camera also needs the same amount of care and attention. You need to have adequate knowledge of handling digital camera to avoid any kind of trouble.
  • Konica Minolta Master
  • 19,396 Answers
The power adapter had a wrong voltage . this burned the power wirings inside the camera. This contacts also go to the batteries.
The camera must be taken apart to repair this.
You are lucky if you did not cause any further damage.
Take camera to a camera repair shop.
Also check your guaranty terms.
  • Ginko
    Ginko Aug 25, 2008
    Now if I post a nonsense I will probably score the best solution.
    Please vote the solution, many thanks.
  • 6,487 Answers
This can be a problem with battery and the camera battery conenctor that might gone bad or just need to be replace..
Hope that helps.......
  • Mark Gil
    Mark Gil Aug 25, 2008
    Its already tested that i can be the problem with the battery connector because you already tried a different battery but still have the same proble,, better take it to a repair center near you..
    Good luck.......
  • jude Oct 02, 2013
    in the manual, it tells us not to have batteries in when the ac power is in use.
    Genius:
  • 1,847 Answers
When was the last time you used it? are you using the correct batteries alkaline one
  • Legin Varghese
    Legin Varghese Aug 25, 2008
    do you see a blinking low-battery icon appears indicating insufficient power, wait approximately 8 seconds until the LCD monitor display and the EVF become blank. Then switch to another power source or replace with fresh batteries
Battery door clip on Dimage 7 5.0 mega pixels
try too fine a battery container which can hold your batteries and contact it too the camera by the external power plug.
It's an solution if you don't find a battery door.
You may also use a car battery of 6 volt by this system.
Oct 09, 2008 | Konica Minolta DiMAGE 7 Digital Camera
Konica minolta Dimage x50 doesn't work
Buy the AC adapter plug the camera in without any battery, if it works then its the battery,if not its the camera.
Jun 10, 2008 | Konica Minolta DiMAGE X50 Digital Camera
Power supply and battery charger
When I turn on the camera the screen is white. No image is on the screen.
Oct 23, 2007 | Konica Minolta DiMAGE X50 Digital Camera
Is it necessary to load the battery (power supply) when the camera is connected to the computer via USB cable?
Yes. Please use the battery or dedicated AC adapter. For transferring large size of images, using AC adapter is recommended.
Sep 19, 2005 | Konica Minolta DiMAGE E500 Digital Camera
Can I use the battery charger BC-400 overseas?
No, you cannot. This is due, not only to the shape of the plug, but also to the fact that the AC cable for BC-400 do not comply with overseas regulations. Though the label on BC-400 indicates the voltage rating (100-240V), the durability of the power cord for each type of BC-400 differs respectively. Minolta has no responsibility for any damage or loss incurred by use of AC adapter or BC-400 not warranted in the region. The mentioned electric cords may not be inseted to the power receptacle. In this case please obtain the transform adaptor at the local dealers. (Please be noted that especially in China there are 5 or 6 types of plug .) Warning: Please be careful when pulling in/out the cord from the power receptacle for the electric shock prevention.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
What is the warranty on my new DiMAGE Digital Camera?
For the following cameras: Dimage PIC, Dimage V, Dimage EX 1500 (ZOOM or WIDE), RD-175, Dimage RD-3000, Dimage 2300, Dimage 2330, Minolta 3D-1500, we offer a 1 year limited USA warranty. Please see warranty details below. For the following cameras: DiMAGE 7, DiMAGE 5, DiMAGE S304, DiMAGE E201, DiMAGE S404, DiMAGE X, DiMAGE 7i and DiMAGE F100, DiMAGE F200, DiMAGE F300, DiMAGE 7Hi, DiMAGE S414, DiMAGE E223, DiMAGE X, DiMAGE Xi, DiMAGE Xt, DiMAGE A1, DiMAGE Z1, DiMAGE G500, DiMAGE X20, DiMAGE E323, and DiMAGE Xt Biz we offer a 1 Year limited international warranty. Please see international warranty details below. (All current Minolta and Konica warranties will continue to be honored by Konica Minolta.) MINOLTA CORPORATION U.S.A. LIMITED ONE (1) YEAR WARRANTY- Minolta Corporation 101 Williams Drive Ramsey, New Jersey 07446 (לMinoltaמ) warrants that the product set forth below, IF PURCHASED IN THE UNITED STATES OR ANY ISLAND IN CARIBBEAN SEA, will be free from defects in materials and workmanship for the period of one (1) year from the original date of purchase under the following terms and conditions:1. To obtain service under this warranty, send or deliver this product, within the warranty period together with this warranty certificate, to any Minolta regional office or Minolta authorized warranty service center, you must also present proof of purchase showing the date and place of purchase and, if not prohibited by local law, pay a handling fee. 2. If, upon inspection by Minolta or a Minolta authorized warranty service center, the product is proved to be defective, it will be repaired without charge using if necessary, new parts or comparable used parts which have been fully reconditioned, and returned to you. Where not prohibited by local law, a freight charge may be imposed for the return of the product to you. The warranty period for replacement parts shall extend for a period of six (6) months following the installation of same or for the remaining period of this warranty, whichever is longer.3. This warranty card does not apply in the following cases:(a) damage to the product due to mishandling, alteration, accident, impact dropped, sand and/or liquid or moisture damage, tampering, battery, or chemical corrosion, failure to follow operating, maintenance or environmental instructions prescribed by the applicable instruction manual or shipping damage; or,(b) damage caused during service performed by other than Minolta or a Minolta authorized warranty service center; or,(c) if the product has had its serial number(s) or other identifying data removed; or,(d) damage, defect or unsatisfactory performance caused by the use or attachment of lenses, flashes or other accessories not manufactured or distributed by Minolta. 4. ANY IMPLIED WARRANTIES FOR THIS PRODUCT, INCLUDING WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR USE OR PURPOSE, ARE LIMITED IN DURATION TO THE PERIOD OF TIME SET FORTH BELOW FROM THE DATE OF PURCHASE,
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Sep 15, 2005 | Konica Minolta DiMAGE 2330 Zoom Digital...
Sep 15, 2005 | Konica Minolta DiMAGE 2300 Digital Camera
Power Compatibility
Look on the power supply or the back of the unit. You will most likely see something like "INPUT 100-240VAC 50-60Hz 15-20VA". If so, then all you need is a plug adapter. If not, you'll need a power converter.
Sep 13, 2005 | Konica Minolta DiMAGE G600 Digital Camera
Konica Minolta DiMAGE 5 Digital Camera Logo
170 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
