Question about Maytag Commercial Non-Coin Washer, MAH21PND
Blowing fuses I have a Maytag commercial coin washing machine model a25ct. It keeps blowing the fuse for the water level control switch. I am thinking the switch is bad but I am open to anyother suggestions before I start buying parts. I am interested in any imput that you may have and thank you for your help in this matter
    Master:
  • 590 Answers
If you have a friend with a multimeter then you can trace the fault backwards from the plug to see when exactly the short circuit happens without plugging the machine into the mains using the multimeter terminals as the mains terminal and advance the timer by hand to see where the short accurses on the dial so you can see weather the short is the heating element or not that's the main cause of short circuits eric
Posted on Dec 27, 2017
SOURCE:
catriver
  • 878 Answers
SOURCE: MAYTAG LAT9235AAE TOP LOAD WASHER WILL NOT WORK
Pt, Should be a yellow wire from the water level switch according to the diagram I have. See if it has 120V to motor when full. Just take it to ground. Same with the lid switch in closed position, it shows here as yellow, but could be grey, these diagrams are not always accurate. I think you have a level switch or lid switch problem. Check for voltage to the motor when it should be agitating. Catriver..post back.
Posted on Oct 02, 2006
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
Washer_tech
  • 164 Answers
SOURCE: repair the maytag commercial washer with out coins selector
your bearings are going bad. you need to replace the bearing on the top of the brake packag and might have to replace the tub bearing also
Posted on Dec 18, 2007
  • 525 Answers
SOURCE: dead Maytag washer
You will need to replace the lid switch assembly, not just the fuse. Below is a link that will go directly to an enlarged image of what you need, along with ordering and shipping information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1468&PPStack=1
Note: Lid switch adjustment may be required when installing new kit. If instructions do not come supplied with the kit, post me back and I will try to guide you through it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
  • 148 Answers
SOURCE: Maytag Performa water level
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Posted on Jul 13, 2008
I own a maytag atlantis top load washer model LAT4914AAE and the fuse located behind the knob controls blows when ever i go to wash a load
The reason the fuse keeps blowing is because one of the two switches their where the fuse is is bad and drawing to much amperage so the fuse blows. THe lid switch/fuse asm comes together and it should be replaced.
The part number for that switch assambly is 22001682 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 23, 2011 | Washing Machines
Maytag model ka806 won,t start. Could it be a safety switch or fuse?
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.Here is the part you need.
Dec 26, 2010 | Maytag PAV2300 Top Load Washer
My washer continually blows a fuse
If your machine is the Maytag stacked washer/dryer combo, there are a couple of areas I would look at. The first is the lid switch assembly. The fuse is a safety device designed to blow if the lid switch malfunctions. The two lid switches interact and if they don't both switch at the same time it can blow the fuse.
The second thing to try is to wash a load on cold water only and see if the fuse blows. See if there is a water supply issue. Check the water inlet valve. Remove the water supply hoses and check the small screens in the water inlet valve. Make sure they are clean and clear of rust or debris. Use a mulitmeter or ohmmeter to check the solenoids for continuity. A lack of continuity would indicate a faulty solenoid and the water inlet valve assembly will need replaced. These are a couple of things to consider. Hope this helped and best wishes.
Aug 15, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Maytag top loader MAV 8000MWW
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Checkto see whether power is getting to the washing machine. Is it pluggedin? Has a fuse blown or is a circuit breaker tripped?
Lid switch Ifthe lid switch is defective, your washer can't spin and may notfunction at all. The switch is inside the washing machine main housingnear the door frame. Often you have to raise or open the top or frontof the washer to get to the switch. If it's defective, you need toreplace it.
Some machines have a special lid-switch fuse nearthe lid switch, inside the control panel. If this fuse blows, the unitwon't fill with water until you replace the fuse.
Sep 27, 2008 | Maytag Atlantis MAV8000
Maytag MAH-24 door won't open
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Apr 26, 2008 | Maytag MAH2400A Front Load Washer
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Open Questions:
Maytag Commercial Non-Coin Washer, MAH21PND Logo
53 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
