Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Printing problems After I select print, the printer prints, but nothing is on the paper. When something does print, it is partially printed or fuzzy. I did the maintenance things on it, but it did not work. It does show that I need to reset the value for H and then it goes through the alphabet--I can have it go from 5 to -5 if I keep hitting the buttons. Thank you.
  • esaurangel Sep 21, 2008
    I have reinstalled drivers, replaced all ink cartridges and done ALL the maintenance numerous times but it still wont put anything on the paper.  It makes all the normal sounds that it did when it printed before.  No error codes. It just wont print.  Any suggestions?
  • mehta_hitesh Oct 15, 2008
    When I send print command. It goes to printer but nothing is printed - self test does not print anything. I did maintenance procedure but it does not print. I tried to photocopy a document, it initiates, goes through everything but paper comes out blank. any body can help?
When I select print I can only get color it wont do black and white.I have went through all the cleanings .It sometimes says cartriges are jammed but they are not.The ink is full Im not really sure whats going on with it.
Its a Canon MP730 Thank you
Posted on Sep 22, 2008
It is printing but the lettered is fuzzy
Best practice is to indicate device, brand, and model when querying about printers. Solutions vary by such often.
The blurring could be caused by the type of paper being used. Or, too much paper being in the printer. It can also be caused by substances adhering to the ribbon (where one is part of the setup). Then there is a potential problem with a fuser in a laserjet.
For example:
Printed documents print ghosted blurry grainy doubled or with smudges What...
How to Solve Common Printer Problems
Fuzzy Print HP Laserjet 4240 4250 and 4350 Printers
Aug 28, 2017 | The Office Equipment & Supplies
HP LaserJet 1007 Prints Light
First of all check your printing preferences
  1. Right-click the product icon, and click Printing Preferences to open the Printing Preferences window.
  2. Click the Paper/Quality tab.
  3. Check the paper or media type setting.
    1. Find the Type is: drop-down list.Figure 1: 'Type is:' drop-down list in the Printing Preferences windowc01855301.gif'Type is:' drop-down list in the Printing Preferences window, Paper/Quality tab (screenshot)
    2. Select the paper or media type you are using.
      • For thinner paper, select Light , Thin , or Vellum .
      • For thicker paper, select Heavy or Thick .
      NOTE:HP does not recommend the use of heavily textured paper, extremely thin paper, or paper with a basis weight heavier than 90 g/m2 (24 lb).
  4. Make sure the paper or media type setting is appropriate for the fuser temperature.NOTE:Unlike ink printers, laser printers use heat to fuse a plastic toner to the surface of the paper. Make sure to use heat-resistant paper, and labels and envelopes that use adhesives compatible with the heat and pressure of the product's fusing process.
    1. If you are experiencing any issues in the following list, adjust the setting.
      • If the paper is curled or wavy , try the following:
        1. Decrease the fuser temperature setting. To do this, select Light ,Thin , or Transparency .
        2. Use the archive print feature to improve toner fusing. To do this, select Archive or Bond .
      • If the printout has areas of fuzzy or dark print , or toner scatter , increase the fuser temperature setting.
        1. Select Heavy or Thick .If this does not resolve the fuzzy, dark print, or toner scatter issues, use a lower basis weight or thinner paper.
  5. Click Apply .
Step three: Check the print density settingsFollow these steps to check the print density settings in Printing Preferences and in Properties.
  1. In the Printing Preferences window, click the Paper/Quality tab, and find the Print Quality section.Figure 2: 'Print Quality' section in the Printing Preferences windowc01855302.gif'Print Quality' section in the Printing Preferences window, Paper/Quality tab (screenshot)
  2. If you are experiencing any issues in the following list, adjust the settings.
    • If the entire page is too dark , change the dpi setting, and turn on EconoMode .
      1. Select 600 dpi from the drop-down list.
      2. Select the EconoMode check box.
    • If the entire page is too light , change the dpi setting, and turn off EconoMode .
      1. Select FastRes 1200 from the drop-down list.
      2. Clear the EconoMode check box.
  3. Click Apply , click OK , and then close the Printing Preferences window.
  4. Open Printer Properties. To do this, right-click the product icon, and click Properties .
  5. Click the Device Settings tab, and find the Print Density section.Figure 3: 'Print Density' section in the Properties windowc01855303.gif'Print Density' section in the Properties window, Device Settings tab (screenshot)
  6. If you are experiencing any issues in the following list, adjust the setting.
    • If the printout has areas of gray shading or a gray background , decrease the print density setting.To do this, slide the bar to the left .
    • If the printout has light, dull or faded areas , increase the print density setting.To do this, slide the bar to the right .
  7. Click Apply , click OK , and then close the Properties window.
  8. Try again to print.If these steps do not resolve the light, dull or faded issue, the print cartridge is almost empty. Skip to Solution eight: Replace the print cartridge .
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , see the next solution.If this don't help you, here is instructions for refilling a toner cartridge.
Maybe you need to clean the drum, blades or the developer roller. Maybe the problem is in the toner you use.
Jul 08, 2012 | Office Equipment & Supplies
Making noise like its printing but nothing comes out on paper
Try to re-seat the cartridges in the printer. Open the printer cover > remove the cartridges > close the printer cover > re-brick you printer by pulling out the power supply - black box behind the printer where the power cord is plugged in, and re-plug after 10 seconds. When the printer turns on, reinsert the cartridges and close the cover. Try to print a document again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark 4800 Series folder.
  4. Select Lexmark Solution Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
Jan 21, 2012 | Lexmark X4850 WIRELESS All-In-One InkJet...
Handles paper fine but nothing prints. Carriage moves normally as though printing. No ink on paper. Cartridges are partially full.
It sounds as if your print heads are clogged. First try performing a deep cleaning from the Service menu. If this fails to clear your problem you can try to manually clean the heads but you may want to use Q-Tip's and Alcohol to clean the cartidge print head before you go to that expense.
Oct 31, 2009 | Epson Stylus C82 InkJet Printer
The printer can not print any paper
First of all we need to check weather it's a hard ware problem or software so try to copy something or press a self test page by pressing the x button and the colour copy button together if that prints fine then it means that its a software issue now click on the start button go to control panel then open printers right click on printers and go to properties print test page from there if it prints a blank page then go to the advance tab of properties and go to print processor then select "winprint" and in next line select RAW now try to print
if still the same then check the operating system if its windows Xp then it should be service pack 1 and above if you do not have service pack download the windows xp service and install it now try to print if still the problem persist then please post the exact model number of the printer and the operating system on your computer
Aug 10, 2009 | HP Office Equipment & Supplies
I just installed my new printer HP F4280, when gives print command in MS office it give error message MS office has stopped working
Hi Ahsan & Guest,
Thanks for sharing the problem with me.
Please first check printer installation:-
Start --> Printers and Faxes --> Right Click the printer --> Properties --> Print test page.
Problem might be Lose cartridge, Lose cable connections, Paper Jam, previous aoverloaded print que. Please Rectify all this.
There may be a hardware problem with printer itself please take help of printer technician in that case.
If this works, then start MS word, type something on page.
Click on print and select the right printer and print. It will work GoodLuck
Dear Guest, this problem might be in printing the web pages, please select all what you want to print or select nothing before printing.
Please see print preview to make sure that what you are going to print is rightly selected.
Zulfikar Ali
Jan 22, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer problem
The HP DeskJet printer will not print, it prints only partial pages, or produces ... remove the scanner, remove the printer driver, and reinstall the printer driver with all programs and ... the paper out of the printer after printing is finished. If one, or ... the kicker feet on your printer are broken, have the printer serviced. ... In tray only when the printer is not printing. Adding paper while printing can cause paper jams. Do ...
Jan 17, 2009 | Office Equipment & Supplies
Can't print custom paper size on HP Photosmart C6180
Printing anything other than 8.5" x 11" I have found challenging but there is a way around it. When you are ready to print select Print and go to
"Properties" button beside the name of the Printer.
Select normal for your print quality,
Paper source select Main Tray,
in resizing options select the size you need. In this case you would make a custom or perhaps the Card Envelope 4" x 6"
Select "Scale to paper size"
under the Resolution button there is a box "Show preview before printing" I select that so that I can see for sure before printing that it is recognizing my special paper and not the usual 8.5 x 11 sheet.
If it all looks good and it should, START PRINTING
You have to do this everytime you want to print a special size paper. If you print a lot of this size of paper custom name it something easy like your name"Krissy card env" so you can find it quickly and remember easily the process you follow.
Jan 07, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer Problem in HP-1280 Printer
go to printer folder , select properties and go to paper /quality , browse to A3, select, apply, OK
check print preview before sending your document
May 01, 2008 | HP DeskJet 1280 InkJet Printer
Partial printing of epson TM-T88III
what you can do is to make sure that from you application you should choose the right size of paper and on the printer driver go to its printing preferences and select layout, from there you must select the roll paper.
you should be well from there..
Dec 05, 2007 | Epson TM-T88III Thermal Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
old marine
old marine
