Question about Sony Cyber-Shot DSC-V1 Digital Camera
Easy way to use it.
My husband bought it and I do not know how to use it. Battery is charging and give me simple instructions to use it.
    Brigadier General:
  • 3,006 Answers
Hopefully you've already learned the basics by trial and error now, but if you want to learn about the advanced functions which give you full creative control of this camera then you'll need to read the manual.
I found the manual to be clear, well-written and very easy to understand.
You can download it from the following location:-
Posted on Jul 02, 2009
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
I have an vivitar dvr 805hd camera. My husband bought it and lost directions..... how do I charge the battery??? Dumb question, I know. Thanks
The battery charges through the USB port. Either connect the camera to a powered port on a computer or use the supplied AC adapter to plug it into a wall outlet.
You can download a copy of the manual from the manufacturer's web site at
Jul 19, 2011 | Cameras
I have a Panasonic KX-TG5633. It has worked fine for several years. suddenly one of the handsets no longer syncs to the base. I've followed the instructions to register it to the base, but it refuses to...
I am so tired of all the answers that don't help by repeating standard answers that you already know won't work or giving directions for a totally different product. The fix here is simple but not easy. It's either a bad charging/battery connection, a bad battery or both. Low power will cause the exact problem asked here.
As the phones get older, and I'm specifically talking about Panasonic cordless KX-TG563x but this may be true of other rechargeable devices, the metal contacts for charging and battery do not make a good connection like they used to. They may look perfectly fine and free of corrosion but are not actually making a good connection.
Symptoms include the phone getting hot while charging and not holding a good charge. The phone may show 3 bars of charge but still blank out like the battery is dying. With these Panasonic phones, weak battery will cause the phone to unregister and will give false charge level readings in the display. If your phone gets hot when charging, this is most likely your problem.
I had this problem with several handsets and used contact cleaner on the charge base, the phone contacts, the battery contacts inside the phone and on the battery itself. It fixed all the registration, heating and charging problems. I had one stubborn handset I had to clean multiple times but it's now working like new as well. I used DeoxIt contact cleaner from Caig, bought it on eBay. Great stuff. If repeated cleaning of the contacts with a good contact cleaner does not fix the phone, replace your battery. Use contact cleaner on your new battery for best connection. Ebay is a good source for replacement batteries as
well. Good luck!
Feb 11, 2011 | Panasonic KX-TG5633B Trio Cordless Phone
I bought a kodak easy share in Feb. I took it back to Best Buy they changed the battery. It still will not take a charge and we replaced the battery from the Best Buy store. Since I have only had it 8...
I know sounds stupid but, I had this problem with my laptop. For months I could not get it charged. My husband finally tested our outlet plug and realized it was no longer getting electrical power or not enough to charge since the light turned on to show charging I didn't think anything of it. Happened to be the outlet. Try another and see. Couldn't hurt right... Best of luck !
Oct 17, 2010 | Kodak EasyShare M1033 Digital Camera
I replaced mt battery on my 2004 jaguar x-type and the radio is locked i bought the car second hand so i dnt know the radio code and the factory code isnt working. what can i do
Simple contact you local Jag dealership and ask them, they will need the VIN No and there is a small charge (about £8). Then follow the instructions on to enter code.
Jul 22, 2010 | 2004 Jaguar X-Type
Battery won't keep charge
At that price point, these are completely disposable if giving problems. Otherwise, Contact your local retailer directly or online here: Support Cobra Electronics Corporation
Aug 02, 2017 | Cobra MicroTalk FRS 110-2 (14 Channels)...
Battery won't hold a charge after sitting for a while
First tell your husband to by a test light! They last for ever! LOL
The prob is most likely the alternator. Remove the negative battery cable, then the power cable at the alternator. With his 'new' test light, check for power between the negative battery post and the cable removed from the alternator. If the light comes on, the alternator has a diode prob. If you want you can also take it for a drive, then remove the battery cable, let everything cool over night, reconnect the cable, wait for about half an hour, feel the alternator for warmth. Frankster016
Nov 28, 2008 | 1995 Ford Windstar
Durabrand PDV709
According to the manual "the LED Indicator will flash when charging the battery and will be steadily on when the battery is fully charged."
If you would like a copy of the manual, I can sell you one for $8.99 including shipping to lower 48 states. If interested, email me at
warm regards,
Jun 22, 2008 | Durabrand PDV-705 Portable DVD Player
Invalid battery, and unable to charge
i tried changing my battery and it worked..if not you can always have it reprogrammed
Jan 11, 2008 | Motorola Mobility RAZR V3
Sony Cyber-Shot DSC-V1 Digital Camera Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
