Question about Mitsubishi WS-55859 55" Rear Projection Television
Green timer light blinking constantly, no picture
Green timer light blinking constantly reset doesn't help turned off power for twenty minutes, no help no picture
  • Anonymous Aug 31, 2008
    green timer will not go off. All instructions state what to do AFTER the timer goes off, but not what to do IF the timer light does not go off.No power and nothing else.
  • Mitsubishi Master
  • 8,617 Answers
You need the V21/V19 DM repair kit thats available at the following link, it contains the parts and step by step instruction CD so you can do the repair yourself. Its listed under their repair Kit category.
Posted on Aug 23, 2008
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Flashing green light
Did you try this yet
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
Big Screen Televison problem
1) pull chassis ( requires un-hooking extensive wire runs)
2) turn chassis upside-down
3) solder any / all bad connects,esp. regulator pins
Look for electrolytic capacitor leakage evidence =
dark,discoloration of trace material
4) replace any bad capacitors
5) re-install chassis and test
Nov 05, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Tv will not turn on but it constantly blinks and will not stop
You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
Aug 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
