Blomberg washing machine 1301abb I fitted a new door interlocking door catch. The old one was playing up so wrongly i pushed the catch down with a screwdriver thinking it may release it from sticking, plugged it back in and then shut the door a flash blue the plastic holder that holds the door cable out of its socket this usually sits in the circuit board above the door release button on the inside of the machine. Now there is no power not even the door light comes on. have i just blown that small circuit above the door release or has the main pcb board blown? nick hopkins
    Genius:
  • 2,028 Answers
There should be an in line fuse to keep from blowing the main board. Check this fuse, and also check the main board for scarring, electrical burns, or any other noticeable damage. If there is no noticeable damage, then I believe that you're going to have to replace the blown circuit in order to see if the main board was affected.
Posted on Aug 21, 2008
    Master:
  • 521 Answers
Its the main board problem.some thing has gone short.get the board checked with proper technician.it will not cost you much.thanks.
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
Door locked light flashes which prevents it from working
hi if your interlock is playing up this will cause this try giving a bit of push on door were catch is dont slam door if light stops flashing doors locked its good idear change interlock to do this take band from round door rubber pull rubber of rim take two screws out interlock you can get it through the gap unplug put new on should be ok then but try a push on door 1st when doing lock unplug machine hope tis helps
Jan 24, 2014 | Hotpoint WMA35 Front Load Washer
Hi, i have a hotpoint wf640 washing machine and i cant open the door.it seems like the catch has gone on the interlocking door as ive tried to push the door in but still no go. Is this something i can fix...
if there is water in the drum it wont open, so you need to drop the drain hose low to gravity drain....then the door should open. sometimes this fault is due to a broken door catch utube is quite good for fitting help.
Jan 08, 2018 | Hotpoint First Edition FEW12 Front Load...
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
Door won't open on wf000
Never reach inside the washing machine with it connected to the mains. The door interlock is always live!
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoint’s - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunged can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank You for contacting Fixya.com
Aug 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint few12 washing machine and have just replaced the interlock door lock as door locked indicator kept flashing even though door was closed,sometimes happened mid cycle,and had to open...
hi
check the spring on the door handle/catch,the easiest way to check this if you close the door and it indicates that the door hasnt locked,push the inner part of the handle towards the machine,if it locks then the spring is worn.(this is more commen than the interlock).
Aug 03, 2009 | Washing Machines
Hotpoint ultima wt741 F11 fault code
HI
  • A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
  • If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
  • A faulty door interlock
  • The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank you
Dec 06, 2008 | Washing Machines
My beko washing machine will not spin. the door does not stick shut which when turned on its ment too. not sure whether it has something to do with door or atual system
hello there it sounds like a door interlock problem
where the catch goes into the body of washing machine is the door interlock held by 2 screws turn electric of and plug out of socket and take lid of washer at the front of machine between drum and casing where catch goes in you will see interlock release cable socket and undo screws keep one hand on interlock so it does not drop down and take this with serial and model number to your washing machine spare outlet or currys parts master online
yours ross
Nov 21, 2008 | Washing Machines
DOOR LATCH DOES NOT CMPLETE INTERLOCK UNLESS PUSHED IN
hi billy
the most likely cause is probably the interlock switch has gained some play through wear an tear replacing it may solve it but first check that the door hinge hasnt been put out of alignment by the door being pushed open futher than needed. fitting a new interlock switch is relatively easy on most models www.espares.com might have it
hope this helps
Oct 25, 2008 | Frigidaire FWT449
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
