Question about Samsung DVD-V6700 DVD Player/VCR
Parental password set by my kids no one fessed up how do I reset it?
How do I reset the parental password on my vcr/dvd combo? its a samsung v6700. one of my kids set the password and no one recalls what it was and so I am stuck watching pg movies. I have pushed in every number i can think of and nothing works. can you help? the samsung website was not helpful at all.
  • 33 Answers
  1. From a cold start with no disc in unit, press the / button simultaneously on the front panel for 5 seconds.
  2. All settings including the password will revert to the factory settings.
  3. Don't use this unless absolutely necessary.
Posted on Mar 20, 2009
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
How do I reset the parental control password on a govideo dvd player?
Parental Control
Blocks playback of rated DVDs based on
their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP.
2. Select Others > Parental.
3. Select the desired Parental Control
rating from "1 Kids" to "8 Adult", then
press ENTER.
4. Enter your password using the 0-9
keys, then press ENTER.
• The factory default password is
3308. If you forget your password,
this will always work.
Password
Changes the Parental Control password.
2. Select Others > Password.
3. Enter your old password using the 0-9
keys.
4. Enter your new password.
5. Re-enter your new password and
press ENTER.
Mar 05, 2011 | GoVideo DV2150 DVD Player/VCR
I forgot the password to my samsung dvd player V3500. I want to reset it for no parental controls & i do not have the user manuel
If you forgot your password, press power on from a cold start
with no disc in the unit. Press the REW and F.F buttons
simultaneously on the front panel for 5 seconds. The "reset ok"
message will appear. Press the POWER button and the
DVD-VCR will go to the "Auto Setup" mode. (See page 13)
You can also download the manual on the link below. Just scroll down to product detail to download it.
http://www.amazon.com/Samsung-DVD-V3500-Progressive-Scan-DVD-Combo/dp/B00008N6YJ
Good luck
Nov 20, 2010 | Samsung DVD-V3500 DVD Player/VCR
Check firmware version Samsung DVD-V6700 DVD
Apr 10, 2010 | Samsung DVD-V6700 DVD Player/VCR
How do i program a remote for this product....i
Samsung.PartStore.com
or
Remotes.com
or
ak5900051b.jpg&size=16&dhm=121da6f5&hl=en SAMSUNG DVD-V6700 DVD/VCR REMOTE CONTROL
$14.95 new - NewRemoteControl.com
Oct 01, 2009 | Samsung DVD-V6700 DVD Player/VCR
Region code for Samsung DVD-V6700
Humm...have you tried going to www.videohelp.com to find a regon free hack? Just put your machines numbers in, hit search, scroll down to your machine. And see what they say-usually on the right side of the page.
Jun 19, 2008 | Samsung DVD-VR357
Samsung DVD-V6700 DVD Player/VCR Logo
226 people viewed this question
Henry  Thomas
Henry Thomas
