Question about Zanussi WJD1257W Front Load Washer
DRUM BEARING REMOVAL ZANUSSI WJD1257
Hi Advisor, I read your advice for zwd1470. I can't remove the allen bolt in the centre of the drum. Is the a technique to do this or is it brute force. Also its it a normal thread as I've figured I could be tightening it if its a reverse thread.
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
How to change back hub on 97 cr-v
Rear Brake Discs
  • Fotolia.com" data-type="modal">honda-rear-wheel-bearing-removal-1.1-800x800.jpg Replace the bearing and race as a single set. automotive roller bearing. image by Tom Oliveira from Fotolia.com
    Before raising the rear of your Honda, remove the dust cup from the center of the brake drums using a hammer and chisel. This will give you access to the spindle nut, which you can loosen using an axle nut socket. Then you can raise and remove the wheel/tire assembly ,or assemblies if you are replacing the bearings on both wheels.
    If your Honda model is equipped with rear disc brakes, remove the brake disc retaining screws, the brake hose bracket from the steering knuckle and caliper bracket mounting bolts. Hang the caliper to the coil spring using wire. Do not let the caliper hang free or the brake hose may be damaged.
    At this point, you will be able to remove the brake disc by hand. However, rust may have a firm grip on the disc. If this is the case, use a couple of 8-by-1.25 mm bolts and screw them evenly into the brake disc threaded holes. This will push the disc off the hub. Now you can finish removing the spindle nut and hub/wheel bearing assembly and install the new hub/wheel bearing assembly using a new spindle nut
Read more: Honda Rear Wheel Bearing Removal ' eHow.com http://www.ehow.com/way_5974291_honda-rear-wheel-bearing-removal.html#ixzz1W3WDRoqv Rear Brake Drums
  • Fotolia.com" data-type="modal">honda-rear-wheel-bearing-removal-2.1-800x800.jpg Pack the bearing with bearing grease before installation. roller bearing image by Tom Oliveira from Fotolia.com
    If your Honda Civic comes equipped with rear brake drums, remove the center grease cup and loosen the axle spindle nut using an axle nut socket. After raising and removing the wheel/tire assembly, finish removing the axle nut and washer.
    You might be able to remove the outer wheel bearing from the spindle using a screwdriver. If not, wiggle the brake drum as you pull on it to let the bearing fall off the spindle. However, the brake drum might be caught in place by the brake shoes. In this case, you can retract the brake shoes through the hole in the back of the backing plate.
    Remove the rubber plug from the back of the backing plate. Then rotate the star wheel on the adjusting screw using a brake adjusting tool as you push the lever off the start wheel with a screwdriver. With the brake shoes off the brake drum, pull the brake drum off the wheel assembly. Then clean the brake assembly with brake parts cleaner and a clean, lint-free towel.
    Now you can set the brake drum on a workbench or hard surface and remove the grease seal and inner wheel bearing. The inner and outer wheel-bearing races can be removed using a drift punch and hammer. Pack the new wheel bearings with high-temperature wheel-bearing grease using a wheel-bearing packer and use a new grease seal during installation. Also, before reinstalling the brake drum, apply a thick coat of wheel-bearing grease to the cavity inside the hub, but do not fill it completely.
Read more: Honda Rear Wheel Bearing Removal ' eHow.com http://www.ehow.com/way_5974291_honda-rear-wheel-bearing-removal.html#ixzz1W3WN9eBb
Aug 25, 2011 | Honda CR-V Cars & Trucks
Remove rear brake drums
Light Duty Models
  1. Raise the vehicle so that the wheel to be worked on is clear of the floor and install jackstands under the vehicle.
  2. Remove the wheel. Remove the three retaining nuts and remove the brake drum. It may be necessary to back off the brake shoe adjustment in order to remove the brake drum. This is because the drum might be grooved or worn from being in service for an extended period of time.
  3. Before installing a new brake drum, be sure to remove any protective coating with brake cleaner or a suitable fast-drying degreaser.
  4. Install the brake drum in the reverse order of removal and adjust the brakes.
Heavy Duty
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel. Loosen the rear brake shoe adjustment.
  3. Remove the rear axle retaining bolts and lockwashers, axle shaft, and gasket.
  4. Remove the wheel bearing locknut, lockwasher, and adjusting nut.
  5. Remove the hub and drum assembly from the axle.
  6. Remove the brake drum-to-hub retaining screws, bolts or bolts and nut. Remove the brake drum from the hub.
To install:
  1. Place the drum on the hub and attach it to the hub with the attaching nuts and bolts.
  2. Place the hub and drum assembly on the axle and start the adjusting nut.
  3. Adjust the wheel bearing nut and install the wheel bearing lockwasher and locknut.
  4. Install the axle shaft with a new gasket and install the axle retaining bolts and lockwashers.
  5. Install the wheel and adjust the brake shoes. Remove the jackstands and lower the vehicle.
// // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 32; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]>
May 08, 2011 | 1991 Ford F250
How do you rmove rear brake drum 2004 frontier 4x4
Hope this helps.
Good luck,
Removal & Installation
  1. Remove the hub cap and loosen the lug nuts.
  2. Raise the rear of the vehicle and support it on jackstands.
  3. Remove the lug nuts, tire and wheel.
  4. Release the parking brake.
  5. Pull the brake drum from the hub. If difficult to remove try the following:
    1. Strike the face of the drum with a plastic or rubber mallet. This will break free any rust that may develop between the drum and the hub.
    2. Install 2, M8x1.25mm bolts into the holes in the drum and gradually tighten them to pull the drum off the hub.
  6. 0900c152801a5f72.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Install and tighten 2 bolts to remove a stubborn brake drum
To install:
  1. Install the brake drum to the hub.
  2. Install the wheel.
  3. Remove the jackstands and lower the vehicle.
  4. Road-test the vehicle to ensure that the brakes are working properly.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the brake fluid, as necessary.
  3. Release the parking brake.
  4. Raise the vehicle and support safely.
  5. Remove the tire and wheel assembly.
  6. Pull the brake drum from the hub. If difficult to remove try the following:
Oct 23, 2009 | 2004 Nissan Frontier
I need to replace the bearing in an AEG Lavamat 1450. I've taken the back off the machine, but there isn't a traditional "spider", just a round wheel type thing attached with an Allen bolt. Can I have some...
Hi there.....unless your exerienced in this area...id advise you to seek expert help...the drive wheel securing bolt is of the torx type and requires a secial torx key to remove it....you will find that the outter drum has a series of torx headed screws around it which have to be removed and then the drum split...only after this has been completed and the inner drum removed will you have access to.the bearings.......
regards Sir Galahad
Aug 20, 2009 | Washing Machines
How easy is it to change the drum bearings on my indesit wil163s?
you will need to remove the pulley first, the screw in the middle will need a knock to release the loctite.
you will then need to remove the spider assembly, that's the metal cross the bearings are sitting in. there are bolts set around the drum. spray the bearings shaft with oil to help removal, and you may need to hammer the spider as you remove it to loosen it. be careful of the heater.
then knock the bearings and seal out and do the reverse proceedure to put back together.
Feb 27, 2009 | Indesit W 123 Front Load Washer
Removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Hi.. hope you can help me.. I have a year old Zanussi ZWF1221W - my dear daughter put in a wash without emptying her pockets and something (a hairgrip or bra support) is now stuck between the drum and the...
It sounds like it's actually stuck between the bottom of the agitator and the basket (assuming you've got an agitator). The top of the agitator is usually for bleach or maybe it's fabric softener. Pop off the top (like the lid off of a can) and that should expose a nut or bolt in the center of the agitator. Remove this bolt (make note of how tight it was just after you've broken it free) and lift to remove the agitator. Remove any foreign objects and feel free to clean up anything else down there. Replace the agitator and tighten the bolt approx as tight as it was when you removed it (be careful not to overtighten). Snap on the top of the agitator and you should be good to go.
Mar 18, 2008 | Washing Machines
Drum Bearings replacement
This is Mogsey above, I have now renewed the bearings in my Zanussi Jetsystem 1600, Model FJD1666W. Had a man in to help. It really is a two man job and I put my back doing this with him. The bearings were much larger than previously encountered. Very! basically you have get out the residue water, release the door seal and (pipe attached) spit the m/c casing, unclip all hoses attached to drum, unclip all drum wiring ,remove belt (note position) remove motor &, lay to one side, withdraw nylon pins from shock absorbers, Look for and remove the little earthing cable set just inside the pulley rim. Carefully release drum/case supporting springs (mark positions top and bottom) and, drop drum/case onto some blocks and lift/pull/take out (really needs two people) (minding other modules). Split drum/case ring of bolts, remove front half (careful here not to damage the heater). take half containing drum outside, lay drum face down and use a drift to hit the socket headed screw securing pulley hard to shake up the taper. Remove this screw (needs good quality allen key) and use wedges to the force off the drum drive pulley. Support drum casing on blocks or put drum on its side, support the drum if on its side and use a heavy drift and hammer to knock through the drum spindle. Careful now to avoid grating hands on the sharp drum holes. With drum now removed place the casing drive end up (ensuring protuding heater is clear of the ground!) put a large bolt (head down) inside the first bearing and rest it on the edge of the inner bearing. Carefully working round the inner bearing edge use a hammer and the bolt head as a drift to knock out the inner (the larger of the two bearings and inturn the drum seal) (note seal postion). Turn over the casing and knock out the outer bearing from inside the drum casing. Clean all and check condition of spider/spindle & renew if damaged. Fit the new outer bearing then the new inner followed by the seal. Dig out the old and renew the (green) O ring seal between the drum casing halves. Replace all, but give a quick test run before replacing casing to ensure belt is positioned correctly. The job would have cost £115 which I think is well worth paying someone to do.
Dec 02, 2007 | Zanussi FJD1666W Front Load Washer
Replace drum bearing
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi WJD1257W Front Load Washer Logo
83 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Chris Hall
Chris Hall
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
