Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Need help my oven is not working, the self cleaning works fine, the broiler also works, but the oven will not heat. what can i do? Our Kenmore gas range will not heat to the proper temp. The oven ready beeper goes off in about 3 minutes and displays 350 which the internal temperature is not. There also seems to be excess heat coming from the vents under the top of the stove, (under the timer, clock etc.). This could be something I just never noticed.
  • Kenmore Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 30, 2010
My GE xl44 gas range broiler won't work,
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Kenmore gas range, burners are working fine. Stove is not working, front panel, clock/timer..panel is off...
Hello there:
Please read the entire solution i have provided it doe4s cover things that you have said has already been checked but there is more to it
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician. The clock stopped The non-electronic clocks on gas range/ovens often don't last long. That's a problem, because the clock is essential to the self-cleaning and timed-bake features. Clocks are rarely repairable--you usually just have to replace them. Electronic clocks have been more reliable. But, they're often integrated with several other features of the range/oven. So when the clock develops a defect, it often renders the entire oven and broiler inoperative. The electronic clock is usually integrated with a circuit board, and the touchpad that holds the buttons you press is often a separate component. If your electronic clock is defective, you may need to replace the touchpad, circuit board, or both. Although these may be expensive, they aren't usually very complicated to replace.
Sep 28, 2010 | Kenmore 78733 Gas Kitchen Range
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven Problem I have a Kenmore 79012 Range. The burners and broiler work fine. The ignitor comes on in the oven, but it will not light. After a few minutes I can smell gas, but the ignitor is still...
the ignitor has to be on before the gas valve opens up and until the stove recognizes a flame, if it doesnt the gas will shut off and the ignitor will cool off, If you use the self clean setting to clean the oven you will destroy the ignitor much faster because they are only rated for about 1000 degreese for just a minute and self clean keeps it around 800 for an hour or so. You may just need to replace the ignitor.
Jul 28, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Oven will not heat up
we have the same problem. Broiler ignites fine and turns on and works fine but the bottom will not come on. AS POSTED BY: JSROCK516 This usually is an indication of a bad igniter. If this is the standard glow type igniter, it could appear as if it is working, but may not be providing enough current to open the gas valve. This is a safety feature on gas ovens. The gas valve requires a current potential of .32 to .37 amps through the igniter before it will open and allow gas to flow. This prevents gas leakage if the igniter fails to light. The reason your broiler works is probably due to the fact that the broiler gets used less and the igniter is probably in better condition. You can test this theory, if you like, by swapping the igniter for the bake and broil burners to see if the symptoms change. Or, you can simply just replace the bake igniter with a new one. Make sure you secure the power before attempting, though. You shouldn't have to turn off the gas for this. Chances are that's all it is. I hope this helps you.
Sep 05, 2007 | Kitchen Ranges
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
137 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
