Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck XL2 Ultra
Any suggestions as to why this vacuum will not turn on? The switch doesn't seem loose and the cord seems to be connected where it should be. I have tried different outlets in my home. I believe this vacuum is about 5 years old. Thanks.
Pat Noonan
  • Anonymous Aug 24, 2008
    I have the exact same problem and mine is only 2 years old.
  • tiffwebb Oct 15, 2008
    my vacuum fell backwards and suddenly won't turn on again. Power light not coming on when plugged in, but nothing seems loose. Help?
I have the same problem and mine is less then a year old.
Posted on Aug 26, 2008
  • nsunshinedes Aug 27, 2008
    My oreck would not turn on. I took the handle apart so I could get to the switch. I noticed there was a wire connector off, I re connected the wire and the vacume turned on with no problem. Good as new!!
I was vacuuming and the vacuum just stopped running. The cord is fairly new so I know it isn't that. Any suggestions?
Sometimes when the small pipe from the motor fan gets plugged up the motor will overheat. For safety reasons, the motor shuts off. If you able to start up the vacuum later, and the suction is not great, then follow the owner's manual to unplug the hose. It is not difficult, but it does require disassembly of the sweeper part of the vacuum. Make sure that you unplug the machine before you try to make any repairs. I have had to do this myself on occasion when the vac seemed to lose suction power. Another problem might be that you vacuum bag might be too full.
Since you mentioned that the cord is fairly new, I will make the assumption that you replaced the cord. If that is the case, then make sure the cord is unplugged from the wall, and check the connections of the cord to the vacuum. One of the wires might not have been attached properly and worked it was loose. This can happen especially if you pull hard of the cord when vacuuming. Oreck's come with a fairly long cord, but you still have to plug into a socket when you run out of cord.
If either of those suggestions does not work, then I recommend a service call to a local repair center.
Jul 16, 2011 | Oreck XL Ultra Bagged Upright Vacuum
How to tell if switch bad..xl2 stopped working
If you have power in the outlet and the vacuum does not come on 9 times out of 10 it is the switch especially in the oreck or if the switch feels like there is no snap or click when turning on and off
Nov 20, 2010 | Oreck XL2600 Vacuum
Oreck XL2 does not start.
There could be a problem with the cord. I suggest taking it to a local vacuum shop to have it inspected as that could be the problem
Apr 13, 2010 | Oreck XL2000 Bagged Upright Vacuum
Simply won't turn on!
I believe all Oreck vacuums have a lifetime warranty. You should pursue that.
Mar 11, 2010 | Oreck XL2200 Bagged Upright Vacuum
I shut my vacume off to change its bag out. Now it won't come on. Oreck xl2. There were no noises before turning it off or any smells of rubber burning. Just won't come back on. Is there a reset button....
An access panel mounted atop a vacuum nozzle base via finger operated latches. When the latches are undone the access panel is removed from the top surface of the nozzle base allowing access to the parts of the brush assembly. The panel also has an integral arm which engages a safety motor switch such that when the panel is removed the motor switch is switched into an open circuit position preventing the motor from continued operation
Sep 23, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My orek has no power it won't turn on
the spade connections are loose, take the handle apart and check them
Jan 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The vacume will not turn on
the spade connections inside the handle have come loose. take the screws out and connect the wires back. thats it
Aug 26, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring
Here are the 4 different wiring for new Oreck motors.
Apr 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
360 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
