Question about Whirlpool GHW9150 Front Load Washer
Whirlpool Duet Ghw9150pw1 would not start
I have Whirlpool Duet Ghw9150pw1 front loader and it has been working fine for 2 years and now it started to act strange..
it would not start. i have clothes in there, door is closed, i press control button and press and hold Start and notthing happens.. Machine would not start, but all the lisghts are on (washing time and etc..). what can i do?
thanks in advance
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Manual for Whirlpool front load washer #GHW9150PW1
Many Whirlpool appliance manuals are available here: http://www.whirlpool.com/manuals/ . Use the search function to find your model. The direct link to the manual for the GHW9150PW1 is currently http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%208182674.pdf . Sears Parts Direct also has the manual; the direct link is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0606369.pdf .
I hope this helps.
Oct 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool front loader Model GHW9150PW1.The drum seems to be wobbling real bad and dragging the bottom of the washer,can you help.
First, remove the 2 screws that hold the bottom front kick-plate on and remove the plate. Look to see if any of the shocks have come loose or broke. Post back your results.
Jan 20, 2013 | Whirlpool Washing Machines
I have a whirlpool Duet Front loader Washer Model GHW9150PW4
there is a book inside the washer in bottom or back that gives you the trouble codes
Jun 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet Washer Model GHW9150PW1 Control Locked
I had the same exact problem, the answer is in the User's Manual for this model Dryer, also here: The Users Manual reads: "TO UNLOCK": Press and hold the END OF CYCLE button for 3 seconds to turn this feature off. I did this and it worked perfectly the first time! My first load is drying now after months of being without the dryer (too busy to investigate!). Good luck.
Oct 26, 2009 | Whirlpool Washing Machines
Screw stuck in door seal drain hole Whirlpool Duet GHW9150PW1
Magnet my friend :)
Jun 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PW1 very noisy when spinning
its most likely bad bearings and basket. usually it happens over wear and tear or overloading.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
315 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
