Question about Hampton Bay Heating & Cooling
Air Conditioning My husband cleaned the air and know it does not keep the room cool at all did before reason for cleaning it was so it would not use so much "elec." He cleaned it the sameway, He did last time about a year ago and it worked perfect. So he does not understand what happen. All I know is My Dog's and Puppies are dyeing from the heat. We live in Duncan,Arizona and it is going to be over 100 degree's today It totally sucks I of cause have a few other choose words but we willnot go into that now will we Ha Ha!!! Please help us resolve this problem if you are able We ara all bankig on You Think You LaVienna
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Is this a 110volt unit or a 220 volt unit? Is this a central or window unit? but the way you describe the cleanning, must be a window unit! there is suppose to be 2-sounds from this unit ,,,1--the fan blowing sound,,,,2---the compressor humming sound.! the compressor kicks in by the thermostat control knob, turn this to the highest setting &listen for the compressor to kick in. if not the compressor is not pulling in..(burnt wire, bad capicator, locked compressor, bad thermostat switch, ) but don8t let that scare you, just have someone to check it out,,or let me walk you through the troubleshooting process,@ koolbreezes74401@yahoo.com... did anyone tell you window units are called the"throw-a-way " type?
Posted on Aug 21, 2008
Why isn't it cooling the room?
A few months ago my air conditioning unit was having cooling issues too. However, the mechanic that came and fixed it said that it was because we constantly blasted it and kept the temperature really low. How cold are you trying to keep your room? Sometimes it has to do with the system freezing up from trying to keep it too cold. Air Conditioning in Chetek WI Stellar Heating Solutions
Dec 17, 2015 | Heating & Cooling
WHAT IS THE MINIMUM TEMPERATURE OF COOLING
most home air conditioners go as low as 18 c but this low setting achieves nothing but a high power bill
the purpose of air conditioning ( air conditioning -- to condition the air) is to remove the humidity ( water vapour ) form the air and allow the body to perspire more freely and so is by the evaporation of the perspiration of the body water that cools the body
this evaporation is hastened by the fact that the water vapour in the air is very low due to the air conditioner operation of conditioning the air
Now knowing this fact it is obvious that all the windows and door should be kept closed ( to remove the humidity from the room /house and so a setting of 25-26 c is sufficient to keep you cool
because the temperature difference between outside air and room air is low the air conditioner cycles less frequently and costs less to run
if the room setting is at minimum and the atmospheric temp is high then the air conditioner is running virtually all the time
so instead of asking what is the minimum temp you should be asking what is the optimum temp run to be conformable and to save on power costs
Jun 26, 2015 | Heating & Cooling
Blows very cold air during dehumidify mode.
se this fact: God bless you
air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
Sep 30, 2012 | Heating & Cooling
The heat sistem is not working well is working but 30% of eficency than it was working beafore.It hear like water on it ..help im frezzing
Air conditioning real definition is not giving cool but removing heat from the room. In same way for heating, it's not heating, removing cool from the room. When your indoor coil, air filter and blower wheel are full of dust, you won't get even 30% of cool or heat depend on your selection.
Simple solution for your problem is clean indoor unit completely. Check all sensor is working well. In heat mode keep temp minimum +3 degree than room temp. thanks and helpful.
Jan 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
May 17, 2009 | Heating & Cooling
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running...
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
Sep 10, 2008 | Amana Heating & Cooling
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
Heating & Cooling Logo
71 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
