Question about Dryers
Tumble dryer keeps stopping
Keeps saying empty water, only goes for 1 minute then stops, all water has been emptied and no fluff inside, please help reslove. thanks
  • 351 Answers
Check the drain pump it may be blocked or faulty
Posted on Aug 27, 2008
My new tumble dyers stops after 10 minutes telling me the water tank is full, when its empty
Since it is new, I would call the mfr and have them look at it. It is under warranty isn't it?
Jan 11, 2015 | Zanussi Dryers
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
My zanussi dryer keeps stopping saying water needs emptied but it is always empty. The vent valve is always falling out is there supposed to be something to stop this?
I read the posts then checked my drier. I found the valve at the back of the water tank was blocked with fluff. So I tilted the dryer and unscrewed and removed the valve so I could remove the trapped fluff. Problem solved.:-)
Jan 16, 2012 | Zanussi Dryers
8kg Candy Condenser dryer keeps stopping and telling me the water compartment is full - trouble is , it isnt. is there a sensor that tends to stick on these models? Thanks, Andrew
Hi Andrew, Nothing I found on-line worked. So tonight I had a good look. Inside the machine at the back of where the water caddy fits there's a reservoir. This was full but oddly the water caddy was empty. On the caddy there's a spout with a valve, inside it was fine dark fluff which was being compressed every time the caddy was reinserted. I picked this out with a little stick. I also, and this may not be necessary, removed the valve socket that the caddy valve goes into. It's attached by three screws to the bottom of the machine. This was also clogged with the same sort of fluff. Both blockages were stopping water passing freely into the caddy and so water built up in the reservoir tripping the empty light. Something to check for. Anyway mine works fine now and thought I'd share. Best regards, Ed
May 04, 2010 | Candy CDV262 Dryer
I have a bosch WTE86304GB/03 tumble dryer red light says empty container, but container is empty, machine keeps stoping and flashing this light on ?
Hi the problems is not a sensor its the codenser unit. Above the water collector should be a panel on the front of your machine, open the panel and you will see the condeser.covered in fluff, simply remove the condeser and clean it under an outside tap after removing as much fluff as possible by hand. Push back into place when clean and hey presto back to new again.
Feb 23, 2010 | Dryers
Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Dec 31, 2009 | Hoover Dryers
Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Dec 05, 2009 | Hoover Dryers
LG TD C70045E problem
Fluff has blocked the drain hole into the water drawer.Try locating the hole and using a small bore plastic tube **** the debris out of the container.
Feb 21, 2009 | Zanussi TC7102W Electric Dryer
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
Dryers Logo
441 people viewed this question
Top Dryers Experts
