Question about Apple iPhone Smartphone
Iphone restoration error (1601)
I have upgraded the firmware from 1.1.4 to 2.0.1 in itunes and the iphone got locked.but now while I try to dongrade to 1.1.4 I am getting the error (1603,1601,20(in restore mode).pls help............................................................
  • 5 more comments
  • sjvnsodv Aug 23, 2008
    I tried this earlier but it was unable to load the ipsw file.And it says that it is an unknown file....Pls help me with the other way
    Thanks for your post.......................
  • Anonymous Aug 23, 2008
    iphone restoration error (1601) problem in itunes while restoring firmware.and while using winpwn ipsw file is getting detected as unknown file ........pls help..............................
  • sjvnsodv Aug 24, 2008
    even I am not able to restore the iphone in itunes while giving shift+restore (1.1.4 or 2.0.1) and I got this error 1601.Actually I had upgraded to 2.0.1 from 1.1.4 directly in itunes. So Pls help
  • Phil-Br Sep 13, 2008
    Subject: Error 1601.
    We have 3 iPhones in the house. They were all bought with firmware 1.1.4, unlocked and jailbroken.
    I updated/unlocked/jailbroke mine to 2.0.1 using a previous version of WinPwn. Needed a few fixes (Caller ID fix, BrFix, etc), but worked pretty well.
    A few days later I went on to iPhone #2. iPhone firmware 2.0.2 was out and so was WinPwn 2.5. We tried it. Worked very well, iPhone #2 is fine and working. We were feeling safe with the procedure.
    iPhone #3 was the unlucky one. Same software (firmware 2.0.2, WinPwn 2.5), same procedure as iPhone #2. Only this time it didn't work. My father did this one alone so I didn't really follow the details. He tells me it worked, but then he messed something up installing third party **** and decided to do over.
    After do over, iPhone has gone "dead", the screen never lights up. Restoring from iTunes always ends with error 1601. We have clared the PC (Win Vista) from iTunes and any trace of Apple software, reinstalled iTunes 7.7.1.11 and tried a Restore with clean IPSW, with custom IPSW, with 1.1.4 IPSW, with 2.0.2 IPSW.... Nothing works... Is this what they call a "bricked iPhone"??? It sure feels like one.
    HEEEEEEELP!!!
    Thanks a lot!
    Phil
  • messedupboy Sep 18, 2008
    my iPhone has the same problem.. i updated my 1st generation (1.1.4) iPhone to 2.0.1.. it shows a connect to iTunes logo whenever i turn my phone on.. it has been in this state for nearly 2 month.. i've tried to restore it.. but iTunes keep poping up with the same message :"iTunes unable to restore iPhone. Error(20)."
  • Anonymous Mar 23, 2009
    i upgraded my software on my iphone and all it will let me do is make an emergency call how do i get the old software back so i can use my iphone again
  • Anonymous May 04, 2009
    iphone having an error 1601
I found a solution!
It worked for me and many others (who posted their gratitude on the original post).
Below are the instructions you have to follow. If you have disconnected your phone or shut your iTunes, don't worry. I did it. I even reinstalled iTunes a few times and shut down the computer as well.
Here it goes:
"The way to get over the 16xx errors while restoring on any firmware is this:
Once you get the error DONT DISCONNECT IPHONE OR CLOSE ITUNES. Which leaves us with only one option, rESTART Iphone. STEP BY STEP GUIDE FOR VERSION 2.0.1:
1). You get the error. (Ofcourse)
2). DONT TURN OFF ITUNES. DONT DISCONNECT IPHONE CABLE.
3). If the phone is still on, reboot/restart the phone. If its off then kick it out of DFU mode which is explained in the NEXT step.
4). Press and hold the power and home button for some time to kick the phone out of DFU mode.
5). Itunes will detect it again.
6). Now try to simple-restore it, that is click on the restore button on itunes while pressing the shift button of your keyboard. YOU WILL GET THE 16XX ERROR AGAIN IN 5 MINS !!!! but dont worry, everything is under control.
7). now your iPhone will have the picture of the iPhone cable on its screen. good.
(DONT TURN OFF ITUNES. DONT DISCONNECT IPHONE CABLE.)
8). NOW put the iPhone it in DFU mode. How? Firstly turn the phone off (it might try to start up on its own again but turn it off again). Once its off, Press and hold the power and home button for 10 seconds, then release the power button but keep the home button pressed for another 10-20 seconds till itunes recognizes your phone.
9). NOW restore the phone by selecting the pawned custom firmware that you created and you will NOT get the 16xx error.
ENJOY."
I got this solution from here:
http://www.modmyifone.com/forums/pwnage/281841-error-1601-help-please.html
Hope it works for all of you.
Cheers!
Phil from Brazil
Posted on Sep 13, 2008
  • 3 Answers
I tried everything and the only thing that worked for getting error 1601 was to use a diferent computer. everytime i tried using my laptop running windows 7 i would get the error after the iphone went white. first time i used my desktop running xp it worked perfectly fine
Posted on Dec 06, 2009
Using winpwn.. u have to use expert mode and change ur partion size to more than 700... works 100%
Posted on Jun 28, 2009
    New Friend:
No power on
Posted on Apr 02, 2013
    Problem Solver:
  • 5 Answers
Hey guy, you need to uninstall the current version of itunes and install itunes 7.5, shift restore works there, however if you have upgraded to 2.0.x you probably upgraded your baseband as well which may result in another error during restore. to get rid of that error just restore your iphone twice and kick it out of the DFU mode using iliberty at the end of the second restore. worked for me.
Posted on Aug 29, 2008
I tried hard but I was unable to load the file into winpwn.It's saying as unknown file after using the build ipsw button.......
Pls help.......................any way thanks for your support
Posted on Aug 23, 2008
  • 3 Answers
1st install winpwn 2.0.0.4 and then ahh just go to this website
http://www.iclarified.com/entry/index.php?enid=1572!! try doing the steps its hard but try
Posted on Aug 22, 2008
  • han_mun223 Aug 23, 2008
    shift + restore click on 2.0.1 5b108 and then download quickpwn and ahhh just try this too this will work 100% but it will take 1hour+http://www.iclarified.com/entry/index.ph...
  • han_mun223 Aug 24, 2008
    when you restore it to 1.1.4 it will give u error code 1600 something then you can use Ziphone to unlock jailbreak and activate it it will be easy
    http://www.iclarified.com/entry/index.ph... go to this website!
My iphone 3g wont turn on at all when i connect it to my pc it wont recognize it but when i hold the power and home button for ten seconds and the home button for 8 it recognizes in itunes but screen on...
This looks like it will probably end up being an internal logic board processor/chip etc malfunction.
restoring from a different computer,
Things you can try are restoring it from a custom firmware,
or maybe even putting into dfu mode and try to jailbreak the device, but that would be a last resort.
let me know if you need help in trying these steps I have given.
hope this helps,
Zach
Dec 26, 2010 | Apple iPhone Smartphone
Tip
How To Fix 1601, 1602, or 21 Error Codes During iPhone 3.1.2 or 3.1.3 Custom...
Are you trying to downgrade or restore your iPhone or iTouch from the official 3.1, 3.1.2 or 3.1.3 Firmware to a Custom Firmware and your iTunes displaying the following 1601, 1602, 16xx or 21 error codes? iH8sn0w has just released a utility named iREB (iTunes Restore Error Bypasser), which provides a workaround to fix these errors.
iREB is available for both Windows and MAC Operating systems. Tool runs on both iPhone & iPhone 3G with Firmware 3.1, 3.1.2, 3.1.3, and also on iPod touch 1G and 2G.
So here is the work around for 1601, 1602, 1604, 16xx or 1621 Error Codes…
New version of iREB is out for 3.1.2 Devices… If you’re upgraded to the latest firmware (3.1.2 or 3.1.3) you should use this download / tool for the errors you’re experiencing. New version has additional devices and more options available.
1. Download iH8sn0w’s iREB 3.1.2 archive for Windows or Mac.
2. Start iTunes and put your iPhone in Recovery Mode; to do so, hold Home and Power button in your iPhone simultaneously and release Power button after a while (10 seconds approx). Keep on holding Home button, till you see following error message appearing in iTunes stating.
3. Now close iTunes and start iREB, following interface will open.d00f484.png
4. Now select your plugged in device in iREB 3.1.2 and it will then show the White creen after few seconds. This happens fast so if you didn’t see it don’t worry… You will also hear sounds (maybe) like your iPhone is being plugged in and unplugged from your computer… That’s normal… The ih8sn0w.exe will crash… That’s normal, as long as you get a white screen…
5. NOTE: If you still don’t see the WHITE screen, you should do this… While the device is still plugged in and iREB running, put your device into the DFU mode. PRESS and HOLD both buttons on your iPhone for 12 Seconds and then release the POWER button (Located at the top of your Device) while still holding down the HOME button… Hold down the HOME button for 30 Seconds… (Yes 30 Seconds) until you get the WHITE Screen, the iTunes will come up with a message stating it found an iPhone in Recover Mode… At this point you can let go of the HOME button… you will be asked to restore this iPhone… and the iREB tool will crash
6. Now start iTunes again and select your device (iPhone/iPod) from iTunes DEVICES tab.
7. To restore original settings on your Apple device, press and hold left “OPTION” button on the keyboard (“SHIFT” button for Windows), iTunes will give you option for Upgrade and Restore, click on “Restore” option in the iTunes and then release the “OPTION/SHIFT” button. Select .ipsw file and restore it
on Jul 08, 2010 | Cell Phones
Error 1604 and Kernel Panic
confirm that your firmware is compatable with your iphone.
if you have a 2G the firmware should start with 1.1 if you have a 3G the firmware should start with 1.2
apparently unlocked or jailbroken phones with the wrong firmware will brick in this manner.
not to worry, your not the only one.
do a web search for error 1604 and you will see solutions such as this below.
  • Problem: I cant restore my custom firmware. I just get error 6, 1, 2, (something low).
    Solution: This has multiple causes. Generally, you are not in DFU mode. See DFU guide. Winpwn solution after ruling out the above: Delete the device file (x12220000_4_Recovery.ipsw) in your iTunes folder. (Search for the file). This can also be caused by using the incorrect firmware image (a 3g on a 2g for example).
  • Problem: I am in DFU mode and I just get error 1604, 1602, 1601 (some 160x). I am pulling my hair out! What do I do?!
    Solution: This one sucks. There’s no single answer for it. Here are some possible suggestions:
    • Validate you are using the correct firmware. You can get this if you are using an incompatible firmware (3g for 2g for example).
    • Restart your computer and try again.
    • Try another computer
    • Try switching USB ports
    • Uninstall and reinstall iTunes 7.7
If you are not able to get out of DFU mode even after trying one of the above fixes, click here to follow the comments on BigBoss’s website.
Apr 17, 2009 | Apple iPhone 3G Black Smartphone
Error 16xx
I would suggest reseotring it once more and trying to use quickpwn again. If it fails you may alternatively want to use Winpwn, it basically does the same thing.
Winpwn: http://www.winpwn.com/index.php/Main_Page
Feb 18, 2009 | Apple iPhone Smartphone
Iphone cannot restore with itunes
Try the following links:
http://amountaintop.com/error-1604-when-upgrading-your-iphone-version-1-1-1
http://support.apple.com/kb/TS1458
Oct 22, 2008 | Apple iPhone Smartphone
Can't restore to my iphone from 2.0 to 1.1.4
Try this tijanotu:
You will need these files/program:
1. Ziphone 3.0 program
2. Ziphone Firmware Files 1.1.2, AND 1.1.4. To get these files open Ziphone 3.0 then Click Help and Support, then middle box on top of page Web Links Firmware Files 1.1.2 and 1.1.4 (to make it easier to find I always save everything to the desktop)
3. Kiphone http://www.iclarified.com/entry/comments.php?page=1&enid=1536#commentsanchor
Not sure if all these steps are needed for success, I am just putting it all down becuase this is exactly what I did to get my cell signal back.
First, I uninstalled itunes 7.7.
Then I downloaded and installed itunes 7.5. At this point you will have to rename your itunes libray folder. Instructions are here: http://www.iclarified.com/entry/index.php?enid=1504
Next I downgraded the iphone to 1.1.2 using the link above.
Downgrading steps:
Connect phone to computer
Open Ziphone 3.0
Click on Prepare for Upgrade (this will put iphone into DFU mode)
Now you have to restore using itunes 7.5 (which will open up as soon as the iphone goes into DFU mode.)
In itunes hold down SHIFT key (FOR WINDOWS) while pressing RESTORE. This will allow you to browse for the firmware file 1.1.2 you previously downloaded. Click on the 1.1.2 restore file and hit OPEN. This will begin the restoring process.
You will probably get an error code noting the restore wasn't successful. Ignore this unless the error code number is in the 1600's.
After this I tried to jailbreak my iphone using Ziphone 3.0 but wasn't successful so I:
Repeated the restore process but his time restoring to 1.1.4. Got the same error saying that restore wasn't successful, which I ignored.
Then I closed itunes, went into Ziphone 3.0 (iphone still connected to computer) and clicked on Do it all!
Jailbreak worked fine except I still had no cell signal.
To fix this I went to:
Iclarified, (the BEST iphone website *******!!) Got Kiphone patch (see Number 3 above) installed it and got my cell service back.
Jul 14, 2008 | Apple iPhone Smartphone
Help error 20
i had the same problem what i did was installed firmware 2.0 on my iphone but i could not unlock it what i did then was uninstalled itunes 7.7 and installed itunes 7.5. Then i put my iphone into Recovery mode , which can be done by pressing both the home button and the power button down until the iphone turns off and then once it had turned off i released my finger from the power button still holding down the home screen button. Then once itunes had recognised it was in recovery mode i held down shift and clicked on restore at the same time. for this u need have the iphone firmware 1.1.4 download u can find this by going to http://www.iphoneatlas.com/2008/02/26/iphone-software-114-released/
and clicking on 165 MB standalone download. Once u have downloaded this select it in the menu that will appear by doing by selecting restore whilst pressing shift at the same time. once this process has completed any errors apart from 1600, 1601, 1602 and 1603 are bad and u should redo this process any others can be ignored. Now to unlock,jailbreak and activate your phone u will need to use ZiPhone which can be downloaded from www.ziphone.org. once u have downloaded and installed it make sure your iphone is connected and recognized by itunes click do it all. once this process is completed your iphone is ready for use!
Jul 12, 2008 | Apple iPhone Smartphone
My iphone 1.1.1 version was locked after we upgrade it. we tried upgrading bec. of the restore option in the itunes. but when we connected it again w/ itunes, the restore doesnt work.help help!!!pls!!! now...
If you have an unlocked pghone and whilst on itunes it asks you to update to tht version you must click nor or else it will lock i don't know how to fix this problem you will need to contace apple or get it unlocked again.
Jan 21, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
53,003 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
