Question about Numatic Henry Bagged Canister Vacuum
Numatic Henry Micro HVR-200
We have a Numatic Henry Micro HVR0299 that shuts off after about 10 minutes of use - is there some sort of heat sensor that can be replaced?
  • 78 Answers
Motor is over heating. you need to clean bag, filter and hose first then re test
Posted on Sep 05, 2008
Vacuum shuts off after ten minutes
Hi, check the hose for a clog. A motor shutting off is usually due to overheating and there is a heat sensor to protect it from burning out. If this doesn't solve it, run the machine and see if it get too hot. If its not this simple you may need new brushes for the motor. Hope this helps. Chris
Feb 21, 2011 | Numatic Henry Bagged Canister Vacuum
Hi, last week I bought a new Henry vacuum with autosave, now the autosave feature is not working. The red indicator light does not light up and the motor does not change speed. Any ideas, other than...
Sadly you need to return to dealer, any problem contact Numatic (www.numatic.com), who supply it with a good 2 year warranty, which the dealer should support. This is a fault I see about 1 in 100, so you are a little unlucky. It will need a new switch and can easily be fitted by the dealer. With Henry's usual life expectancy anything from 5 -20 years it is well worth getting sorted.
Feb 06, 2011 | Numatic Henry Bagged Canister Vacuum
New Henry Numactic Moter - How to wire?!
on the motor there are 2 connection together and one on it's own and on the brushes 1 each ignore these .and on the motor fix to the 2 tab one that you can see a wire connection on and then fix to the other side of the motor .this worked for me
Mar 11, 2010 | Henry Numatic "" Canister Vacuum
I have a Henry 200 and the red on/off switch is stuck in the on position can it be fixed
Well... It probably can't be fixed, but it can easily be replaced. Depending where you are, spares are usually readily available. If you need more guidance, please post here again, and I'll see what I can do to help. Good luck!
Mar 03, 2009 | Numatic HHR-200 Henry Hound Bagged...
Numatic Henry Hoover
They should just pull out with a little pressure and a pair of pliers. Good luck with your repair
May 21, 2008 | Numatic Henry Bagged Canister Vacuum
Numatic Henry Bagged Canister Vacuum Logo
470 people viewed this question
Top Numatic Vacuums Experts
Chris Nomland
Chris Nomland
Andrew Taylor
Andrew Taylor
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
