Question about Logitech QuickCam Messenger Web Camera
I am not sure how to install the software - Logitech QuickCam Messenger Web Camera
  • 435 Answers
WARNING: DO NOT connect the camera to your computer before installing the software.
To install the software, insert the Logitech camera software CD into your computer's CD-ROM drive. The Setup screen should appear. If it does not, please perform the following steps:
  1. Click Start and then Run.
  2. Type D:Setup.exe and press the Enter key.
  3. Follow the on-screen instructions.
After the computer reboots, the driver installation for the camera will start. Do not connect the camera until the setup prompts you to connect the camera cable to your computer.
While the driver installation progresses, remove the camera and camera base from the packaging and mount the camera on the camera base.
When prompted, plug the camera into the USB port. You should see the following diagram to let you know where to plug the camera in:
After the installation is complete, the camera should be ready to use.
Thanks
Posted on Aug 22, 2008
Canon printer pixma mg6120 wont install . microsoft does not recognize
Turn off your security software and firewall if you have one and install the software. Once you have reinstalled your software be sure to turn on you security software and firewall again. Be sure to check the printer software and be sure it will run with your present version of your computer. It should if it ran before.
Jul 04, 2015 | Canon Pixma MG6120 InkJet Printer
Install software
I think the Install Shield has been the gold standard for building Windows software installations. In order to install software bone must Make sure that the related computer meets the system requirements of the program, game, or utility you are attempting to install.
http://mhelpdesk.com/field-service-management-software/
Sep 03, 2013 | Nokia 2626 Mobile Phone
Lost software installation
Go to the Canon website and get a new clean version of the driver software and use that version to reload the driver. Look to see if you can remove all of the old driver software before you load the new one. If this is not possible, proceed with the new installation as most good company software will look for old software and remove it before proceeding. Make sure that you have the complete software of the new driver software before starting any new installation as installing only part of it is a sure fire way to cause it to fail.
Feb 16, 2013 | Canon PIXMA MX310 All-In-One Printer
Hello... nokia n73 my device software is V4.0726.2.04,can you help me to update it?tnx and more power
first of all you have to download the software updater from the nokia webite..and once your done,connect your cellphone to the computer with a USB cable..
update software:
With device software updates and application updates, you can get new features and enhanced functions for your device. Updating the software may also improve your device performance. You can update your device's software using the Software Updater in your device or using the Software Updater PC application. Learn how to update your device's software using both methods.
It is recommended that you back up your personal data before updating your device software.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting. installation of an update.
Downloading software updates may involve the transmission of large amounts of data (network service). Make sure that the device battery has enough power, or connect the charger before starting the update. After you update your device software or applications, the instructions in the user guide may no longer be up to date.
Update device software using your PC You can use the Nokia Software Updater PC application to update your device software. To update your device software, you need a compatible PC, a high-speed internet connection, and a compatible USB data cable to connect your device to the PC.
To get more information and to download the Nokia Software Updater application, go to www.nokia.com.ph/softwareupdate.
Update software over the air Your service provider may send device software updates over the air directly to your device (network service). This option may not be available, depending on your device.
Warning: If you install a software update, you cannot use the device, even to make emergency calls, until the installation is completed and the device is restarted. Be sure to back up data before accepting installation of an update.
Request a software update
  1. Select Menu > Ctrl. panel > SW update.
  2. The device scans for available updates.
  3. Select the desired update from the list, and follow the instructions on the screen.
  4. If the installation was cancelled after the download, to start the installation, select Install sw update.
The software update may take several minutes. If there are problems with the installation, contact your service provider.
Jun 16, 2011 | Nokia N73 Cellular Phone
Reload software: 513
you would have to install or re-install the OS for your device. Make sure you have installed the software in the CD included in the kit for your phone in your computer. If you do not have it download it from the blackberry website
Download the software below: http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Make sure to select the correct region.
Run the software and select Device menu -> Update My device
If a window appears saying that there are no software updates for your device, click view other versions on the lower left of the window.
A new window should show up with a list of software have it check and select install.
Another should show up and select Install update.
If you are using another version of the software please refer to this link.
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB11320
Apr 03, 2011 | RIM BlackBerry Curve 8520 Smartphone
I have an windows vista and receive always error:ox8000FFFF when trying to install SP1
make sure you bring your system in clean boot. Uninstall you security software. Install SP1 and then install your secuirty software.
Make sure you turn off your system for five minutes before you start installing SP1
Mar 22, 2011 | Computers & Internet
The scanning software could not be found, or your scanner is not connected. please make sure you scanner and your scanning software are properly installed
the scanning software could not be found, or your scanner is not connected. please make sure you scanner and your scanning software are properly installed
Oct 23, 2010 | Acer Scan to Web 3300U Flatbed Scanner
When i press the scan button it says downloading application list and after about two minutes it says no applications found
Make sure the scan software is already installed in your computer. If not, install it using the installation cd that came with your printer. If scan software is already installed and was working before, you can uninstall and reinstall the software. Check your firewall. Make sure to allow all Lexmark communications to go through. Hope this helps. Good luck!
Mar 22, 2010 | Lexmark X3650 Printer
Install memorex expressit and later had to unstall and now i cant re-install it saids it cant install over existing have look everywhere i have been to add remove programs and even look in c drive i have...
make sure the software is compatible with the OS. Especially express it. I wouldn't worry about sure thing. Good software. If you've deleted it. I'd install again either by contacting sure thing or download.
Nov 30, 2009 | Computers & Internet
Won't install on Windows xp
try to check first if it meets the system requirements of the software.
If you are sure,then try to install the same software in a different system running windows xp. if it runs, then theres a problem with your system, you can try to update all the software updates, and scan your system for viruses. check if the firewall is turned on, and try to install it with the firewall turned off.
be sure to install it with no other programs running on your system.
Hope this works:)
Aug 10, 2009 | ValuSoft Print Workshop 2003 for PC
Logitech QuickCam Messenger Web Camera Logo
105 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
